Thanks! I just threw the file up on my website and looks like it's working now. But yeah, that's good info for future reference! =)
Seems to have hung at 3%... =/ Might need to try this again when there's minimal other z-wave traffic. I think I've had instances where motion sensors interrupt z-wave network traffic (querying all the codes from a z-wave lock would hang if anyone moved in a room). =/
Oh... just increased to 5%... How long should an update take? Looks like the update file is 90K...
infofirmware total bytes: 90393
It is a pretty drastic change from device to device on how long.. It depends on many factors..
- Distance from hub
- Number of hops
- Legacy z-wave repeaters in route
- Z-Wave network activity - This is a big one as the firmware update process is designed to pause if it detects a good bit of traffic.. Because the firmware update packets are so big it tries to not totally monopolize the network time.
Fair. It's still progressing, and definitely pausing now and again. Up to 12%. lol. And it's about as far from the hub as possible. I don't have a recent map of the network... yeah, probably not a good number of hops.
Boo. Finally failed at 13%. Probably just too much other traffic. =/
dev:14412020-04-19 11:35:30.131 debuglocked by:
dev:14412020-04-19 11:35:30.110 warnThe device was unable to receive the requested firmware data
dev:14412020-04-19 11:35:18.032 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
Cannot resolve which method to invoke for [null] due to overlapping prototypes between:
[class java.lang.Character]
[class java.lang.Number] on line 148 (parse)
dev:14412020-04-19 11:35:06.033 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:54.061 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:42.111 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:30.004 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:23.932 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:23.725 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:22.118 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:18.675 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:18.407 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:18.235 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:18.145 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:18.138 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:34:06.033 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:33:54.072 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:33:44.720 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:33:43.953 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:33:42.224 errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method java.lang.Integer#multiply.
dev:14412020-04-19 11:33:32.663 debuglocked by:
dev:14412020-04-19 11:33:32.642 warnERROR. Device expected an authentication event to enable firmware update
dev:14412020-04-19 11:21:19.234 infoOK. The device will initiate the firmware update of the target specified in the Firmware Update Meta Data Request Get Command
dev:14412020-04-19 11:21:16.191 infocalculating crc...
dev:14412020-04-19 11:21:10.161 infogot otz compressed image reading compression header
dev:14412020-04-19 11:21:10.158 infofirmware total bytes: 90393
dev:14412020-04-19 11:21:10.155 infoSorted all the bytes. cleaning up some memory...
dev:14412020-04-19 11:20:28.451 infoVersionReport- applicationVersion:2.1
dev:14412020-04-19 11:20:28.448 infoVersionReport- zWaveProtocolVersion:5.3
dev:14412020-04-19 11:20:28.082 infoFirmwareUpdateMd version:4
I think I bricked a invelli red switch (gen 2). I started it last night and it got stuck at 26% and now the switch is unresponsive. Here is the log.
dev:1012020-04-19 08:09:46.024 am errorjava.lang.NullPointerException: Cannot invoke method split() on null object on line 427 (childOff)
dev:1012020-04-19 08:08:14.147 am debuglocked by:
dev:1012020-04-19 08:05:39.027 am infocalculating crc...
dev:1012020-04-19 08:05:38.479 am infogot otz compressed image reading compression header
dev:1012020-04-19 08:05:38.476 am infofirmware total bytes: 97555
dev:1012020-04-19 08:05:38.473 am infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-19 08:05:12.974 am infoVersionReport- applicationVersion:1.9
dev:1012020-04-19 08:05:12.966 am infoVersionReport- zWaveProtocolVersion:6.4
dev:1012020-04-19 08:05:11.923 am infoVersionReport- applicationVersion:1.9
dev:1012020-04-19 08:05:11.921 am infoVersionReport- zWaveProtocolVersion:6.4
dev:1012020-04-19 08:05:11.589 am infoVersionReport- applicationVersion:1.9
dev:1012020-04-19 08:05:11.573 am infoVersionReport- zWaveProtocolVersion:6.4
dev:1012020-04-19 08:05:11.550 am infoVersionReport- applicationVersion:1.9
dev:1012020-04-19 08:05:11.547 am infoVersionReport- zWaveProtocolVersion:6.4
dev:1012020-04-19 08:05:02.841 am infoFirmwareUpdateMd version:4
dev:1012020-04-19 08:04:58.150 am infoFirmwareUpdateMd version:4
dev:1012020-04-19 08:04:58.147 am infoFirmwareUpdateMd version:4
dev:1012020-04-19 08:04:41.517 am debuglocked by:
dev:1012020-04-19 08:04:37.335 am debuglocked by:
dev:1012020-04-18 11:20:40.413 pm infoOK. The device will initiate the firmware update of the target specified in the Firmware Update Meta Data Request Get Command
dev:1012020-04-18 11:20:34.499 pm infoOK. The device will initiate the firmware update of the target specified in the Firmware Update Meta Data Request Get Command
dev:1012020-04-18 11:20:33.911 pm infoOK. The device will initiate the firmware update of the target specified in the Firmware Update Meta Data Request Get Command
dev:1012020-04-18 11:20:26.197 pm infocalculating crc...
