I originally looked into that and the only ad blocker I have is pi-hole and no blocking extensions.
I shut the pi-hole down for 30 minutes and while it was off I cleared the cache and then rebooted but still had the same problem. Went through a couple of Windows 11 and Edge updates, but still no change. Normally issues like this are somewhat easy to sort out, this one though has me puzzled.
I did some research and they do some low-level blocking, I whitelist habitat restarted, and no change... I still see code snips and screenshots, but none of the actual comments and no one else seems to have this problem
Usually use Chrome but just as a test I just logged into the Community using Edge (Version 108.0.1462.54 (Official build) (64-bit)) on Windows 10 Pro (Version 22H2, Windows Feature Experience Pack 120.2212.4190.0) and using piHole v5.2.4. I believe I am seeing all messages and responses.
Nope, no extension installed. I did a reset of the browser and still nothing, I downloaded it from Microsoft and reinstall no difference. I navigated to my old stomping grounds the Home Assitance forum, the problem doesn't manifest itself over there.
I guess my only option is to figure out how to remove it from Windows 11 and then reinstall it just to see if that fixes it.
I do as well, but every once in a while I hop over to Edge. The only reason this bothers me is that it was working just fine and all of a sudden this happens and you know how it is, if it's broken and you don't use fix it, lol
At first, I did a repair, that didn't work, then I reinstall it and it didn't work, and now a reset, that worked, I can see the replies again. However, I still don't know what caused it.
