I am so sorry for not including the entire log above. I cropped the log above to exclude my personal information since it gets shown.
Here is the full log. I removed the password key, address and spoofed my name and number,
Thank you
dev:14142024-02-03 09:51:36.171 PMdebugupdated: Update process complete
dev:14142024-02-03 09:51:36.070 PMdebugupdated: Debug logging will be automatically disabled in 30 minutes
dev:14142024-02-03 09:51:36.069 PMdebugrefresh: Refresh process complete
dev:14142024-02-03 09:51:36.068 PMdebugrefresh: createChildACUnits() method skipped, we are working with the Kumo Cloud platform
dev:14142024-02-03 09:51:36.067 PMinfoA new authentication code value has been set
dev:14142024-02-03 09:51:36.066 PMdebugsetAuthCode: New authentication code value has been set
dev:14142024-02-03 09:51:34.370 PMdebugretrieveAuthCode_KumoCloud: Child - {"lastScheduleChange":0,"zoneTable":{},"children":[{"lastScheduleChange":0,"zoneTable":{"3834P008U100231F":{"serial":"3834P008U100231F","mac":"ec:5c:84:0c:73:36","label":"Living Room MS","port":80,"_isNew":true,"unitType":"ductless","reportedCondition":{"more":{"fan_speed_text":"Very High","air_direction_text":"Swing","power_on":false},"_created":1707024633690,"id":"2251950605473710","record_time":"2024-02-04T05:30:14.143Z","device_serial":"3834P008U100231F","it_status":null,"rssi":-32,"power":0,"operation_mode":16,"set_temp":null,"set_temp_a":null,"fan_speed":6,"air_direction":7,"prohibit_local_remote_control":null,"room_temp":27,"room_temp_beyond":null,"room_temp_a":null,"out_of_use":null,"unusual_figures":32768,"two_figures_code":"A0","status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false},"actual_fan_speed":null,"sp_cool":17.5,"sp_heat":16,"sp_auto":-1,"raw_frames":null,"run_test":0,"active_thermistor":null,"temp_source":null,"seconds_since_contact":20,"lastAdapterUpdated":"2024-02-04T05:30:33.690Z"},"desiredConditionStack":[],"lastUpdate":1707024639789,"_requestRescan":1,"_isRespondingLocally":null,"overrideSettings":{"dryMode":true,"heatMode":true},"forceCloudUpdates":true,"errorHandler":{"1":{"error2char":"A0","timestamp":0,"error4char":"8000","code":"8000","text":"8000"}},"equipmentControllerSettings":{},"eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"mhk2Settings":{"auto":{"owner":"none","status":"inactive","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"unset","outdoorAir":false,"outdoorAirBattery":"unset","indoorAir":false,"indoorAirBattery":"unset"},"dr":{"override":false,"event":"none"},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"adapter","enabled":"disabled"},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":60,"overcool":1.5,"offset":4,"active":false,"lastUpdated":1707024648674,"hasUpdated":true,"offsetShow":2},"kumoSensorSettings":{"battery":null,"humidity":null,"rssi":null,"temperature":null,"txPower":null,"uuid":null,"lastUpdated":"2024-02-04T05:23:54.762Z"},"systemChangeoverSettings":{"masterZone":{"serial":"3834P008U100231F","minRuntime":20,"maxStandby":180,"disable":"none","activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":{"inUse":true,"optimalStart":null,"day":"SuMoTuWeThFrSa","time":"0630","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":16,"spHeat":16,"vaneDir":"auto","fanSpeed":"auto","mode":"auto"}},"2":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"3":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"4":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"5":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"6":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"7":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"8":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"9":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"10":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"11":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"12":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"13":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"14":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"15":