I have on of these coming tomorrow. I'm sure this will probably work with the Generic Z-Wave Thermostat driver. But...
Does anyone have a custom driver for this? Thought I would ask before I make one, as I will need access to a few parameters in it that I'm sure are not in the generic driver - like sensor calibration/adjustment.
Not surprisingly, this thermostat was detected as 'device'. I changed it to generic zwave thermostat, and it seems to be working.
This one should get its its own driver at some point, though, as you can not reset the filter change messages except via zwave. Can do with the basic zwave tool for now.
Pairing info:
Manufacturer: 5254
Product Name: Device
Model Number: Unknown Part Number
deviceTypeId: 19
nodeId:47
deviceId:8170
manufacturer:5254
deviceType:0200
inClusters:0x5E,0x98,0x72,0x5A,0x86,0x7A,0x59,0x85,0x70,0x73,0x20,0x31,0x40,0x42,0x43,0x44,0x45
outClusters:0x20
No, pretty much won't dink with thermostats unless I have the device in hand, too many moving parts, so not willing to punt these as we can do with simpler devices.
They are shit. Strong "do not buy" recommendation.
Build quality sucks, up/down controls get stuck on occasion for example. I had to modify all 4 of mine with rubber spacers to keep it from ramping my temp down to minimum randomly / every time I touched it.
It does not have minimum runtime settings. I caught the thermostat turning my hvac compressor on/off 16 times in 10 minutes. Very bad for the equipment.
