I tried many things I read about arming my Ring alarm from the Dashboard but still unable to do it. I installed Hubitat Safety Monitor but my Ring Tile in dashboard changed from armed to disarmed but nothing happens on the Ring virtual alarm Hub. Any idea what I do wrong ?
There is an option in the Ring Alarm device to synch it to HSM. This will make it so that HSM arms when Ring Arms and HSM disarms when Ring Disarms.
If you want to have Ring arm/disarm with HSM, you will need to create a Rule that synchs both.
Another option would be to create a button that will arm and disarm Ring. However, there will be no security code with this which has the potential to make your house alarm easy to disarm.
To activate Ring from RM, you will need to select the command:
Stings can be “Home”, “Away” or “Off”.
Hope this helps!
Merci Sebastien,
This is what I want to do, sync Ring when I arm using HSM.
Since I'm using Webcore I did not find yet how to add HSM to webcore so I can use it. I'll try to find it. Again thank you.
Should be available as a Virtual Device….
I don't see it ![]()
@thebearmay : Thank you very much ! This is what I need !
Stupid question, what Ring App did you install?
