@bcopeland
Sorry but I'm a little confused with the "Type in the URL for the firmware update file".
So I do not download the Firmware file to my PC, but instead copy the URL from the page were the Firmware file is list to download from?
Like for the Inovelli Red Dimmer, Firmware v1.41 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2).
I gave it a try, but it didn't work for me. Don't want to push my luck. lol
I first tried using the URL from Inovelli website as posted above, and then tried as you mentioned about using Google drive. But keep getting the same results each time.
I must be doing something wrong as I try to upgrade three of the LZW30 Switch and one of the LZW31 dimmer and I keep getting padding hex bytes on both the Switches and dimmer. I wait a few day and will try again? Thanks for the help.
I had the same issue with Dropbox. From the DB WEB interface, I requested a public URL to the file, and plugged that into the updater. Got the padding message for several tries.
Finally, used wget on the DB url, and compared it to a direct download of the image, and they did not match. I don't know what DB did to the file; I would have expected an exact bit-for-bit of the original.
I ended up putting it onto my local WEB server, and used that in the update driver.
Well, after about 1h 45m it transferred 100%. It now says it's flashing (and has for a few minutes). Should I do anything (refresh)?
If you're curious I have all the logs in a pastebin I can share. I turned on Debug for that run. One thing that might be helpful for the debug log is "packet number X out of Y". Was hard to tell how far along it was without flipping back and forth between log and device.
Not sure if Driver is supposed to come back at some point and say the device is done updating...
That is the last message you will get from the device.. It is probably already done.. There is no standard message they will send when they boot back up ..
