I want to rename the buttons I create for Button Controllers or at least what appears when I add them to Dashboards.
As it is now, I am able to only set the correct name only upon creation - and if it's not set correctly then I need to delete and redo them
This is probably an obvious settings which I can't see - but I I can't figure it out so I am asking
Just overtype the name in the Name this Button Controller field, click your cursor out of the field and press Done
Thanks for the message. I can't seem to find the Name This button Controller field. In which page/screen is it?
Depending which version controller you want to edit
argyrou
October 29, 2021, 12:49pm
5
Thank you. All this time I was trying to rename the sub-buttons but I just realized that this cannot be done
I would also like to rename the buttons of a virtual button.
simon4
June 17, 2023, 1:23pm
7
I concur with this one. Renaming the buttons in Button Controller would be nice so you know what they do.
When using virtual buttons in Rule Machine you have no context as to what the button is doing. Being able to add a name to the button would make this much easier.