dev:1012020-04-18 11:20:25.896 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:25.893 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:25.890 pm infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-18 11:20:24.415 pm infocalculating crc...
dev:1012020-04-18 11:20:24.034 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:24.031 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:24.028 pm infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-18 11:20:21.922 pm errororg.apache.http.client.ClientProtocolException: null on line 374 (firmwareStore)
dev:1012020-04-18 11:20:20.952 pm infocalculating crc...
dev:1012020-04-18 11:20:20.186 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:20.180 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:20.175 pm infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-18 11:20:19.013 pm infocalculating crc...
dev:1012020-04-18 11:20:18.690 pm infocalculating crc...
dev:1012020-04-18 11:20:18.263 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:18.251 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:18.247 pm infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-18 11:20:17.248 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:17.245 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:17.241 pm infoSorted all the bytes. cleaning up some memory...
dev:1012020-04-18 11:20:16.662 pm errororg.apache.http.client.ClientProtocolException: null on line 374 (firmwareStore)
dev:1012020-04-18 11:20:14.586 pm infocalculating crc...
dev:1012020-04-18 11:20:11.882 pm infogot otz compressed image reading compression header
dev:1012020-04-18 11:20:11.875 pm infofirmware total bytes: 97555
dev:1012020-04-18 11:20:11.869 pm infoSorted all the bytes. cleaning up some memory...
That's a new one ..
Also this one is concerning:
Give me a few minutes to digest this ...
Wow.. Ok.. No you shouldn't have bricked it..
But it appears as though you had 2 processes running at the same time.. I have no idea how this happened.. did you rapidly double click on the UpdateFirmware button? ..
I have provisions to prevent this but if it happens too fast it may not catch it..
But when your device starts firmware updating it is in a different mode .. Since it didn't finish, rebooting the switch should make it work again.. Pull the air-gap tab and then re-insert it.
Good question - I don't think so. But what I did do was press the get version report
button - which took forever... so I decided to move ahead with the firmware update and pressed the update button.
I'm not sure what the air-gap tab is... let me google it. Thanks for the tip!
Once we get these kinks worked out, this is going to be such a great tool - thanks for working on it!
Hit abort on the updater, change the driver back to the inovelli driver, and hit the air gap. it'll come back to life.
Yay! I pulled the air-gap, and it's revived. Thanks!
I'm going to take another crack at the update
Ok @staze Did you click on anything else ? or try to update another device at the same time?..
I’ve run through my code and that value becoming null should only be possible with one of those 2 events
Nope. hit update, and kept a watch on the percent in the driver, and the logs...
make sure you follow the specific steps for the Inovellis:
Ok.. Researching some more..
So I think it's related to this : ERROR. Device expected an authentication event to enable firmware update..
Give me a few more minutes on this one..
Is this still the ZEN27?
Yup. Only device I currently have that needs a firmware update that I actually have. =) If it helps, I think there's at least one Zooz rep that frequents the forums...
Ok.. @staze can you try again.. I just researched the product and it shouldn't need authentication part.. But it sent it.. So I'm thinking maybe a physical button press happened or something to trigger it to abort..
No button press I could see (I'm looking in that general direction). Will give it another shot.
Let me know
