The presence and other related attributes being updated is the reason.
I think I found the problem, all my other zigbee devices had the "Enable Last Checkin Date" ON except for this one sensor, when I changed it the sensor stayed present.
Is the the presence attribute direct linked to the "Last Checkin Date"?
Hi @markus
I have a temp/humisity sensor that is working just fine.
The only thing is I keep seeing this in my logs.
dev:27552020-07-27 19:09:55.284 warnEvent interval INCORRECT, recovery mode (Normal) ACTIVE! If this is shown every hour for the same device and doesn't go away after three times, the device has probably fallen off and require a quick press of the reset button or possibly even re-pairing. It MAY also return within 24 hours, so patience MIGHT pay off.
dev:27552020-07-27 19:09:55.261 warnOne or several EXPECTED checkin events have been missed! Something MIGHT be wrong with the mesh for this device. Minutes since last checkin: 2 (maximum expected 1)
--- Live Log Started, waiting for events ---
When I look in the events for the device I can see that it is reporting in OK.
Not sure what to make of it.
Name | Value | Unit | Description Text | Source | Type | Date |
lastCheckin | 2020-07-27 19:07:34 | DEVICE | 2020-07-27 19:07:34.360 BST | |||
humidity | 64 | % | DEVICE | 2020-07-27 19:07:34.340 BST | ||
lastCheckin | 2020-07-27 19:07:34 | DEVICE | 2020-07-27 19:07:34.335 BST | |||
temperature | 3.4 | °C | DEVICE | 2020-07-27 19:07:34.322 BST | ||
lastCheckin | 2020-07-27 18:57:17 | DEVICE | 2020-07-27 18:57:17.483 BST | |||
lastCheckin | 2020-07-27 18:57:17 | DEVICE | 2020-07-27 18:57:17.479 BST | |||
lastCheckin | 2020-07-27 18:57:17 | DEVICE | 2020-07-27 18:57:17.474 BST | |||
humidity | 68 | % | DEVICE | 2020-07-27 18:57:17.446 BST | ||
lastCheckin | 2020-07-27 18:50:12 | DEVICE | 2020-07-27 18:50:12.391 BST | |||
lastCheckin | 2020-07-27 18:50:12 | DEVICE | 2020-07-27 18:50:12.358 BST |
@markus I’ve been testing this for a bit now but noticed these in the log:
dev:5452020-07-27 08:21:41.511 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BC4D01000012040042044C554D49, dni: BC4D, endpoint: 01, cluster: 0000, size: 12, attrId: 0004, encoding: 42, command: 01, value: 044C554D49 | msgMap:[raw:BC4D01000012040042044C554D49, dni:BC4D, endpoint:01, cluster:0000, size:12, attrId:0004, encoding:42, command:01, value:LUMI, clusterInt:0, attrInt:4]
dev:5452020-07-27 06:22:38.456 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BC4D01000012040042044C554D49, dni: BC4D, endpoint: 01, cluster: 0000, size: 12, attrId: 0004, encoding: 42, command: 01, value: 044C554D49 | msgMap:[raw:BC4D01000012040042044C554D49, dni:BC4D, endpoint:01, cluster:0000, size:12, attrId:0004, encoding:42, command:01, value:LUMI, clusterInt:0, attrInt:4]
dev:5452020-07-27 05:23:54.691 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BC4D01000012040042044C554D49, dni: BC4D, endpoint: 01, cluster: 0000, size: 12, attrId: 0004, encoding: 42, command: 01, value: 044C554D49 | msgMap:[raw:BC4D01000012040042044C554D49, dni:BC4D, endpoint:01, cluster:0000, size:12, attrId:0004, encoding:42, command:01, value:LUMI, clusterInt:0, attrInt:4]
Driver details:
- endpointId: 01
- application:
- driver: v0.8.2.0720b
- model: lumi.vibration.aq1
- manufacturer:
Current States
- acceleration : inactive
- activityLevel : 23
- battery : 100
- batteryLastReplaced : Jun 01 2020
- currentX : 88.3
- currentY : -0.9
- currentZ : 1.4
- driver : v0.8.2.0720b
- lastCheckin : 2020-07-27 22:13:15
- lastDropped : 2020-07-21 20:44:35
- lastStationary : 2020-07-21 20:45:47
- lastTilted : 2020-07-21 20:45:45
- lastVibration : 2020-07-17 08:34:31
- motion : inactive
- notPresentCounter : 0
- numberOfButtons : 1
- presence : present
- pushed : 1
- restoredCounter : 0
- sensitivityLevel : Low
- sensorState : stationary
- tiltAngle : 89
State Variables
- currentAngleZ : -88.2
- motionactive : 0
- comment : Works with model DJT11LM.
