Good day,
I have decommissioned a Smartthings Hub and I have tried to remove it from HE following the direction in the Hubconnect app. The ST hub doesnt get removed and not sure on how to get it removed.
Has anyone else encountered this ? and if so how did you get it removed?
B
On your Server hub, select the ST Remote and you should see this at the bottom...
![Screen Shot 2022-01-12 at 11.48.51 AM](https://community.hubitat.com/uploads/default/original/3X/5/e/5e7e7d70a94a94f6735151d8b659b922ea437e78.png)
I had done that before and then hit the red "remove" button and the app appeared to go through the removal process but then it would show the Hub as still being there. Tried it a couple times and then, for grins and giggles did a restart and retried, that worked.
Odd behaviour but gone.
