Hi Bill, I don't believe you can directly pair that remote(5122?) with sylvania strips. There is a specific LED device powersupply made by RGB genie that the remote is for. I believe if you had the RGBgenie LED powersupply , then it would work.
You could pair the sylvania LED strips to HE and then use rule machine to change colors and dim based on button presses, assuming the remote paired to HE is properly connected and sending the button presses.
I do not see that remote on the compatible devices list, did you check there?
The sylvanias will pair directly to Hubitat. You don't need the bridge. But you will need to reset the strips to get them to connect. Sylvania is dropping support, so your gateway will brick and become useless whenever that gets wrapped up. Cree bulbs are not recommended due to repeating issues. You should search both out in the community here. There are known issues with both. I have sylvania lightify strips and love them, but they're not connected to the main hub. I have them connected to a second hub because of stability issues. If you have a c7, I am unsure of how well they integrate as I have c4 hubs.
Thanks for the reply
I was hoping to benefit from the preset scenes in Lightify app
I was able to add osram gateway and link to HE so end of services not issue
If thereโs another way to have scenes like color wheel random cycles Iโd do it...