- prefsSetCount : 1
- currentAngleY : 0.6
- currentAngleX : -1.7
Any ideas?
Yes, either Last Checkin Date and/or Last Checkin Epoch needs to be enabled. These are the timestamps used to determine presence. The description of Enable Presence mentions this as a requirement for the feature to work.
It looks like you have entered Forced Recovery mode and not left it. Could have happened if you were on one Beta driver and switched to another with it running, there was a rename of some schedules recently. Take a screenshot of your scheduled events on that device (in case the issue is another one) and then run the "Force Recovery Mode" with minutes set to 0 and this should be sorted.
Thank you for reporting, there is no harm in these messages, but I've added a filter for them for the next release.
The device doesn't have on/off buttons in the settings page and this is in the log
No On/Off buttons? That sounds strange, they are there as long as the correct driver is selected. Please provide a screenshot.
Not sure if it's still helpful but here's the fingerprint
@mwboudro It helps. It does tell me that it doesn't seem to use any of the Aqara-specific clusters. Please try a new Beta driver I just uploaded here. After switching to this driver, run the Initialize command on the device page.
Actually this makes sense. I did use forced recovery mode mode but put in "1" as I just assumed it needed a figure. This ties in with the logs.
Did as you suggested and now it is OK.
Thanks for your help and of course, your fantastic apps/drivers.
I may have missed it but do you have a "donation" page?
I'm using your drivers exclusively when I can.
Thanks for offering Living in China I don't really have any good options for that. Paypal doesn't allow donation pages for China-based accounts. I don't know of any other services that do either. With that said I haven't really given it much thought until recently, it came up regarding a device and since it is very difficult to send devices here I did accept a payment through Paypal to cover me purchasing a specific device here in China. I'm doing this for fun and if someone wants a specific device implemented which I don't have that might be a good reason for a donation, if it can be purchased here in China that is. Not everything on AliExpress exists domestically. For these instances a payment to my Paypal can work even though I don't have a donation page.
Happy you like them! When I initially wrote them I wasn't so sure they would be liked since I don't conform to "HE standards".
On a different note: If someone has a Hue Bridge v2 they don't need and want to ship it to China (probably not possible/easy from USA) I'd be happy to receive it, what I find here seems to be some strange locked-down version without local API
Thanks @markus, I did that. Here's a snapshot of the device page. It looks as if it's initialized, but still no buttons to actually control the device.
You should have two child devices that have the on/off buttons.
Yep, that's it. Seems to be working, thanks for all your help.
Hello @markus. One of your 'creations" asked me to share a message with you
I think it's some kind of secret code language
dev:20902020-07-29 11:40:04.785 am infoCOPY AND PASTE THIS ROW TO THE DEVELOPER: fingerprint model:"TRADFRI signal repeater", manufacturer:"IKEA of Sweden", profileId:"0104", endpointId:"01", inClusters:"0000,0003,0009,0B05,1000,FC7C", outClusters:"0019,0020,1000", application:"20"
Thank you again for the tremendous work on these drivers, I love being able to know my tradfri & xbee repeaters are working, really helps with tracking down all my issues.
It's the device fingerprint, it's what is used to auto-select a driver on pairing. This fingerprint is different from all of my IKEA Repeaters in two locations, will add it to the driver, thank you
Always happy to hear my code is appreciated
My pleasure. So does my version have extra magic clusters?
@markus -- are you saying that the Xiaomi driver that is the subject of this thread also has support for the IKEA Tradfri repeaters? Or was that in reference to another driver? (I have some long awaited Tradfri repeaters arriving tomorrow.)
See this thread for @markus' Generic Zigbee Repeater driver.
NOTE: These are NOT the Official Hubitat Generic Zigbee drivers, these are my take on how to do Generic Zigbee devices, they all include a Presence feature some people have liked. More device types will be added when inspiration strikes and time permits. Supported Devices Generic Zigbee Device Toolbox (can generate fingerprints, remove child devices, clean the Data, Preferences and State Variables sections of the device.) - Import URL Generic Zigbee Repeater (works with IKEA Trådfri Repeater…
that's what I was missin' thanks!
Just wanted to thank you for enabling the use of these devices to Hubitat! Thanks!
and THIS is another "Markus Masterpiece"
Dam, this guy is a flippin genius
@markus Hi
I paired an Aqara leak sensor successfully today. The default driver Hubitat picked was the Orbital 12 Station Sprinkler. I have since changed the driver to your driver for the leak sensor. Now I am left with a lot of component devices for Orbital 12. What do I do with these?
