Replace Yale lock Hardware- Zwave module
C8 pro version 2.5.1.143 with zwave JS
I have a Yale assure lock 2 touch that I need to replace the hardware have the spare using the zw3 (700 series) zwave module. Anyone know of when I swap the hardware if I need to zwave exclude the lock, replace the hardware then re include again? Or is it possible to just swap the hardware and pop the module back on and it all work as was before? I use LCM so hoping codes carry over I do not use the Yale app at all
Exclude the lock before replacing the module. Include it again after replacing the module.
Ok. Was hoping just swapping hardware would work but will do as you noted.
saw prior posts that using a virtual lock swapping old over then swapping to new so I don’t have to recreate rules doesn’t play nice with LCM. If anyone has done it successfully, please let me know.
