Remote Admin not working - Subscription Active
Murphy is hard at work.
I’m out of town and attempting to connect to my protected hub through the mobile app. When I select the hub in settings, then go to ‘tools’, the ‘connect to hub’ tab changes to ‘Purchase Remote Admin’.
When I check subscriptions it shows active with hub protect and remote admin, and when I check registered hubs it also shows protected.
In the registered hubs section I can click connect to hub and it just clocks, but never connects.
I can access and control devices through the devices button, so I know I have network connectivity to my home.
Thoughts?
Should have included I have not updated to 2.3.1. Im on the latest release prior to 2.3.1
@bobbyD
@rabell, please see my PM.
Could you please try to log in using the Remote Admin portal by accessing the following page from a browser:
https://remoteaccess.aws.hubitat.com/login
Let me know if that works. If not, you may need to reboot the hub when you have a chance.
That did work. gopher.ny was already working to reboot my hub for me.
Thank you
All good now.
Thanks @gopher.ny and @bobbyD
Excellent. If you ever need to reboot the hub, you can do it from the Remote Admin portal:
