Not sure where else to post this. I use the built-in Nanoleaf Aurora driver to control a Nanoleaf Shapes install in my house. After a recent incident, my Nanoleaf controller was damaged and had to be replaced. When I got the new one set up, I went to try and grab a new authorization token for the existing device and found that it wouldn't request a new token since it already had one and I could not find a way to clear the existing one out as it is stored in the device state.
I ended up having to create a whole new Nanoleaf device and then update everything that referenced it. It would be really helpful if you could just reset the existing device and get a new token instead of having to go through the process of creating a whole new device. Considering how unreliable Nanoleaf shapes have been for me as a whole, and how often I have had to factory reset it, making it so the auth token can be reset on an existing device in Hubitat just makes sense.
Following because I have an Aurora and an Elements. Today I tried to setup what appears to be an open box canvas and I've been having mega trouble getting it to connect all day. Similar symptoms may be manifesting differently.
I'm pretty sure when I changed my nanoleaf controller I changed the driver to a zigbee toolbox and cleared the token then changed back and then got a new token
