Required Expression - Cancel pending actions
Under Required Expression, does ā€œCancel pending actions when required expression becomes falseā€ stop the ā€œrepeatā€ of an action? Is a repeat considered a pending action?
Consider a rule that has an action that repeats 10 times. If the required expression becomes false after 4 repeats, would the 6 remaining repeats be cancelled?
Make a rule to test this out and report back what happens.
Edit: Okay, I couldn't wait and made my own test rule. Yes, the Repeat will stop when the RE becomes false.
Based on the documentation here: Rule 5.1 | Hubitat Documentation
I would suspect that it does cancel repeats, as those would be in the same category as "delays/waits, etc"
Thank you @pseudonym and @tray_e for responding!
I just got done testing my rule, and as stated by @pseudonym earlier, the repeats are indeed cancelled.
