@mike.maxwell
At the present time, the only options for times are very short ones, the maximum being 5 seconds. Can this please be expanded, up to later, to 5 minutes.
Help yourself (5 minutes is 300000 msecs):
metadata {
	definition (name: "Virtual Switch", namespace: "hubitat", author: "Bruce Ravenel") {
		capability "Switch"
		capability "Refresh"
	preferences {
		input name: "autoOff", type: "enum", title: "Enable auto off", options: [0:"Disabled",500:"500ms",1000:"1s",1500:"1500ms",2000:"2s",5000:"5s"], defaultValue: 0
		input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
		input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
void logsOff(){
	log.warn "debug logging disabled..."
	device.updateSetting("logEnable",[value:"false",type:"bool"])
void installed() {
	log.warn "installed..."
	off()
	runIn(1800,logsOff)
void updated() {
	log.info "updated..."
	log.warn "debug logging is: ${logEnable == true}"
	log.warn "description logging is: ${txtEnable == true}"
	if (logEnable) runIn(1800,logsOff)
void parse(String description) {
	if (logEnable) log.debug "parse ${description}"
	if (description == "on") on()
	else if (description == "off") off()
void refresh() {
	sendSwitchEvent(device.currentValue("switch"))
void on() {
	sendSwitchEvent("on")
	if (autoOff != null && autoOff != "0") runInMillis(autoOff.toInteger(),off)
void off() {
	sendSwitchEvent("off")
void sendSwitchEvent(value) {
	String descriptionText = "${device.displayName} ${ (value == device.currentValue("switch")) ? "is" : "was turned" } ${value}"
	if (txtEnable) log.info descriptionText
	sendEvent(name:"switch", value:value, descriptionText:descriptionText)
          Or you can use this one:
