Remove debug log entries from Webcore
Is there any way to limit the volume of debug entries from Webcore pistons?
Thanks!
What is the logging level set on that piston?
Can see this in IDE when you open the piston, or looking at the piston app in the HE console.
As I’m still working on it, I have the full log enable. Is that setup affecting what is reported in the HE log?
that message comes out because full logging on the piston is on. It will go away when you reduce below full logging
Makes sense. Thanks for the education!
