Is it possible to restore a C8 backup to a C7?
Both hubs are registered for hub-protect, but I'll only want to restore the apps etc, not the Z-wave and Zigbee devices, as these are already paired to the C7. (The C7 was migrated to a C8, but I want to revert to the C7. I can simply turn the C8 off and turn the C7 on, but I've made some changes to webCore (changed existing pistons and added a few) which I would like to transfer to the C7.)
Thank you.
You can do this with cloud or local however as Bruce has just explained on another thread provided you haven't changed your z-wave it should work. But your ZigBee device would need to be reset and rejoined (they will fall straight back into there old holes though). This is because there internal counters won't match to the hub.
