I'm writing to hub variables in my app. If I have a variable linked, and use the "rename" option in the hub variable menu, the app is throwing an error.
After this, app updates that should be setting the variable are also throwing an error (I presume it's still trying to set the "old" variable since the name update is failing.
You have to provide a method in your app called renameVariable that takes two string parameters, the old name and new name. Looks like you didn't do that.
That method has to track down all settings and state that refer to the old name, and update them to use the new name.
