I have a "SmartLife RGBW Controller" device setup, but it seems to only be able to control the RGB but not the W. Is there a way to do that? Also, the "color bulb" template only shows RGB.
There is a color temp slider on the RGB tile.
With what driver? Do you see the command, setColorTemperature in the edit deice page? Enter a Kelvin value and it should go to that CT setting.
