A motion sensor at the front door is quite handy for other things too. Auto porch lights ON, extra trigger for Auto Unlock and arrival status, security, etc. since you’re in a warm climate, battery drain in Winter does not exist like it does for me, so you just stick a sensor outside your front door, write the rule and you are done.
Alternately you trigger from the inside with a Xiaomi motion sensor. Even easier and cheaper, but your arrival and added security benefits that and outdoor motion sensor offers are reduced.
Yeah, formalizing would be the way to go, this howerer requires a minimum across the board attribute set applicable to all devices of a given class, and with locks this is difficult.
I have August auto-unlock when I arrive home (August feature) or via HomeKit. It would be nice to have it automatically run the "Home mode" when it was unlock "digital" but not physical.
Thanks for sharing this. I never programmed in Groovy before but after looking at the code I think I just need to modify the "evt.descriptionText.endsWith" & "evt.type" statement to match the August lock reply.
Here are the changes I made; I haven't tested this yet (will post an update after I do). But basically this is what I want the code to do (If lock is locked turn on the virtual switch. If lock is unlocked digital turn off the the virtual switch).
definition(
name: "August Lock Events",
namespace: "rvrolyk",
author: "Russ Vrolyk",
description: "Tracks if August Lock was unlocked digitally. Modified by K-MTG",
category: "Convenience",
iconUrl: "",
iconX2Url: "",
iconX3Url: "")
def lock = [
type: "capability.lock",
title: "Lock",
description: "Select the lock to monitor.",
required: true,
multiple: false
def virtualLockedSwitch = [
type: "capability.switch",
title: "Virtual Lock Switch",
description: "Virtual switch that should be turned on when lock is locked and off only when digitally unlocked.",
required: true,
multiple: false
def enableLogging = [
type: "bool",
title: "Enable debug Logging?",
defaultValue: false,
required: true
preferences {
page(name: "mainPage", title: "<b>Lock to monitor:</b>", install: true, uninstall: true) {
section("") {
input lock
input virtualLockedSwitch
label title: "Assign an app name", required: false
section ("<b>Advanced Settings</b>") {
input enableLogging
def installed() {
log.info "Installed with settings: ${settings}"
initialize()
def updated() {
log.info "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
log "Lock status: ${lock.displayName} " + lockStatus()
subscribe(lock, "lock.locked", lockHandler)
subscribe(lock, "lock.unlocked", unlockHandler)
def lockStatus() {
return lock.currentValue("lock")
def lockHandler(evt) {
virtualLockedSwitch.on()
log "${lock.displayName} was locked"
def unlockHandler(evt) {
log("Unlock event: ${evt.name} : ${evt.descriptionText}")
if (evt.type == 'digital' && evt.descriptionText.endsWith('is unlocked [digital]')) {
log "${lock.displayName} was unlocked inside"
virtualLockedSwitch.off()
} else {
log "${lock.displayName} was unlocked"
def log(msg) {
if (enableLogging) {
log.debug msg
If someone can confirm the changes I made won't preform an unexpected action that would be much appreciated!
Btw is their sample code on how to get the current mode and change mode on a UserApp? Might as well have it change the mode directly instead of having RM act on the virtual switch.
A "keypad" lock means the device was locked from the outside.
A "physical thumb" lock is most likely from the inside (and, since we're writing our own "rules" to automate things, it's very easy to make that assumption).
So, "keypad lock" means you just left--and should do an "Arm Away".
A "Thumb knob" turn lock means you're in the house and either shouldn't do anything--or should lock "stay" (if all the doors in the house are locked).
That makes for some very helpful automated routines--and a whole lot more straightforward than kludging together a variety of motion sensors and building a full-blow AI engine to determine where the person is.
@kamransiddiqi1998 Have you try out your groovy scripts? I'm also looking for an app to differentiate the lockingEventMethod between physical or digital.
What device type is required for the Virtual Lock Switch? I set up a virtual lock type but not shown up. Only bulb, outlet and switch types are listed. Would be good to amend it to include lock type, since it is technically representing a "lock". Sharing my thoughts.
I have copied your scripts and made minor tweak to try it on my Schlage Lock but still not working. I tried your original codes and it didn't work, as the Description Texts in the event log are different to the text you have.
Here's the Events from the Lock
Name | Value | Unit | Description Text | Source | Type
[Digital] in my lock means when the lock/unlock action is triggered from an app, such as from Hubitat or SmartThings hub.
[Physical] means lock/unlock using either the knob on the inside or the keypad. The lock/unlock event description include whether the event is physical by knob or physical by keypad.
Thanks for this - I was able to tweak this to use for my Schlage BE469 as well and tweaked it to focus on the lock button from the keypad and is working flawlessly so far! Thank you, thank you!!
