[Resurrected] Advanced Honeywell T6 Pro Z-Wave Thermostat Driver
I posted this to the old thread, then I realized there is this new thread.
Thanks much for this driver. I moved away from Honeywell WIFI thermostats due to the polling delay and replaced them with the T6 Pro Z-Wave.
I had a case where I wanted the humidity reading on the thermostat to match my external humidity sensor. I found there is a config for Humidity Offset that was not included in this driver. I went ahead and added it to your driver code. Now I can bump the humidity to match my external sensor using a Webcore piston that checks for the difference and sets the calibration to make it match. All tested and working on my T6 Pro.
Edit: In case anyone is wondering, this ISU is not found in the online documentation. I found it in the manual that came with the thermostats:
"ISU# 1425 - Humidity Display Offset - 0=Off, -12% to 12% (in 1% increments). The thermostat can display up to 12% lower or higher that the actual measured % relative humidity"
If you want to incorporate this into your driver, or if anyone else wants this feature, here is the modified driver code that includes it:
import groovy.transform.Field
 * Advanced Honeywell T6 Pro
 * v1.2
metadata {
    definition (name: "Advanced Honeywell T6 Pro Thermostat", namespace: "djdizzyd", author: "Bryan Copeland", importUrl: "https://raw.githubusercontent.com/djdizzyd/hubitat/master/Drivers/Honeywell/Advanced-Honeywell-T6-Pro.groovy") {
        capability "Actuator"
        capability "Battery"
        capability "Configuration"
        capability "Refresh"
        capability "Sensor"
        capability "TemperatureMeasurement"
        capability "Thermostat"
        capability "ThermostatMode"
        capability "ThermostatFanMode"
        capability "ThermostatSetpoint"
        capability "ThermostatCoolingSetpoint"
        capability "ThermostatHeatingSetpoint"
        capability "ThermostatOperatingState"
        capability "RelativeHumidityMeasurement"
        capability "PowerSource"
        attribute "currentSensorCal", "number"
        attribute "currentHumidityCal", "number"
        attribute "idleBrightness", "number"
        command "SensorCal", [[name:"temperature calibration",type:"ENUM", description:"Number of degrees to add/subtract from thermostat sensor", constraints:["-3", "-2", "-1", "0", "1", "2", "3"]]]
        command "HumidityCal", [[name:"humidity calibration",type:"ENUM", description:"Percent to add/subtract from humidity sensor", constraints:["-12","-11","-10","-9","-8","-7","-6","-5","-4","-3", "-2", "-1", "0", "1", "2", "3","4","5","6","7","8","9","10","11","12"]]]
        command "IdleBrightness", [[name:"brightness",type:"ENUM", description:"Set idle brightness", constraints:["0", "1", "2", "3", "4", "5"]]]
        command "syncClock"
        fingerprint  mfr:"0039", prod:"0011", deviceId:"0008", inClusters:"0x5E,0x85,0x86,0x59,0x31,0x80,0x81,0x70,0x5A,0x72,0x71,0x73,0x9F,0x44,0x45,0x40,0x42,0x43,0x6C,0x55", deviceJoinName: "Honeywell T6 PRO"
    preferences {
        configParams.each { input it.value.input }
        input "logEnable", "bool", title: "Enable debug logging", defaultValue: false
@Field static Map CMD_CLASS_VERS=[0x71:3, 0x7A:2, 0x81:1, 0x73:1, 0x2B:1, 0x2C:1, 0x85:2, 0x72:1, 0x86:2, 0x8F:1, 0x31:5, 0x70:1, 0x80:1, 0x45:1, 0x44:3, 043:2, 0x42:1, 0x40:2, 0x5A:1, 0x59:1, 0x5E:2]
@Field static Map THERMOSTAT_OPERATING_STATE=[0x00:"idle",0x01:"heating",0x02:"cooling",0x03:"fan only",0x04:"pending heat",0x05:"pending cool",0x06:"vent economizer"]
@Field static Map THERMOSTAT_MODE=[0x00:"off",0x01:"heat",0x02:"cool",0x03:"auto",0x04:"emergency heat"]
@Field static Map SET_THERMOSTAT_MODE=["off":0x00,"heat":0x01,"cool":0x02,"auto":0x03,"emergency heat":0x04]
@Field static Map THERMOSTAT_FAN_MODE=[0x00:"auto",0x01:"on",0x02:"auto",0x03:"on",0x04:"auto",0x05:"on",0x06:"circulate",0x07:"circulate"]
@Field static Map SET_THERMOSTAT_FAN_MODE=["auto":0x00,"on":0x01,"circulate":0x06]
@Field static Map THERMOSTAT_FAN_STATE=[0x00:"idle", 0x01:"running", 0x02:"running high",0x03:"running medium",0x04:"circulation mode",0x05:"humidity circulation mode",0x06:"right - left circulation mode",0x07:"quiet circulation mode"]
@Field static List<String> supportedThermostatFanModes=["on","auto","circulate"]
@Field static List<String> supportedThermostatModes=["auto", "off", "heat", "emergency heat", "cool"]
@Field static Map ZWAVE_NOTIFICATION_TYPES=[0:"Reserverd", 1:"Smoke", 2:"CO", 3:"CO2", 4:"Heat", 5:"Water", 6:"Access Control", 7:"Home Security", 8:"Power Management", 9:"System", 10:"Emergency", 11:"Clock", 12:"First"]
@Field static Map configParams = [
        1: [input: [name: "configParam1", type: "enum", title: "Schedule Type", description: "", defaultValue: 2, options: [0:"No schedule/Occupacy based schedule",1:"Every day the same",2:"5-2 Schedule",3:"5-1-1 Schedule",4:"Every day individual"]], parameterSize: 1],
        2: [input: [name: "configParam2", type: "enum", title: "Temperature Scale", description:"", defaultValue: 0, options: [0:"Fahrenheit", 1:"Celsius"]], parameterSize: 1],
        3: [input: [name: "configParam3", type: "enum", title: "Outdoor Temperature", description:"", defaultValue: 0, options: [0:"No", 1:"Wired"]], parameterSize: 1],
        4: [input: [name: "configParam4", type: "enum", title: "Equipment Type", defaultValue: 2, options: [0:"None", 1:"Standard Gas",2:"High Efficiency Gas",3:"Oil",4:"Electric",5:"Fan Coil",6:"Air to Air Heat Pump",7:"Geothermal Heat Pump",8:"Hot Water",9:"Steam"]], parameterSize: 1],
        5: [input: [name: "configParam5", type: "enum", title: "Reversing Valve", defaultValue: 0, options: [0:"O/B on Cool", 1:"O/B on Heat"]], parameterSize:1],
        6: [input: [name: "configParam6", type: "enum", title: "Stages", defaultValue: 1, options: [0:"0", 1:"1",2:"2"]], parameterSize:1],
        7: [input: [name: "configParam7", type: "enum", title: "Heat Stages Aux/E stages", defaultValue: 1, options: [0:"0", 1:"1",2:"2"]], parameterSize:1],
        8: [input: [name: "configParam8", type: "enum", title: "Aux/E Control", defaultValue: 0, options:[0:"Both Aux and E", 1:"Either Aux/E"]], parameterSize: 1],
        9: [input: [name: "configParam9", type: "enum", title: "Aux Heat Type", defaultValue: 0, options:[0:"Electric", 1:"Gas/Oil"]], parameterSize: 1],
        10: [input: [name: "configParam10", type: "enum", title: "EM Heat Type", defaultValue: 0, options:[0:"Electric", 1:"Gas/Oil"]], parameterSize: 1],
        11: [input: [name: "configParam11", type: "enum", title: "Fossil Kit Control", defaultValue: 0, options:[0:"Thermostat",1:"External"]], parameterSize: 1],
        12: [input: [name: "configParam12", type: "enum", title: "Auto Changeover", defaultValue: 0, options:[0:"Off",1:"On"]], parameterSize: 1],
        13: [input: [name: "configParam13", type: "enum", title: "Auto Differential", defaultValue: 0, options:[0:"0°F",1:"1°F",2:"2°F",3:"3°F",4:"4°F",5:"5°F"]], parameterSize: 1],
        14: [input: [name: "configParam14", type: "enum", title: "High Cool Stage Finish", defaultValue: 0, options:[0:"No",1:"Yes"]], parameterSize: 1],
        15: [input: [name: "configParam15", type: "enum", title: "High Heat Stage Finish", defaultValue: 0, options:[0:"No",1:"Yes"]], parameterSize: 1],
        16: [input: [name: "configParam16", type: "enum", title: "Aux Heat Droop", defaultValue: 0, options:[0:"Comfort",2:"2°F",3:"3°F",4:"4°F",5:"5°F",6:"6°F",7:"7°F",8:"8°F",9:"9°F",10:"10°F",11:"11°F",12:"12°F",13:"13°F",14:"14°F",15:"15°F"]], parameterSize: 1],
        17: [input: [name: "configParam17", type: "enum", title: "Up Stage Timer Aux Heat", defaultValue: 0, options:[0:"Off",1:"30 minutes",2:"45 minutes",3:"60 minutes",4:"75 minutes",5:"90 minutes",6:"2 hours",7:"3 hours",8:"4 hours",9:"5 hours",10:"6 hours",11:"8 hours",12:"10 hours",13:"12 hours",14:"14 hours",15:"16 hours"]], parameterSize: 1],
        18: [input: [name: "configParam18", type: "enum", title: "Balance Point (Compressor Lockout)", defaultValue: 65, options:[0:"Off",5:"5°F",10:"10°F",15:"15°F",20:"20°F",25:"25°F",30:"30°F",35:"35°F",40:"40°F",45:"45°F",50:"50°F",55:"55°F",60:"60°F",65:"65°F"]], parameterSize: 1],
        19: [input: [name: "configParam19", type: "enum", title: "Aux Heat Lock Out (Aux Heat Outdoor Lockout)", defaultValue: 0, options:[0:"Off",5:"5°F",10:"10°F",15:"15°F",20:"20°F",25:"25°F",30:"30°F",35:"35°F",40:"40°F",45:"45°F",50:"50°F",55:"55°F",60:"60°F",65:"65°F"]], parameterSize: 1],
        20: [input: [name: "configParam20", type: "enum", title: "Cool 1 CPH (Cooling cycle rate stage 1)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6"]], parameterSize: 1],
        21: [input: [name: "configParam21", type: "enum", title: "Cool 2 CPH (Cooling cycle rate stage 2)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6"]], parameterSize: 1],
        22: [input: [name: "configParam22", type: "enum", title: "Heat 1 CPH (Heating cycle rate stage 1)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        23: [input: [name: "configParam23", type: "enum", title: "Heat 2 CPH (Heating cycle rate stage 2)", defaultValue: 3, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        24: [input: [name: "configParam24", type: "enum", title: "Aux Heat CPH (Heating cycle rate Auxiliary Heat)", defaultValue: 9, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        25: [input: [name: "configParam25", type: "enum", title: "EM Heat CPH (Heating cycle rate Emergency Heat)", defaultValue: 9, options:[1:"1",2:"2",3:"3",4:"4",5:"5",6:"6",7:"7",8:"8",9:"9",10:"10",11:"11",12:"12"]], parameterSize: 1],
        26: [input: [name: "configParam26", type: "enum", title: "Compressor Protection", defaultValue: 5, options:[0:"Off",1:"1 minutes",2:"2 minutes",3:"3 minutes",4:"4 minutes",5:"5 minutes"]], parameterSize: 1],
        27: [input: [name: "configParam27", type: "enum", title: "Adaptive Intelligent Recovery", defaultValue: 1, options:[0:"Off",1:"On"]], parameterSize: 1],
        28: [input: [name: "configParam28", type: "number", title: "Minimum Cool Temperature", description: "degrees fahrenheit", defaultValue: 50, range: "50..99"], parameterSize: 1],
        29: [input: [name: "configParam29", type: "number", title: "Maximum Heat Temperature", description: "degrees fahrenheit", defaultValue: 90, range: "40..90"], parameterSize: 1],
        30: [input: [name: "configParam30", type: "enum", title: "Air Filters", defaultValue: 0, options:[0:"0",1:"1",2:"2"]], parameterSize: 1],
        31: [input: [name: "configParam31", type: "enum", title: "Air Filter 1 Reminder", defaultValue: 0, options:[0:"Off",1:"10 run time days",2:"20 run time days",3:"30 run time days",4:"45 run time days",5:"60 run time days",6:"90 run time days",7:"120 run time days",8:"150 run time days",9:"30 days",10:"45 days",11:"60 days",12:"75 days",13:"3 months",14:"4 months",15:"5 months",16:"6 months",17:"9 months",18:"12 months",19:"15 months"]], parameterSize: 1],
        32: [input: [name: "configParam32", type: "enum", title: "Air Filter 2 Reminder", defaultValue: 0, options:[0:"Off",1:"10 run time days",2:"20 run time days",3:"30 run time days",4:"45 run time days",5:"60 run time days",6:"90 run time days",7:"120 run time days",8:"150 run time days",9:"30 days",10:"45 days",11:"60 days",12:"75 days",13:"3 months",14:"4 months",15:"5 months",16:"6 months",17:"9 months",18:"12 months",19:"15 months"]], parameterSize: 1],
        33: [input: [name: "configParam33", type: "enum", title: "Humidification Pad Reminder", defaultValue: 0, options:[0:"Off",1:"6 months",2:"12 months"]], parameterSize: 1],
        34: [input: [name: "configParam34", type: "enum", title: "Dehumidification Filter Reminder", defaultValue: 0, options:[0:"Off",1:"1 months",2:"2 months",3:"3 months",4:"4 months",5:"5 months",6:"6 months",7:"7 months",8:"8 months",9:"9 months",10:"10 months",11:"11 months",12:"12 months"]], parameterSize: 1],
        35: [input: [name: "configParam35", type: "enum", title: "Ventilation Filter Reminder", defaultValue: 0, options:[0:"Off",3:"3 months",6:"6 months",9:"9 months",12:"12 months"]], parameterSize: 1],
        36: [input: [name: "configParam36", type: "enum", title: "UV Devices", defaultValue: 0, options:[0:"0",1:"1",2:"2"]], parameterSize: 1],
        37: [input: [name: "configParam37", type: "enum", title: "UV Bulb 1 Reminder", defaultValue: 0, options:[0:"Off",6:"6 months",12:"12 months",24:"24 months"]], parameterSize: 1],
        38: [input: [name: "configParam38", type: "enum", title: "UV Bulb 2 Reminder", defaultValue: 0, options:[0:"Off",6:"6 months",12:"12 months",24:"24 months"]], parameterSize: 1],
        39: [input: [name: "configParam39", type: "enum", title: "Idle Brightness", defaultValue: 0, options:[0:"0",1:"1",2:"2",3:"3",4:"4",5:"5"]], parameterSize: 1],
        40: [input: [name: "configParam40", type: "enum", title: "Clock Format", defaultValue: 0, options: [0:"12 hour", 1:"24 hour"]], parameterSize:1],
        41: [input: [name: "configParam41", type: "enum", title: "Daylight Savings", defaultValue:1, options:[0:"Off",1:"On"]], parameterSize: 1],
        42: [input: [name: "configParam42", type: "enum", title: "Temperature Offset", defaultValue: 0, options:[(-3):"-3°F",(-2):"-2°F",(-1):"-1°F",0:"Off",1:"+1°F",2:"+2°F",3:"+3°F"]], parameterSize: 1],
        43: [input: [name: "configParam43", type: "enum", title: "Humidity Offset", defaultValue: 0, options:[(-12):"-12%",(-11):"-11%",(-10):"-10%",(-9):"-9%",(-8):"-8%",(-7):"-7%",(-6):"-6%",(-5):"-5%",(-4):"-4%",(-3):"-3%",(-2):"-2%",(-1):"-1%",0:"Off",1:"+1%",2:"+2%",3:"+3%",4:"+4%",5:"+5%",6:"+6%",7:"+7%",8:"+8%",9:"+9%",10:"+10%",11:"11%",12:"12%",]], parameterSize: 1]
void logsOff(){
    log.warn "debug logging disabled..."
    device.updateSetting("logEnable",[value:"false",type:"bool"])
void configure() {
    if (!state.initialized) initializeVars()
    runIn(10, "syncClock")
    runIn(5, "pollDeviceData")
    runEvery3Hours("syncClock")
void initializeVars() {
    // first run only
    sendEvent(name:"supportedThermostatModes", value: supportedThermostatModes.toString().replaceAll(/"/,""), isStateChange:true)
    sendEvent(name:"supportedThermostatFanModes", value: supportedThermostatFanModes.toString().replaceAll(/"/,""), isStateChange:true)
    state.initialized=true
    runIn(15, refresh)
void installed() {
    if (logEnable) log.debug "installed()..."
    initializeVars()
void updated() {
    log.info "updated..."
    log.warn "debug logging is: ${logEnable == true}"
    unschedule()
    if (logEnable) runIn(1800,logsOff)
    runConfigs()
void SensorCal(value) {
    if (logEnable) log.debug "SensorCal($value)"
    List<hubitat.zwave.Command> cmds=[]
    cmds.addAll(configCmd(42,1,value))
    sendToDevice(cmds)
void HumidityCal(value) {
    if (logEnable) log.debug "HumidityCal($value)"
    cmds.addAll(configCmd(43,1,value))
    sendToDevice(cmds)
void IdleBrightness(value) {
    if (logEnable) log.debug "IdleBrightness($value)"
    cmds.addAll(configCmd(39,1,value))
    sendToDevice(cmds)
void zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd) {
    Map evt = [isStateChange:false]
    log.info "Notification: " + ZWAVE_NOTIFICATION_TYPES[cmd.notificationType]
    if (cmd.notificationType==8) {
        // power management
        switch (cmd.event) {
            case 0:
                // idle
                break
            case 1:
                // Power has been applied
                log.info "${device.displayName} Power has been applied"
                break
            case 2:
                // AC mains disconnected
                evt.name="powerSource"
                evt.isStateChange=true
                evt.value="battery"
                evt.descriptionText="${device.displayName} AC mains disconnected"
                break
            case 3:
                // AC mains re-connected
                evt.value="mains"
                evt.descriptionText="${device.displayName} AC mains re-connected"
                break
            case 4:
                // surge detected
                log.warn "${device.displayName} surge detected"
                break
            case 5:
                // voltage drop / drift
                break
            case 6:
                // Over-current detected
                break
            case 7:
                // Over-voltage detected
                break
            case 8:
                // over-load detected
                break
            case 9:
                // load error
                break
            case 10:
                // replace battery soon
                break
            case 11:
                // replace battery now
                break
            case 12:
                // battery is charging
                log.info "${device.displayName} Battery is charging"
                break
            case 13:
                // battery is fully charged
                break
            case 14:
                // charge battery soon
                break
            case 15:
                // charge battery now
                break
            case 16:
                // backup battery is low
                break
            case 17:
                // battery fluid is low
                break
            case 18:
                // backup battery disconnected
                break
            case 254:
                // unknown event / state
                break
    if (evt.isStateChange) {
        if (txtEnable) log.info evt.descriptionText
        eventProcess(evt)
