[RELEASE] Zigbee Window Shade driver with positioning for modules/motors that don't report position
[RELEASE] Zigbee Window Shade/Blind (Timed) β€” Sonoff MINI-ZBRBS, Tuya, ZCL
A Hubitat driver for Zigbee shade/curtain/blind modules that estimates position based on movement time, motor and Zigbee delays.
Designed for devices that don't reliably report their position, or don't report the position at all.
This was the first driver I've developed for Hubitat back in 2021 when I got my first hub.
It's been improved over the years, but the main calculations didn't change since then, so it is very stable and well tested.
Supported Devices
Device Protocol Recommendation
Sonoff MINI-ZBRBS ZCL :white_check_mark: Strongly recommended. Powerful Zigbee signal, works perfectly.
LoraTap SC500ZB Tuya :yellow_circle: Works well, weaker Zigbee signal than Sonoff, but no other issues.
Zemismart ZW-EC-01 Tuya :red_circle: Not recommended. Can't disable calibration. Sometimes drops from the Zigbee network.
Other ZCL devices ZCL Should work with any device that follows ZCL Window Covering cluster standards.
Other Tuya devices Tuya May work with similar Tuya devices, but not tested.
Features
  • Time-based position estimation β€” Configurable open/close durations and motor start delays for precise positioning.
  • Semi-blind position β€” Special support for cellular/honeycomb shades: setting position to 3% uses a dedicated timing for precise cell positioning (e.g., cells closed with shade slightly raised for privacy + light).
  • Inverted movement near lower limit β€” When targeting a low position (≀5%), the shade first closes fully and then opens to the target, improving accuracy near the bottom.
  • Turbo Mode (Sonoff only) β€” Increases Zigbee radio power for better range.
  • Safety timeout β€” Automatically recovers state if a pause command is missed.
  • Invert open/close β€” For installations where the motor direction is reversed.
  • Configurable logging levels β€” Error, Warning, Info, Debug, Trace.
Installation
  1. Go to Drivers Code in your Hubitat hub and click New Driver.
  2. Paste the driver code and click Save.
  3. Assign the driver to your device under Devices β†’ (your device) β†’ Type.
Setup
  1. Calibration β€” It is important not to set or clear any existing calibration on the device.
  2. Reset Position β€” When first using the driver, use the Reset Position command to set the shade's current actual position. This initializes the driver's internal state to match reality. No commands are sent to the device.
  3. Set open/close durations β€” Open and close the shade fully, measure the times (in milliseconds), and enter them in the preferences. Click Save Preferences.
  4. That's it for most users. The default motor delay values work well for typical setups. You can now use open/close/setPosition/stopPositionChange as usual, and the driver will estimate position based on your configured timings.
Advanced: Precise Timing Calibration
For very precise positioning (e.g., the semi-blind cell position):
  1. Record a video of the shade opening and closing.
  2. Use a subtitle tool or video analysis tool that shows precise frame timestamps (milliseconds).
  3. Motor start delay = time from when you hear the controller relay click until you see the shade actually start moving.
  4. Open/close time = time from when the shade starts moving until it reaches the fully open/closed position.
Preferences
Preference Default Description
Invert open/close false Swap open/close direction for reversed motor installations
Time to open 10000 ms Total time for the shade to go from fully closed to fully open
Time to close 10000 ms Total time for the shade to go from fully open to fully closed
Semi-blind position time 0 ms Time from closed to semi-blind position (triggered at 3%). Set to 0 to disable.
Motor start delay (open) -108 ms Delay compensation after the open command is sent
Motor start delay (close) 186 ms Delay compensation after the close command is sent
Open/Close safety margin 1000 ms Extra time added when targeting fully open or fully closed
Turbo Mode (Sonoff only) Disabled Increases Zigbee radio power for better range
Logging level Info Error / Warning / Info / Debug / Trace
Commands
Command Description
open() Opens the shade to 100%
close() Closes the shade to 0%
setPosition(pos) Moves the shade to the specified position (0–100%)
startPositionChange(direction) Starts moving up or down
stopPositionChange() Stops the shade
resetPosition(pos) Sets the driver's internal position state without sending any command to the device
How It Works
The driver sends standard Zigbee Window Covering cluster commands (open/close/stop) and estimates position by measuring elapsed movement time against the configured durations. When a stop command is needed (e.g., to reach 50%), the driver schedules a precisely-timed pause command.
Key implementation details:
  • Zigbee command delay compensation β€” The round-trip delay is measured and factored into pause timing.
  • Pre-pause scheduling β€” A two-stage scheduling approach (pre-pause β†’ pause) minimizes timing jitter.
  • Inverted movement β€” For positions ≀5%, the shade closes fully first, then opens to the target position, avoiding the inaccuracy of stopping very close to the limit.
Source Code
Some Related Discussions
