It's working for my TS0601 _TZE200_9qayzqa8 again. It's a 10 GHz radar presence sensor that is DC only.
The only thing I see now is the LINPTECH 24Ghz lost fading time under 10 sec with both versions of 1.6.2. I've edited it back in for the meantime. All other sensors of mine appear to be working as expected settings-wise and function-wise. Amazing work by you as always!
The Linptech radar doesn't fit into the common processing code flow that I am trying to complete... I am still working on it, will let you know when ready for testing.
Hi @user5693_ABu ,
Your device seems to be not the old ZY- M100, but a newer 24Ghz version of the radar...
I don't know if someone else has used it with this driver so far. You must update the driver to the latest development branch version - please use the link on the second post, or from within the HE driver editor click on the "Import" button. You must use version 1.6.2 of the driver or newer.
After updating the driver click on the Initialize button and then press the F5 key in the PC browser to refresh the page - the configuration parameters should show up.
OK, thank you. I will be going out now, but your tomorrow morning, there should be a new version with some fixes, I will ping you when ready to update it and test again.
Yes, the sensitivity parameter of the 24GHz model is a float value in the range of 1.0 to 10.0, so it must be divided by 10 in the code. In the current version, if you set it to 57, it will be actually 5.7
You can experiment changing the code yourself now ..
Change the Device Profile for TS0601_IJXVKHD0_RADAR this way :
You will need to click on Initialize button after saving the new code, there is still a problem when an existing preference type is changed from 'number' to 'decimal' and vice versa ...
The attribute functions are really a neat thing. The radar sensor used for the Linptech is criticized by some as being really inaccurate with regard to distance readings. I put it to the test against my FP1 using the attribute reading of distance on my dashboard. It fluctuates a little as each sensor reads the people moving around the room slightly differently, but I was amazed at how much they agreed with each other. I will have to test my other sensors now out of curiosity starting with my TS0601_IJXVKHD0. Thanks, kkossev for bringing it up as I learned something neat and new today!
Hi, do you know where I can read to have a little more in-depth understanding with regard to i.e. what Lux threshold, delay fading time, illuminance correction are meant for, how to set it right. Thanks for your response
Hello and thank you for all your efforts in creating these drivers. I purchased one WZ-M100, when I am using your 4 in 1 driver , it gives 500 Server Error, there is no logs or anything. Any ideas on where to start troubleshooting this ?
@memiautomation make sure you have your HE hub updated to the latest platform version.
This error 500 was fixed in HE version 2.3.6.144
You have a new device model/manufacturer whose fingerprint is currently not in the driver.
Enable the 'Advanced Options' and hit Save. Then, manually select Device Profile "Tuya Human Presence Detector SXM7L9XA".
Thank you for the reply. It dosen't get there, when adding, it picks up Zemismart blind and when I try to change it, it generates the Server Error 500, so I never get to the advanced options.
I am on C8 and using the latest firmware. I actually added the fingerprint just below line 632:
[profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,EF00", outClusters:"0019,000A", model:"TS0601", manufacturer:"_TZE204_e5m9c5hl", deviceJoinName: "Tuya Human Presence Detector"]
But it didn't help. The driver is downloaded from HPM , just today. Thank you
