It's the same product, but the logs are very different.
This is normal.
Summary
dev:51512022-09-25 02:32:19.050 aminfo여과기모터용P 20A energy is 142.58 kWh, energyCost=$13.31 (rate=$0.12), duration=13.54 Days
dev:51512022-09-25 02:32:00.154 aminfo여과기모터용P 20A power is 364 W
dev:51512022-09-25 02:31:04.146 aminfo여과기모터용P 20A power is 363 W
dev:51512022-09-25 02:31:00.343 aminfo여과기모터용P 20A amperage is 2.08 A
dev:51512022-09-25 02:31:00.160 aminfo여과기모터용P 20A voltage is 224 V
dev:51512022-09-25 02:30:45.142 aminfo여과기모터용P 20A voltage is 220 V
dev:51512022-09-25 02:30:40.902 aminfo여과기모터용P 20A energy is 142.57 kWh, energyCost=$13.31 (rate=$0.12), duration=13.54 Days
dev:51512022-09-25 02:30:13.143 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:30:00.159 aminfo여과기모터용P 20A power is 364 W
dev:51512022-09-25 02:29:22.135 aminfo여과기모터용P 20A power is 365 W
dev:51512022-09-25 02:29:02.848 aminfo여과기모터용P 20A energy is 142.56 kWh, energyCost=$13.31 (rate=$0.12), duration=13.54 Days
dev:51512022-09-25 02:29:00.253 aminfo여과기모터용P 20A voltage is 225 V
dev:51512022-09-25 02:29:00.195 aminfo여과기모터용P 20A power is 364 W
dev:51512022-09-25 02:28:18.158 aminfo여과기모터용P 20A voltage is 224 V
dev:51512022-09-25 02:28:09.118 aminfo여과기모터용P 20A power is 363 W
dev:51512022-09-25 02:28:00.156 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:27:22.903 aminfo여과기모터용P 20A energy is 142.55 kWh, energyCost=$13.31 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:26:00.319 aminfo여과기모터용P 20A amperage is 2.044 A
dev:51512022-09-25 02:26:00.212 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:26:00.167 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:25:47.095 aminfo여과기모터용P 20A voltage is 217 V
dev:51512022-09-25 02:25:45.141 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:25:45.097 aminfo여과기모터용P 20A power is 0 W
dev:51512022-09-25 02:25:43.340 aminfo여과기모터용P 20A energy is 142.54 kWh, energyCost=$13.31 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:25:00.162 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:24:03.390 aminfo여과기모터용P 20A energy is 142.53 kWh, energyCost=$13.31 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:24:00.197 aminfo여과기모터용P 20A voltage is 221 V
dev:51512022-09-25 02:24:00.155 aminfo여과기모터용P 20A power is 359 W
dev:51512022-09-25 02:23:00.160 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:22:28.063 aminfo여과기모터용P 20A voltage is 218 V
dev:51512022-09-25 02:22:23.866 aminfo여과기모터용P 20A energy is 142.52 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:22:18.066 aminfo여과기모터용P 20A power is 360 W
dev:51512022-09-25 02:22:00.406 aminfo여과기모터용P 20A amperage is 2.044 A
dev:51512022-09-25 02:22:00.315 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:22:00.207 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:21:18.117 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:21:18.070 aminfo여과기모터용P 20A power is 0 W
dev:51512022-09-25 02:21:00.351 aminfo여과기모터용P 20A voltage is 221 V
dev:51512022-09-25 02:21:00.176 aminfo여과기모터용P 20A power is 360 W
dev:51512022-09-25 02:20:43.833 aminfo여과기모터용P 20A energy is 142.51 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:20:00.191 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:19:55.048 aminfo여과기모터용P 20A power is 359 W
dev:51512022-09-25 02:19:08.033 aminfo여과기모터용P 20A voltage is 218 V
dev:51512022-09-25 02:19:04.298 aminfo여과기모터용P 20A energy is 142.5 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:19:00.168 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:18:48.028 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:18:00.298 aminfo여과기모터용P 20A voltage is 221 V
dev:51512022-09-25 02:17:49.027 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:17:48.022 aminfo여과기모터용P 20A power is 359 W
dev:51512022-09-25 02:17:22.790 aminfo여과기모터용P 20A energy is 142.49 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:17:00.349 aminfo여과기모터용P 20A amperage is 2.08 A
dev:51512022-09-25 02:17:00.201 aminfo여과기모터용P 20A power is 364 W
dev:51512022-09-25 02:16:49.017 aminfo여과기모터용P 20A voltage is 224 V
dev:51512022-09-25 02:16:48.078 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:16:48.019 aminfo여과기모터용P 20A power is 0 W
dev:51512022-09-25 02:16:00.602 aminfo여과기모터용P 20A voltage is 225 V
dev:51512022-09-25 02:16:00.483 aminfo여과기모터용P 20A power is 365 W