void runConfigs() {
    configParams.each { param, data ->
        if (settings[data.input.name]) {
            cmds.addAll(configCmd(param, data.parameterSize, settings[data.input.name]))
    sendToDevice(cmds)
List<hubitat.zwave.Command> pollConfigs() {
            cmds.add(zwave.configurationV1.configurationGet(parameterNumber: param.toInteger()))
    return cmds
List<hubitat.zwave.Command> configCmd(parameterNumber, size, scaledConfigurationValue) {
    if (logEnable) log.debug "ParameterNumber: ${parameterNumber}, Size: ${size}, Value: ${scaledConfigurationValue}"
    List<hubitat.zwave.Command> cmds = []
    int intval=scaledConfigurationValue.toInteger()
    if (intval<0) intval=256 + intval
    cmds.add(zwave.configurationV1.configurationSet(parameterNumber: parameterNumber.toInteger(), size: size.toInteger(), configurationValue: [(intval & 0xFF)]))
    cmds.add(zwave.configurationV1.configurationGet(parameterNumber: parameterNumber.toInteger()))
    return cmds
void zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
    int scaledValue
    cmd.configurationValue.reverse().eachWithIndex { v, index -> scaledValue=scaledValue | v << (8*index) }
    if(configParams[cmd.parameterNumber.toInteger()]) {
        Map configParam=configParams[cmd.parameterNumber.toInteger()]
        if (scaledValue > 127) scaledValue = scaledValue - 256
        device.updateSetting(configParam.input.name, [value: "${scaledValue}", type: configParam.input.type])
        if (cmd.parameterNumber==42) {
            eventProcess(name: "currentSensorCal", value: scaledValue)
        if (cmd.parameterNumber==43) {
            eventProcess(name: "currentHumidityCal", value: scaledValue)
        if (cmd.parameterNumber==39) {
            eventProcess(name: "idleBrightness", value: scaledValue)
void eventProcess(Map evt) {
    if (device.currentValue(evt.name).toString() != evt.value.toString()) {
        sendEvent(evt)
void pollDeviceData() {
    cmds.addAll(processAssociations())
    cmds.add(zwave.manufacturerSpecificV2.deviceSpecificGet(deviceIdType: 1))
    cmds.add(zwave.versionV2.versionGet())
    cmds.addAll(pollConfigs())
    sendToDevice(cmds)
void refresh() {
    cmds.add(zwave.batteryV1.batteryGet())
    cmds.add(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1, scale: configParam2==0?0:1))
    cmds.add(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 5, scale: 0))
    cmds.add(zwave.thermostatFanModeV3.thermostatFanModeGet())
    cmds.add(zwave.thermostatFanStateV1.thermostatFanStateGet())
    cmds.add(zwave.thermostatModeV2.thermostatModeGet())
    cmds.add(zwave.thermostatOperatingStateV1.thermostatOperatingStateGet())
    cmds.add(zwave.thermostatSetpointV2.thermostatSetpointGet(setpointType: 1))
    cmds.add(zwave.thermostatSetpointV2.thermostatSetpointGet(setpointType: 2))
    sendToDevice(cmds)
void syncClock() {
    Calendar currentDate = Calendar.getInstance()
    sendToDevice(zwave.clockV1.clockSet(hour: currentDate.get(Calendar.HOUR_OF_DAY), minute: currentDate.get(Calendar.MINUTE), weekday: currentDate.get(Calendar.DAY_OF_WEEK)))
void zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
    hubitat.zwave.Command encapsulatedCommand = cmd.encapsulatedCommand(CMD_CLASS_VERS)
    if (encapsulatedCommand) {
        zwaveEvent(encapsulatedCommand)
void zwaveEvent(hubitat.zwave.commands.multicmdv1.MultiCmdEncap cmd) {
    if (logEnable) log.debug "Got multicmd: ${cmd}"
    cmd.encapsulatedCommands(CMD_CLASS_VERS).each { encapsulatedCommand ->
void parse(String description) {
    if (logEnable) log.debug "parse:${description}"
    hubitat.zwave.Command cmd = zwave.parse(description, CMD_CLASS_VERS)
    if (cmd) {
        zwaveEvent(cmd)
void zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
    if (logEnable) log.debug "Supervision get: ${cmd}"
    sendToDevice(new hubitat.zwave.commands.supervisionv1.SupervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0))
void zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.DeviceSpecificReport cmd) {
    if (logEnable) log.debug "Device Specific Report: ${cmd}"
    switch (cmd.deviceIdType) {
        case 1:
            // serial number
            def serialNumber=""
            if (cmd.deviceIdDataFormat==1) {
                cmd.deviceIdData.each { serialNumber += hubitat.helper.HexUtils.integerToHexString(it & 0xff,1).padLeft(2, '0')}
            } else {
