There might be an obvious answer and logic to my question, but I want to ask.
I just paired the Ring G2 and everything works fine Device Name updated as it should and I added the Device Label
When I go to Apps and add the device to my dashboard both Device Name and Device Label pop up as separate devices.
Is this normal/common and by default? Making me crazy wondering why the device is showing up 2x but under different names.
Thank you and I understand that, maybe im not explaining or getting my question across. When I have added other devices in the past it never shows up as two separate devices like it does above.
When I go to Hubitat Dashboards to add it to my dashboard it shows up 2X. Once as Basement Slider (Device Label) & once as Rings Alarm Contact Senor G2 (Device Name).
I am just curious why it shows up as two different devices as shown below.
