Sorry, that was confusing for me just to write!
I too couldn't duplicate it, but I'm guessing you were doing what I just did. Used the "<<App list" link to return and then opened HSM again? It doesn't do it when you do that. If you click "Done" then reopen, you should be able to see the issue. If you still cannot duplicate it, I can make a screen recording of the steps to show it for you.
We figured this out. Obviously, this only happens if the app is open, an event occurs, and then you hit Done. The fix unfortunately entails rewriting a significant amount of code. That will be in the next release.
Sorry it wonβt be an easy fix. Glad you were able to find the issue though.
It's an edge case, leaving the app open while some other app is running that arms or disarms HSM. The fix isn't difficult.
This has been fixed in the latest release: Hub Update 1.1.3
If you hit Done it will honor the change to arm setting that occurred from an external source. If you open the app again you would see the changed setting. If you hit refresh on that page, the arm setting of that page would be set (over-ruling the external source).