                cmd.deviceIdData.each { serialNumber += (char) it }
            device.updateDataValue("serialNumber", serialNumber)
            break
void zwaveEvent(hubitat.zwave.commands.versionv2.VersionReport cmd) {
    if (logEnable) log.debug "version2 report: ${cmd}"
    device.updateDataValue("firmwareVersion", "${cmd.firmware0Version}.${cmd.firmware0SubVersion}")
    device.updateDataValue("protocolVersion", "${cmd.zWaveProtocolVersion}.${cmd.zWaveProtocolSubVersion}")
    device.updateDataValue("hardwareVersion", "${cmd.hardwareVersion}")
void sendToDevice(List<hubitat.zwave.Command> cmds) {
    sendHubCommand(new hubitat.device.HubMultiAction(commands(cmds), hubitat.device.Protocol.ZWAVE))
void sendToDevice(hubitat.zwave.Command cmd) {
    sendHubCommand(new hubitat.device.HubAction(secureCommand(cmd), hubitat.device.Protocol.ZWAVE))
void sendToDevice(String cmd) {
List<String> commands(List<hubitat.zwave.Command> cmds, Long delay=200) {
    return delayBetween(cmds.collect{ secureCommand(it) }, delay)
String secureCommand(hubitat.zwave.Command cmd) {
    secureCommand(cmd.format())
String secureCommand(String cmd) {
    return zwaveSecureEncap(cmd)
void zwaveEvent(hubitat.zwave.Command cmd) {
    if (logEnable) log.debug "skip:${cmd}"
List<hubitat.zwave.Command> setDefaultAssociation() {
    cmds.add(zwave.associationV2.associationSet(groupingIdentifier: 1, nodeId: zwaveHubNodeId))
    cmds.add(zwave.associationV2.associationGet(groupingIdentifier: 1))
    return cmds
List<hubitat.zwave.Command> processAssociations(){
    cmds.addAll(setDefaultAssociation())
    return cmds
void zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
    if (logEnable) log.debug "${device.label?device.label:device.name}: ${cmd}"
    List<String> temp = []
    if (cmd.nodeId != []) {
        cmd.nodeId.each {
            temp.add(it.toString().format( '%02x', it.toInteger() ).toUpperCase())
    updateDataValue("zwaveAssociationG${cmd.groupingIdentifier}", "$temp")
void zwaveEvent(hubitat.zwave.commands.associationv2.AssociationGroupingsReport cmd) {
    log.info "${device.label?device.label:device.name}: Supported association groups: ${cmd.supportedGroupings}"
    state.associationGroups = cmd.supportedGroupings
void zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
    if (logEnable) log.debug "got battery report: ${cmd.batteryLevel}"
    Map evt = [name: "battery", unit: "%"]
    if (cmd.batteryLevel == 0xFF) {
        evt.descriptionText = "${device.displayName} has a low battery"
        evt.value = "1"
    } else {
        evt.descriptionText = "${device.displayName} battery is ${cmd.batteryLevel}%"
        evt.value = "${cmd.batteryLevel}"
    eventProcess(evt)
void zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
    if (cmd.sensorType.toInteger() == 1) {
        if (logEnable) log.debug "got temp: ${cmd.scaledSensorValue}"
        eventProcess(name: "temperature", value: cmd.scaledSensorValue, unit: cmd.scale == 1 ? "F" : "C")
    } else if (cmd.sensorType.toInteger() == 5) {
        eventProcess(name: "humidity", value: Math.round(cmd.scaledSensorValue), unit: cmd.scale == 0 ? "%": "g/m³")
void setpointCalc(String newmode, String unit, value) {
    String mode="cool"
    if (device.currentValue("thermostatMode")=="heat" || device.currentValue("thermostatMode")=="emergency heat") {
        state.lastMode="heat"
        mode="heat"
    } else if (device.currentValue("thermostatMode")=="cool") {
        state.lastMode="cool"
        mode="cool"
    } else if (device.currentValue("thermostatOperatingState")=="heating" || device.currentValue("thermostatOperatingState")=="pending heat") {
        mode="heat"
    } else if (device.currentValue("thermostatOperatingState")=="cooling" || device.currentValue("thermostatOperatingState")=="pending cool") {
        mode="cool"
    } else if (state.lastMode) {
        mode=state.lastMode
    if (newmode==mode) {
        eventProcess(name: "thermostatSetpoint", value: Math.round(value), unit: unit, type: state.isDigital?"digital":"physical")
void zwaveEvent(hubitat.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd) {
    if (logEnable) log.debug "Got thermostat setpoint report: ${cmd}"
    if (device.currentValue("thermostatMode")=="heat") mode="heat"
    if (device.currentValue("thermostatMode")=="cool") mode="cool"
    String unit=cmd.scale == 1 ? "F" : "C"
    switch (cmd.setpointType) {
