Ring Chime integration
Is there way to use Rings Chime with hubitat or there doorbell camera itself.
I have two ring chimes, both operate on Wifi. Using the Ring app the chimes sound when the doorbell senses motion or someone presses the button. I have Alexa setup with a dummy Hubitat contact device that opens with movement or a button press.
one chimes and repeats wifi to my Doorbell
one chimes
The Wifi repeater creates a private wifi network useable by Ring Devices only. I've found no way to use these devices with Hubitat, SmartThings, or to extend my wifi network.
If you figure it out please post how to do it. It would be great to use the chimes as intrusion sirens or alarms, or extend my home Wifi network.
@arnb @louis
I don't know if this is still true, but it used to be that the chimes were not exposed in Ring's API.