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"16":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"17":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"18":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"19":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"20":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"21":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"22":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"23":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"24":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"25":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"26":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"27":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"28":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":1706986862746,"holdChanged":0,"hasElectricHeatingOption":false,"rssi":{"rssi":-33,"string":"Very strong","image":"images/signal-verystrong-ondark-50x50.svg"},"ledDisabled":false,"cryptoSerial":"01236a589a8fb92bee","cryptoKeySet":"F","timezone":"America/Los_Angeles","lastAdapterUpdate":"2024-02-04 05:09:13.516225","firmwareVersion":"02.06.12","autoModeEnabled":true,"roomTempOffset":0,"password":"PASSGOESHERE","reportedInitialSettings":{"assigned_settings":{},"restart_after_outage":0,"vent_air":0,"voltage":0,"energy_save":0,"filter_alerts":0,"auto_fan":0,"pla_outlets":0,"filter_type":0,"frost_temp":0,"defrost":0,"oscillate":0,"heating_offset":0,"thermal_off1":0,"thermal_off2":0,"pressure1":0,"pressure2":0,"electric_heater1":0,"electric_heater2":0,"humidifier":0,"humidifier_modifier":0,"leftovers_settings":{"2":0,"6":0,"12":0,"14":0,"18":0,"19":0,"20":0,"21":0,"22":0,"26":0,"28":0,"29":0,"30":0,"31":0}},"reportedProfile":{"fan_speed_stages":5,"has_air_direction":true,"has_auto_fan_speed":true,"has_dry_function":true,"has_extended_temp_range":true,"has_heat_function":true,"has_swing_direction":true,"has_test_run":false,"has_unit_function_setting":false,"has_ventilation_function":true,"display_setting_temp_of_dry":false,"maximum_auto_temp":31,"maximum_cool_or_dry_temp":31,"maximum_heat_temp":31,"minimum_auto_temp":16,"minimum_cool_or_dry_temp":16,"minimum_heat_temp":10},"unconfigured":true,"sendDesiredConditionsPending":true,"sendDesiredConditionsTime":"2024-02-03T19:25:03.548Z","systemChangeoverEnabled":true,"minCoolSetpoint":16,"maxHeatSetpoint":31,"$$hashKey":"object:3013","autoDryModeCapable":2}},"children":[],"level":3,"label":"Most Mini Split","v1.2+":1,"id":"1706370304771-1536911875","lastUpdate":1706370401430,"isSystemChangeoverGroup":true,"$$hashKey":"object:2996"}],"level":2,"label":"Home","salesforceSiteId":"aDZPd000001601hOAA","v1.2+":1,"id":"1706370147036-2062001933","lastUpdate":1706370304771,"network":{"name":"Hypergalaxy","password":""},"program":{"events":[{"active":false,"time":"06:30:00","scopeZoneSerials":["3834P008U100231F"],"pattern":[true,true,true,true,true,true,true],"inUse":true,"event_id":null,"mapping":{"3834P008U100231F":"1"},"setting":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Auto","power_on":true},"_created":1707024640543,"spHeat":16,"spCool":16,"power":1,"operation_mode":33,"fan_speed":0,"air_direction":0}}],"deactivated":null},"$$hashKey":"object:7834"}
dev:14142024-02-03 09:51:34.366 PMdebugretrieveAuthCode_KumoCloud: New Auth Code - 96abd24660b06bb2dd81c1761b6c1bbc
dev:14142024-02-03 09:51:32.073 PMdebugretrieveAuthCode_KumoCloud: HTTP Response = [{"token":"96abd24660b06bb2dd81c1761b6c1bbc","username":"ktspambox@gmail.com","device":null,"emailIsVerified":true},{"lastUpdate":1706369727018},{"lastScheduleChange":0,"zoneTable":{},"children":[{"lastScheduleChange":0,"zoneTable":{},"children":[{"lastScheduleChange":0,"zoneTable":{"3834P008U100231F":{"serial":"3834P008U100231F","mac":"ec:5c:84:0c:73:36","label":"Living Room MS","port":80,"_isNew":true,"unitType":"ductless","reportedCondition":{"more":{"fan_speed_text":"Very