Remote admin access re-writing image URLs in Dashboards
Hello!
My image urls in dashboards keep re writing not sure what’s happening here but thought it might be related to Remote Admin.
Was first considering it might be the app... so details are here:
@bravenel Is this a bug, or working as designed?
I'm having the same issue as above in Dashboards and also in Rule machine (both 5 and legacy) when editing through Remote Admin, the local URL's get changed from the local 192.xxx.xxx.xxx to Remoteaccess.aws.hubitat.com, but don't revert back on the local network until they are manually changed locally. Any ideas on this, or a workaround to keep the URL's using the local IP addresses?
It's an unintentional side effect of URL rewrite in remote access, yes. This will need to be patched in the hub firmware.
Should be fixed in 2.2.8.145, ping me if you still see issues.
I did not see this! I haven't had a chance to check this out yet... I kind of gave up on it...about to go on vacay but will try this when I can!
