Hubitat OS: 2.3.4.122
I am getting the following error from one of my SmartSense Multi Sensor V4.
Settings for the device look like:
I've tried enabling debugging, but it keeps turning off before the error occurs.
Have you by any chance switched drivers for this device recently?
No. The driver has been in use since I installed it over a year ago. I don't remember there being errors initially.
I have 2 other SmartSense Multi Sensor V4 and do not see the errors on either of those.
I believe I have resolved the issue. I changed the driver to a Generic Component Multi Sensor driver and ran configure/refresh using the generic driver. I then changed back to the SmartSense Multi Sensor V4 driver and ran configure/refresh.
I haven't seen the error since doing that over 24 hours ago. The issue use to show up every 1-2 hours before that.
