Thanks Amit, appreciate your help.
It's a bit awkward way, but could work. I think that use of 'on1' command instead of 'all10000000' would be even better.
Solved my problem by changing child device capability to 'Switch' ('RelaySwitch' was probably removed at some point).
BTW (just in case somebody runs into this issue) Delay relay setting of '1' gives 10sec. delay, '2' - 20sec. etc. Definetly a bug in the board FW (at least in mine) - from what I see the driver sends a correct command.
I am glad to see you enjoying the driver, please let me know if you need anything changed.
I do not update my hubitat often, it just works like a breeze so I just leave it be.
When I do I come back to developing, I check all the threads of drivers I shared and will reply/attend to requests when needed. It is easier to reach me by raising issues at github if you find any.
