Hi James,
This device is currently not supported by this driver. It seems to be an independently controlled relay with an external temperature sensor, not a standard Tuya thermostat.
You can try using this custom fork of another Tuya driver :
If you get the temperature sensor working and are able to control the relay, you can use the Hubitat Rule Machine to create your own thermostat control rule.
Due to my commitment to an important private project, I will not be able to actively participate in this forum from the beginning of April until the end of September this year. Once I return, I will review the available requests for adding new devices to the existing custom Tuya drivers. Thank you for your understanding and patience!
