Well, yes if you choose a dashboard design with 3 columns (which you did during setup) it will always show 3 tiles across.
You can change (at anytime) the dashboard settings by going into dash edit mode, choosing the dashboard you wish to change and editing it (pen icon) - and change theme and the dashboard name etc
@gslender : I'm testing it trying to compare to Home Remote. I have a problem with 1 tile. I have many Stelpro thermostats, (many zwave and 1 zigbee). When I click on a zwave it shows thermostat controller as mention in tap action. But on the zigbee, nothing happens when I click on it, event if the action is Show thermostat controller. Any idea why ?
I think that's a bug with several thermostats in the way the driver outputs to maker api. @bravenel provided a workaround for the moment and it will be fixed in 2.3.3 but that fix may break other maker api using progs that will have to be fixed again...(I hope I got that right)
I’m working on an update that should be posted to the App Store tomorrow. Apple don’t release apps quickly unfortunately. I’ll update Android in the next few hours.
@gslender : It's nice playing around with your app. Using another app I was able to include Hubitat Safety Monitor on the dashboard. Any idea how I can manage my Ring Alarm using your app ?
@bravenel is HSM something that MakerAPI can control/monitor? If not, can you add that? If yes, @jbilodea you should have everything you need already - I’ve not played with HSM so don’t really know why you can’t just create a virtual switch device to arm/disarm??
For now, I'm just comparing this tool with another one before deciding which one to use. With the other one I can use directly HSM, no need for a virtual switch.
hubiVue v1.1.5 Build 268 has been released to Apple AppStore, Google Play, and Amazon App Store, PLUS releases for Windows and Mac Os have been uploaded
hubiVue v1.1.6 Build 273 has been released to Apple AppStore, Google Play, and Amazon App Store, PLUS releases for Windows and Mac Os have been uploaded to the hubiVue.com website.
