Thanks for developing this, I've had one of these sitting for a few years not bothering to use it since it was not compatible or so i thought.
Just curious what was the process you used to make this app. I got a wifi hot tub controller i have been trying to crack to make a driver for and i cannot make heads or tales out of the packets i pick up from it using wireshark. Do you have any tips?
Just lots of experience starting with other devices, and coming back to this one every once in a while. Epoch time threw me off the most with this one, but once I figured that out the rest just fell together.
You start by controlling what you can, and creating further tests that push the envelope slowly, but surely
In this case, I had one device and just started with turning on/off. Then I compared it with a second device. I looked for data that made sense, and pieced it together.
Hey All,
Been using this one on a few Different Wion devices the last few months. The things are a pain to get paired and on the Wifi at times, but after that have generally worked well.
Until.... Setting up Christmas lights .. I started using a 2 outlet, outdoor unit. as well as the larger staked unit with 3 outlet.
The 2 Outlet unit is connected and works.. but I am finding it is very 'sleepy' and seems to drop off .. thus missing the nightly automations either on or off.
If I go into the Device page and turn it on or off.. it doesn't respond on the cycle of the 2 commands, but will respond to the second. (Yes I am giving it time.. in between) So it seems the first is 'waking' it but not generating the response/action to turn on.
Any suggestions on how to get this guy to stay awake/on-line?
Let me know if their is more info I can provide to assist... Happy to test stuff for you if needed. (Im no good on to coding side unfortunately - but can follow directions)