High","air_direction_text":"Swing","power_on":false},"_created":1707024633690,"id":"2251950605473710","record_time":"2024-02-04T05:30:14.143Z","device_serial":"3834P008U100231F","it_status":null,"rssi":-32,"power":0,"operation_mode":16,"set_temp":null,"set_temp_a":null,"fan_speed":6,"air_direction":7,"prohibit_local_remote_control":null,"room_temp":27,"room_temp_beyond":null,"room_temp_a":null,"out_of_use":null,"unusual_figures":32768,"two_figures_code":"A0","status_display":{"filter":false,"defrost":false,"hot_adjust":false,"standby":false},"actual_fan_speed":null,"sp_cool":17.5,"sp_heat":16,"sp_auto":-1,"raw_frames":null,"run_test":0,"active_thermistor":null,"temp_source":null,"seconds_since_contact":20,"lastAdapterUpdated":"2024-02-04T05:30:33.690Z"},"desiredConditionStack":[],"lastUpdate":1707024639789,"_requestRescan":1,"_isRespondingLocally":null,"overrideSettings":{"dryMode":true,"heatMode":true},"forceCloudUpdates":true,"errorHandler":{"1":{"error2char":"A0","timestamp":0,"error4char":"8000","code":"8000","text":"8000"}},"equipmentControllerSettings":{},"eqcStageThreeBacksupChannels":{"1":0,"2":0,"3":0,"4":0},"eqcUpdatedLocally":{"1":false,"2":false,"3":false,"4":false},"mhk2Settings":{"auto":{"owner":"none","status":"inactive","heatSetpoint":null,"coolSetpoint":null},"connected":{"thermostat":false,"thermostatBattery":"unset","outdoorAir":false,"outdoorAirBattery":"unset","indoorAir":false,"indoorAirBattery":"unset"},"dr":{"override":false,"event":"none"},"hold":{"adapter":{"cancelMHK2":false,"endTime":0},"mhk2":{"cancelAdapter":false,"endTime":0}},"info":{"model":"","serial":"","firmware":""},"schedule":{"owner":"adapter","enabled":"disabled"},"status":{"outdoorTemp":0,"outdoorHumid":null,"indoorHumid":null}},"acoilSettings":{"isAcoil":false,"inputs":{"humidistat":false,"ervSwitch":false,"floatSwitchWet":false},"outputs":{"w1":false,"w2":false,"y":false,"g":false,"erv":false,"humidifer":false,"heartbeat":false},"humidifier":{"targetPcr":0,"source":null,"enable":false},"erv":{"mode":"classic"},"ytoo":{"fan":false,"humidifier":false,"erv":false},"cbp":0,"oat":0,"bpcr":"off","ebp":false,"fDelay":0},"autoDrySettings":{"isAutoDry":true,"enable":false,"targetHumid":60,"overcool":1.5,"offset":4,"active":false,"lastUpdated":1707024648674,"hasUpdated":true,"offsetShow":2},"kumoSensorSettings":{"battery":null,"humidity":null,"rssi":null,"temperature":null,"txPower":null,"uuid":null,"lastUpdated":"2024-02-04T05:23:54.762Z"},"systemChangeoverSettings":{"masterZone":{"serial":"3834P008U100231F","minRuntime":20,"maxStandby":180,"disable":"none","activeMode":null,"durActive":null,"durInactive":null},"priority":1},"programEventSettings":{"1":{"inUse":true,"optimalStart":null,"day":"SuMoTuWeThFrSa","time":"0630","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":16,"spHeat":16,"vaneDir":"auto","fanSpeed":"auto","mode":"auto"}},"2":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"3":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"4":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"5":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"6":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"7":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:45.486863","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"8":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"9":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"10":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"11":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"12":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"13":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"14":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.156947","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"15":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"16":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"17":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"18":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"19":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"20":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"21":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:46.818781","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"22":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"23":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"24":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"25":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"26":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"27":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}},"28":{"inUse":false,"optimalStart":null,"day":"","time":"0000","active":false,"lastUpdated":"2024-02-03 