Thank you for the report, @Gradenko !
That's another Tuya platform oddity - your device has a newer firmware (application) version 53, and the manufacturer has changed the inClusters list compared to the previous version 52 ! : (
As there was no need to track the app. version of one and the same model and manufacture until now, there is no code to set the Mode parameter to tilt automatically for this device, it should be done manually for now.
The unexpected message is informative only, every device has some specific (and generally unknown) messages that probably only the manufacturer uses for specific needs.
The error log message is due to the fact that this device fingerprint was missing and most probably it was assigned another driver when first paired to HE (the Tuya Metering Plug maybe)?
I have added unscheduling of all periodic tasks that may have left potentially from other drivers, when you click on Save Preferences button again the error should not pop up anymore.
You can update the driver manually to the new dev, branch version 3.2.5