        case 1:
            eventProcess(name: "heatingSetpoint", value: Math.round(cmd.scaledValue), unit: unit, type: state.isDigital?"digital":"physical")
            setpointCalc("heat", unit, cmd.scaledValue)
            break
        case 2:
            eventProcess(name: "coolingSetpoint", value: Math.round(cmd.scaledValue), unit: unit, type: state.isDigital?"digital":"physical")
            setpointCalc("cool", unit, cmd.scaledValue)
            break
    state.isDigital=false
void zwaveEvent(hubitat.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd) {
    if (logEnable) log.debug "Got thermostat operating state report: ${cmd}"
    String newstate=THERMOSTAT_OPERATING_STATE[cmd.operatingState.toInteger()]
    if (logEnable) log.debug "Translated state: " + newstate
    eventProcess(name: "thermostatOperatingState", value: newstate)
    if (newstate=="cooling") {
    } else if (newstate=="heating") {
    } else if (newstate=="pending heat") {
    } else if (newstate=="pending cool") {
void zwaveEvent(hubitat.zwave.commands.thermostatfanstatev1.ThermostatFanStateReport cmd) {
    if (logEnable) log.debug "Got thermostat fan state report: ${cmd}"
    String newstate=THERMOSTAT_FAN_STATE[cmd.fanOperatingState.toInteger()]
    if (logEnable) log.debug "Translated fan state: " + newstate
    sendToDevice(zwave.configurationV1.configurationGet(parameterNumber: 52))
    if (newstate=="idle" && (device.currentValue("thermostatOperatingState")=="heating" || device.currentValue=="cooling")) sendToDevice(zwave.thermostatOperatingStateV1.thermostatOperatingStateGet())
void zwaveEvent(hubitat.zwave.commands.thermostatfanmodev2.ThermostatFanModeReport cmd) {
    if (logEnable) log.debug "Got thermostat fan mode report: ${cmd}"
    String newmode=THERMOSTAT_FAN_MODE[cmd.fanMode.toInteger()]
    if (logEnable) log.debug "Translated fan mode: " + newmode
    eventProcess(name: "thermostatFanMode", value: newmode, type: state.isDigital?"digital":"physical")
void zwaveEvent(hubitat.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
    if (logEnable) log.debug "Got thermostat mode report: ${cmd}"
    String newmode=THERMOSTAT_MODE[cmd.mode.toInteger()]
    if (logEnable) log.debug "Translated thermostat mode: " + newmode
    eventProcess(name: "thermostatMode", value: newmode, type: state.isDigital?"digital":"physical")
void zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
    // setup basic reports for missed operating state changes
    if (cmd.value.toInteger()==0xFF) {
        if (device.currentValue("thermostatOperatingState")!="heating" || device.currentValue!="cooling") sendToDevice(zwave.thermostatOperatingStateV1.thermostatOperatingStateGet())
    } else {
        if (device.currentValue("thermostatOperatingState")=="heating" || device.currentValue=="cooling") sendToDevice(zwave.thermostatOperatingStateV1.thermostatOperatingStateGet())
private void setSetpoint(setPointType, value) {
    cmds.add(zwave.thermostatSetpointV2.thermostatSetpointSet(setpointType: setPointType, scale: getTemperatureScale()=="F" ? 1:0 , precision: 0, scaledValue: value))
    cmds.add(zwave.thermostatSetpointV2.thermostatSetpointGet(setpointType: setPointType))
    state.isDigital=true
    sendToDevice(cmds)
void setHeatingSetpoint(degrees) {
    if (logEnable) log.debug "setHeatingSetpoint(${degrees}) called"
    setSetpoint(1,degrees)
void setCoolingSetpoint(degrees) {
    if (logEnable) log.debug "setCoolingSetpoint(${degrees}) called"
    setSetpoint(2,degrees)
void setThermostatMode(mode) {
    if (logEnable) log.debug "setThermostatMode($mode)"
    if (logEnable) log.debug "setting zwave thermostat mode ${SET_THERMOSTAT_MODE[mode]}"
    cmds.add(zwave.thermostatModeV2.thermostatModeSet(mode: SET_THERMOSTAT_MODE[mode]))
    sendToDevice(cmds)
void off() {
    setThermostatMode("off")
void on() {
    log.warn "Ambiguous use of on()"
void heat() {
    setThermostatMode("heat")
void emergencyHeat() {
    setThermostatMode("emergency heat")
void cool() {
    setThermostatMode("cool")
void auto() {
    setThermostatMode("auto")
void setThermostatFanMode(mode) {
    if (logEnable) log.debug "setThermostatFanMode($mode)"
    if (logEnable) log.debug "setting zwave thermostat fan mode ${SET_THERMOSTAT_FAN_MODE[mode]}"
    cmds.add(zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: SET_THERMOSTAT_FAN_MODE[mode]))
    sendToDevice(cmds)
void fanOn() {
    setThermostatFanMode("on")
void fanAuto() {
    setThermostatFanMode("auto")
void fanCirculate() {
    setThermostatFanMode("circulate")
void setSchedule() {
    log.warn "setSchedule is not supported by this driver"
I had the same issue, as I bought open box thermostats that were not excluded when I got them. I simply did a factory reset from the thermostat options and that worked, but it is also good to know they can be excluded by using Inclusion mode.
I'll look at merging the code this morning, thanks.
Edit: Merged changes and added a refresh when setPoints change to address @idallen 's note
I'm going to remove my Refresh polling I recently installed as the setPoints fix might have been my intermittent incorrect readings as well.
Tks
Thank you. Do you have comments on my October 4 changes? Does Groovy have hashes?
I remember looking at your suggestion but don't remember making the changes so I'll need to look again to see why. As to hash, if you mean a HashMap ([key:value]), yes.
When connected to a system with a heat pump with emergency backup this thermostat will switch to Emergency Heat when the outdoor temp drops below a user set limit or when the heat pump isn't increasing the indoor temp. Is there any monitored thermostat parameter that will reflect this automatic switch to emergency heat? I think the Thermostat mode can be set and it's value retrieved but I don't know that it will reflect a change to emergency heat.
Looks like the driver has some code for emergency heat, but I don't see any support on the physical device for it; i,e, when I toggle through the thermostat modes on the physical device it goes: cool, heat, off.
I would guess the emergency heat option is only shown when your t-stat is configured that it has emergency heat available.
Just installed a T6 Pro Z-wave, and it's working fine. I tried both the built-in driver and your more advanced driver. I have two questions:
  1. After switching back and forth between drivers it seems that the reported temperature is staying the same (73.4), even as the thermostat itself is cycling as needed, Could I have somehow gotten a "stuck" report and is there a fix?
  2. Does the built-in thermostat scheduler work properly with your driver?
  3. I'm not seeing the Powersource attribute reported...?
    Thanks for any help, still learning this system
Many drivers may require you to hit the "Configure" button on the device change after saving the driver change. Give that a try to ensure the driver you are using has applied its settings, etc. @thebearmay will have more (and better) help for you when he comes by again. :slight_smile:
May not be related to your issues, but won't hurt.
Thanks, I should have mentioned that I already tried that :wink:
My temps are reporting fine, no issues there.
There's no reason why this driver wouldn't play nicely w/the Thermostat Scheduler that I'm aware of. Have you seen any issues?
On powerSource, a post from above, so it should show up in a while:
Generally hitting the Configure will enable all functions, but you could try hitting Save Preferences to ensure all of the parameters were initially stored correctly. Refresh should also force a update of the temperature and humidity. As for the scheduler, I haven’t tried it but it shouldn’t have an issue.
Thanks. Not sure what I did, but seems to be working again and reporting properly...
As for the scheduler, the only thing I noticed is that with the default driver you can specify the fan mode for each schedule time, whereas with this driver, the fam mode doesn't seem to be active on the schedule.
I’ll take a look at it and see if I can recreate.
Found the issue. Fix is in v1.2.17. After importing the code or updating from HPM. Click on the new command Initialize Vars to update the Thermostat and Fan Mode attributes - after doing that the Thermostat Scheduler should work as expected. Thanks for catching this.
Sounds great! Meanwhile, my first problem has recurred... thermostat reports a set temp, even though it cycles properly. Seems to rarely report temp.. not sure why
Confirmed that the change you made now allows setting fan mode in the scheduler :+1:
Here's a bit more info about the issue I'm having. In this event list, the schedule kicks in at 11:00, lowering the heat setpoint from 74 to 72. Notice the next few temp reports... doesn't seem to make sense...?