19:01:47.501082","settings":{"spCool":null,"spHeat":null,"vaneDir":"auto","fanSpeed":"auto","mode":"heat"}}},"prohibits":{"global":{"power":false,"mode":false,"setpoint":false},"local":{"power":false,"mode":false,"setpoint":false},"effective":{"power":false,"mode":false,"setpoint":false}},"prohibitsChanged":1706986862746,"holdChanged":0,"hasElectricHeatingOption":false,"rssi":{"rssi":-33,"string":"Very strong","image":"images/signal-verystrong-ondark-50x50.svg"},"ledDisabled":false,"cryptoSerial":"01236a589a8fb92bee","cryptoKeySet":"F","timezone":"America/Los_Angeles","lastAdapterUpdate":"2024-02-04 05:09:13.516225","firmwareVersion":"02.06.12","autoModeEnabled":true,"roomTempOffset":0,"password":" PASSGOESHERE ","reportedInitialSettings":{"assigned_settings":{},"restart_after_outage":0,"vent_air":0,"voltage":0,"energy_save":0,"filter_alerts":0,"auto_fan":0,"pla_outlets":0,"filter_type":0,"frost_temp":0,"defrost":0,"oscillate":0,"heating_offset":0,"thermal_off1":0,"thermal_off2":0,"pressure1":0,"pressure2":0,"electric_heater1":0,"electric_heater2":0,"humidifier":0,"humidifier_modifier":0,"leftovers_settings":{"2":0,"6":0,"12":0,"14":0,"18":0,"19":0,"20":0,"21":0,"22":0,"26":0,"28":0,"29":0,"30":0,"31":0}},"reportedProfile":{"fan_speed_stages":5,"has_air_direction":true,"has_auto_fan_speed":true,"has_dry_function":true,"has_extended_temp_range":true,"has_heat_function":true,"has_swing_direction":true,"has_test_run":false,"has_unit_function_setting":false,"has_ventilation_function":true,"display_setting_temp_of_dry":false,"maximum_auto_temp":31,"maximum_cool_or_dry_temp":31,"maximum_heat_temp":31,"minimum_auto_temp":16,"minimum_cool_or_dry_temp":16,"minimum_heat_temp":10},"unconfigured":true,"sendDesiredConditionsPending":true,"sendDesiredConditionsTime":"2024-02-03T19:25:03.548Z","systemChangeoverEnabled":true,"minCoolSetpoint":16,"maxHeatSetpoint":31,"$$hashKey":"object:3013","autoDryModeCapable":2}},"children":[],"level":3,"label":"Most Mini Split","v1.2+":1,"id":"1706370304771-1536911875","lastUpdate":1706370401430,"isSystemChangeoverGroup":true,"$$hashKey":"object:2996"}],"level":2,"label":"Home","salesforceSiteId":"aDZPd000001601hOAA","v1.2+":1,"id":"1706370147036-2062001933","lastUpdate":1706370304771,"network":{"name":"Hypergalaxy","password":""},"program":{"events":[{"active":false,"time":"06:30:00","scopeZoneSerials":["3834P008U100231F"],"pattern":[true,true,true,true,true,true,true],"inUse":true,"event_id":null,"mapping":{"3834P008U100231F":"1"},"setting":{"more":{"operation_mode_text":"Cool","fan_speed_text":"Auto","air_direction_text":"Auto","power_on":true},"_created":1707024640543,"spHeat":16,"spCool":16,"power":1,"operation_mode":33,"fan_speed":0,"air_direction":0}}],"deactivated":null},"$$hashKey":"object:7834"}],"lastUpdate":1707112289322,"level":1,"v1.2+":1,"id":"1706369727021-4061226643","label":"Home","version":136},"no device token",{"userDetails":{"firstName":"Bond","lastName":"kt","phone":"2099999996","email":"ktspambox@gmail.com","IsPersonAccount":true},"siteDetails":[{"aDZPd000001601hOAA":{"address":"ADDRESS REDACTED","address2":null,"city":"ADDRESS REDACTED","state":"CA","zip":"ADDRESS REDACTED","country":"United States","contractor":null}}]}]
dev:14142024-02-03 09:51:30.363 PMdebugsetAuthCode: method called, Platform = KumoCloud
dev:14142024-02-03 09:51:30.362 PMdebugrefresh: Refresh process called
dev:14142024-02-03 09:51:30.360 PMdebugsetBaseURL: Platform provided = KumoCloud, alternateURL = null
dev:14142024-02-03 09:51:30.358 PMdebugupdated: Update process called
