Report Temperature to Dashboard from HUE Outdoor Motion Sensor
I have a Hue Outdoor Motion sensor and would like to put a Temperature guage on my dashboard. Is there a way to do that?
Welcome to the madhouse. :wink:
Something like this?
This is created using a community app called 'Hubigraphs'.
If you decide to give it a go I would download it via Hubitat Package Manager as there are a lot of elements to it.
Good luck.
I use a Hue Motion sensor for outside Temp as well.
Simple Temp dashboard tile.
More Hubigraph, chart not gauge I know @bobbles beat me to it :wink:
Thanks, and yes but was hoping it already existed in Hubitat, I will take a peak at it. Are you using the HUE outdoor sensor?
Cool, what are the mechanics of getting this to work. If you can just point me in the right direction I will do the legwork
No, I don't use that type of device.
The picture I showed above is the humidity sensor in my bathroom.
These are 4 different sensors (all motion, but they do not need to be) in various locations. Hubigraph > Time Graph and it will walk you thru the settings. Hubigraph has a ton to offer, so I would start with just one or sensors on a graph and play with each to get the fell. Enjoy a fantasic app from @thomas.c.howard
The only thing the exsist by default is the tile I posted above, not gauge, chart/graphs. you need apps for that
:point_down:
:point_up_2:
