Request to Add Innr AE 282 C Firmware 1.9.54 to Zigbee OTA Updater
I used AI to help me state what was needed to request an OTA firmware be added to Hubitat. I just added some new bulbs and found out they had newer firmware. I did the search for the firmware myself. But I was unsure what information might be needed. So, yes AI wrote the request. I did my best to validate what I could of what it generated.
The firmware release notes describe expanded color-temperature support, improvements to color accuracy and white-light quality, and general stability fixes.
@mike.maxwell
Would it be possible to add firmware version 1.9.54 for the Innr AE 282 C Zigbee 3.0 RGBW bulbs to Hubitat's built-in Zigbee OTA firmware repository?
I recently replaced 12 older EcoSmart CT bulbs with Innr AE 282 C RGBW bulbs. All 12 are currently running firmware version 1.9.33.
I located firmware version 1.9.54 in the Koenkk Zigbee OTA repository, which is used by Zigbee2MQTT. The firmware image matches the manufacturer ID and OTA image type reported by my bulbs.
Device Information
Property Value
Manufacturer Innr
Model AE 282 C
Protocol Zigbee 3.0
Current firmware 1.9.33
Current firmware identifier 0x19213685
Manufacturer ID 0x1166
OTA image type 0x04B0
Hub Hubitat Elevation C-8 Pro
Available Firmware
Property Value
Firmware version 1.9.54
Firmware identifier 0x19363685
File size 300,978 bytes
Filename 1166-04b0-19363685-ae282c-1.9.54.ota
Firmware Source
The firmware is available in the Koenkk Zigbee OTA repository, a widely used collection of manufacturer firmware images.
Firmware file:
https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Innr/1166-04b0-19363685-ae282c-1.9.54.ota
Firmware index:
Original repository pull request (merged September 15, 2026):
Hubitat Firmware Availability Check
I also checked the built-in Zigbee firmware updater on my C-8 Pro using one of the bulbs.
The following messages were returned in the hub's logs:
Firmware update for BCKDN1, innr 1166-04B0-19213685 is not available.
Unable to download firmware update for BCKDN1, innr, please try again.
This indicates that Hubitat is not currently offering a firmware update for this device.
Since the newer firmware image has matching manufacturer and image-type identifiers, would Hubitat be able to review it and add it to the built-in Zigbee OTA firmware repository?
Thank you!
That firmware is already available, the failure indicates that the hub wasn't able to download it for some reason, if you can DM me your hub id i can have a look at the engineering logs, they should have some info as to why the download failed.
Turns out there is a regression bug due to another hub components update.
This should be fixed in the next 2.5.3 release...
Thank you sir!
Confirming fix if you needed it. All good now
