How did you go with porting this one mate?
couldnt get it working but didnt spend long on it. unfortunately i have no idea what im doing.
@anon61068208 @jchurch when I click in the link I go to this page. No options for sign up and if I click in " There are public projects listed [here]" I can't find this project. Is there anotrher way to get this code? Thank you
Repo has been deleted. @jchurch was banned from here and on my hosted repository. You will have to contact Jason at oh-la labs for the code.
@Evilborg thanks for the tip, I got the driver. After insert the IP and port, save and click in refresh this log appears. Any idea what is going on? I am using port 80.
Again you need to talk to Jason about this device. This is his code not mine.
Hi All.
I have the fronius Symo + Smart meter working in my updated version of Tim Flinders / JChruch's fronius driver.
It also goes to 'sleep' overnight when the invertor shuts down. (Reduces to 30 min poll time)
I haven't gone as far as reading voltage and current (that the smart meter also supports), but if there's interest I might do it.
This is my first attempt at coding anything in groovy, so if you see some improvements, please share and be nice.
* Fronius Solar Inverter
* Copyright 2015 Tim Flinders
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* EDITED by jchurch to include runEvery15Minutes(refresh) - 02/20
* EDITED by jchurch and Markus to include ErrorCode information and clean up ported code for Hubitat slightly - 02/20
* EDITED by jchurch and Markus to include kWh conversation for energy stat - 02/21
* Updates by HardyM to give 1 min updates, reduce to 30 mins polls overnight, and also return data from Fronius SmartMeter to give Grid power and Load. 2021-07-25
* Dec 18,2021. Added attribute access to pGrid and pLoad. (HardyM)
Sourced from here
https://github.com/jchurchward/Fronius-Solar-Inverter/blob/main/Fronius-solar-inverter-driver
import groovy.json.JsonSlurper
preferences {
input("inverterNumber", "number", title: "Inverter Number", description: "The Inverter Number", required: true, displayDuringSetup: true)
input("destIp", "text", title: "IP", description: "The device IP", required: true, displayDuringSetup: true)
input("destPort", "number", title: "Port", description: "The port you wish to connect", required: true, displayDuringSetup: true)
metadata {
definition (name: "Fronius Solar Inverter", namespace: "TimFlinders", author: "Tim Flinders") {
capability "Polling"
capability "Power Meter"
capability "Energy Meter"
capability "Actuator"
capability "Refresh"
capability "Sensor"
attribute "errorCode", "number"
attribute "pGrid", "number"
attribute "pLoad", "number"
def initialize() {
log.info "Fronius Inverter ${textVersion()} ${textCopyright()}"
sendEvent(name: "power", value: 0 )
sendEvent(name: "YearValue", value: 0 )
sendEvent(name: "energy", value: 0 )
sendEvent(name: "pGrid", value: 0 )
sendEvent(name: "pLoad", value: 0 )
sendEvent(name: "TotalValue", value: 0 )
state.parseCallCounter=0
// updated()
poll()
// parse events into attributes
def msg = parseLanMessage(description)
def slurper = new JsonSlurper()
def result = slurper.parseText(msg.body)
def errorCode = result?.Body?.Data?."$inverterNumber"?.ErrorCode
if(errorCode != null) {
sendEvent(name: "errorCode", value: errorCode )
} else {
sendEvent(name: "errorCode", value: 0 )
int yearValue = result.Body.Data.Site.E_Year
int dayValue = result.Body.Data.Site.E_Day
int totalValue = result.Body.Data.Site.E_Total
int pGrid = result.Body.Data.Site.P_Grid
int pLoad = result.Body.Data.Site.P_Load
pLoad = -pLoad
def pPV = result.Body.Data.Site.P_PV
int power
if (pPV == null) {
power = 0
} else {
power = pPV
sendEvent(name: "power", value: power, unit: "W" )
sendEvent(name: "energy", value: dayValue, unit: "Wh")
sendEvent(name: "eYear", value: Math.round(yearValue/100)/10, unit: "kWH")
sendEvent(name: "TotalEnergy", value: Math.round(totalValue/100)/10, unit: "kWH")
sendEvent(name: "pGrid", value: pGrid, unit: "W")
sendEvent(name: "pLoad", value: pLoad, unit: "W")
//Keep track of when the last update came in
if (state.parseCallCounter>0)
updated() // reset the poll timer back to 1 min if we got an answer
sendEvent(name: "Status", value: "Online")
// handle commands
def poll() {
if (state.parseCallCounter==null) {
state.parseCallCounter=1
} else {
state.parseCallCounter++
if (state.parseCallCounter==3)
// Not getting Fronius's replies so could be sleeping. Set the timer with 30 min interval
sendEvent(name: "Status", value: "Not Responding")
unschedule(refresh)
schedule('0 */30 * ? * *', refresh)
callInvertor()
def callInvertor() {
try
def hosthex = convertIPtoHex(destIp)
def porthex = convertPortToHex(destPort)
device.deviceNetworkId = "$hosthex:$porthex"
sendHubCommand(new hubitat.device.HubAction(
'method': 'GET',
'path': "/solar_api/v1/GetInverterInfo.cgi?Scope=System",
'headers': [ HOST: "$destIp:$destPort" ]
def hubAction = new hubitat.device.HubAction(
'method': 'GET',
'path': "/solar_api/v1/GetPowerFlowRealtimeData.fcgi",
hubAction
catch (Exception e) {
log.debug "Hit Exception $e on $hubAction"
private def textVersion() {
def text = "Version 1.0"
private def textCopyright() {
def text = "Copyright Β© 2015 Tim Flinders"
private String convertIPtoHex(ipAddress) {
String hex = ipAddress.tokenize( '.' ).collect { String.format( '%02X', it.toInteger() ) }.join()
return hex
private String convertPortToHex(port) {
String hexport = port.toString().format( '%04X', port.toInteger() )
return hexport
def refresh(){
poll()
def updated(){
unschedule(refresh)
schedule('0 */1 * ? * *', refresh)
Hi, is there a way of using βpGridβ value in a rule, in order to activate a socket when there is enough power produced? Thanks!
I think so. Sorry for the delay,
I think you need to make a variable in the rule machine where you can assign any parameter's value to the variable. Then use the variable in your rules.
See if that helps. If not - let me know and I'll experiment with it.
I can only set 2 types of data to a variable: sensor value (ENERGY METER and POWER METER are available from Fronius driver) or device attribute (energy, error code and power are available).
Any idea how I get to use pGrid?
ok. Looks like this works, but you need to add these two attribute lines near the top of the driver code. Add them immediately after the attribute "errorCode" line.
(I have updated the code in my original post with these mods)
Then, I would advise watch the driver until the next update comes through and the attribute values display.
Following this, I could select these attributes (like pGrid) in a rule for assigning values or creating conditions.