dev:51512022-09-25 02:15:49.011 aminfo여과기모터용P 20A voltage is 220 V
dev:51512022-09-25 02:15:45.004 aminfo여과기모터용P 20A power is 363 W
dev:51512022-09-25 02:15:44.843 aminfo여과기모터용P 20A energy is 142.48 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:15:00.188 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:14:25.001 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:14:19.990 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:14:04.819 aminfo여과기모터용P 20A energy is 142.47 kWh, energyCost=$13.3 (rate=$0.12), duration=13.53 Days
dev:51512022-09-25 02:14:00.234 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:13:19.990 aminfo여과기모터용P 20A power is 363 W
dev:51512022-09-25 02:13:00.198 aminfo여과기모터용P 20A amperage is 2.058 A
dev:51512022-09-25 02:13:00.162 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:12:25.247 aminfo여과기모터용P 20A energy is 142.46 kWh, energyCost=$13.3 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:12:20.016 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:12:19.973 aminfo여과기모터용P 20A power is 0 W
dev:51512022-09-25 02:12:00.356 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:12:00.155 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:11:50.961 aminfo여과기모터용P 20A voltage is 224 V
dev:51512022-09-25 02:11:00.231 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:11:00.146 aminfo여과기모터용P 20A power is 363 W
dev:51512022-09-25 02:10:50.960 aminfo여과기모터용P 20A voltage is 219 V
dev:51512022-09-25 02:10:47.249 aminfo여과기모터용P 20A energy is 142.45 kWh, energyCost=$13.3 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:10:00.162 aminfo여과기모터용P 20A voltage is 224 V
dev:51512022-09-25 02:09:07.258 aminfo여과기모터용P 20A energy is 142.44 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:09:02.938 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:09:00.149 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:08:00.248 aminfo여과기모터용P 20A amperage is 2.051 A
dev:51512022-09-25 02:08:00.199 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:08:00.167 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:07:52.931 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:07:34.926 aminfo여과기모터용P 20A power is 360 W
dev:51512022-09-25 02:07:31.925 aminfo여과기모터용P 20A voltage is 218 V
dev:51512022-09-25 02:07:27.706 aminfo여과기모터용P 20A energy is 142.43 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:07:00.187 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:06:00.344 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:06:00.318 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:05:47.718 aminfo여과기모터용P 20A energy is 142.42 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:05:11.914 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:05:00.161 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:04:47.906 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:04:11.890 aminfo여과기모터용P 20A voltage is 217 V
dev:51512022-09-25 02:04:08.214 aminfo여과기모터용P 20A energy is 142.41 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:04:00.185 aminfo여과기모터용P 20A amperage is 2.051 A
dev:51512022-09-25 02:04:00.146 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:03:47.888 aminfo여과기모터용P 20A power is 360 W
dev:51512022-09-25 02:03:22.894 aminfo여과기모터용P 20A amperage is 0 A
dev:51512022-09-25 02:03:00.190 aminfo여과기모터용P 20A voltage is 222 V
dev:51512022-09-25 02:03:00.150 aminfo여과기모터용P 20A power is 361 W
dev:51512022-09-25 02:02:30.177 aminfo여과기모터용P 20A energy is 142.4 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:02:24.874 aminfo여과기모터용P 20A power is 362 W
dev:51512022-09-25 02:01:58.872 aminfo여과기모터용P 20A voltage is 223 V
dev:51512022-09-25 02:01:00.333 aminfo여과기모터용P 20A amperage is 2.08 A
dev:51512022-09-25 02:01:00.304 aminfo여과기모터용P 20A power is 364 W
dev:51512022-09-25 02:00:54.860 aminfo여과기모터용P 20A amperage is 1.862 A
dev:51512022-09-25 02:00:50.337 aminfo여과기모터용P 20A energy is 142.39 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
dev:51512022-09-25 02:00:00.213 aminfo여과기모터용P 20A power is 365 W
dev:51512022-09-25 02:00:00.028 aminfo여과기모터용P 20A hourlyEnergy is 0.36 kWh
dev:51512022-09-25 01:59:10.655 aminfo여과기모터용P 20A energy is 142.38 kWh, energyCost=$13.29 (rate=$0.12), duration=13.52 Days
[/details]
