Ooo ok..
fingerprint profileId:"0104", endpointId:"01", inClusters:"0004,0005,EF00,0000", outClusters:"0019,000A", model:"TS0601", manufacturer:"_TZE200_whkgqxse"
Ooo ok..
Temperature is detecting perfectly.. no humidity..
Please update the driver to the latest dev. branch version 1.0.11, timeStamp 2022/11/09 7:26 AM - the link is in the second post on this thread.
After updating the driver, DELETE the device from the web page and pair it again. This driver should be automatically selected now during the Zigbee pairing process.
If the humidity is not shown again, enable the debug logs, rapidly change the humidity near the device and copy/paste the debug logs near the time of the humidity change.
Thankyou for the quick reply..
No no luck..
there's a warning in the log...
dev:10392022-11-09 04:04:25.608 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:463701000068040042105F545A453230305F77686B67717873650000002003010000204805000042065453303630310700003003FEFF003000, dni:4637, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_whkgqxse, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
There is nothing received from the device... You can ignore this warning, it is not important.
Do you pair the sensor close to the HE hub? Pair it again, but in close proximity - no more than 1 meter from the hub.
Yes, please send me the complete log.
You can enclose it in a ‘Summary’ section ( use the cog wheel tool in the forum editor) or send the long logs to me in a private message.
dev:10432022-11-09 04:39:11.721 PMinfoHumidity temperature is 25.0 °C (delayed)
dev:10432022-11-09 04:39:07.803 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10432022-11-09 04:39:07.801 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10432022-11-09 04:39:07.796 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 021A0C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 1A, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10432022-11-09 04:39:07.685 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock DELAYING 4 seconds event : [name:temperature, unit:°C, value:25, type:delayed, isStateChange:true, descriptionText:temperature is 25.0 °C]
dev:10432022-11-09 04:39:07.682 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=250
dev:10432022-11-09 04:39:07.676 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 021901020004000000FA020200040000003904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 19, 01, 02, 00, 04, 00, 00, 00, FA, 02, 02, 00, 04, 00, 00, 00, 39, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10432022-11-09 04:39:05.824 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10432022-11-09 04:39:05.823 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10432022-11-09 04:39:05.818 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02180C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 18, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10432022-11-09 04:39:05.801 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Received endpoint response: cluster: 8005 (endpoint response) endpointCount = 01 endpointList = 01
dev:10432022-11-09 04:39:05.792 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0000 8005 00 00 0040 00 DC2B 00 00 0000 00 00 B3002BDC0101, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:DC2B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[B3, 00, 2B, DC, 01, 01]]
dev:10432022-11-09 04:39:05.688 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock DELAYING 6 seconds event : [name:temperature, unit:°C, value:24.8, type:delayed, isStateChange:true, descriptionText:temperature is 24.9 °C]
dev:10432022-11-09 04:39:05.685 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=249
dev:10432022-11-09 04:39:05.679 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 021701020004000000F9020200040000003904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 17, 01, 02, 00, 04, 00, 00, 00, F9, 02, 02, 00, 04, 00, 00, 00, 39, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10432022-11-09 04:39:04.298 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DC2B01000030DFFF42140600FE2A132200FE2A652300FE2A126A00FE2A65, dni:DC2B, endpoint:01, cluster:0000, size:30, attrId:FFDF, encoding:42, command:0A, value:þ"þe#þjþe, clusterInt:0, attrInt:65503]
dev:10432022-11-09 04:39:04.295 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DC2B01000030DFFF42140600FE2A132200FE2A652300FE2A126A00FE2A65, dni:DC2B, endpoint:01, cluster:0000, size:30, attrId:FFDF, encoding:42, command:0A, value:þ"þe#þjþe, clusterInt:0, attrInt:65503]
dev:10432022-11-09 04:39:04.054 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DC2B0100001801002048E2FF2038E4FF2000, dni:DC2B, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:10432022-11-09 04:39:04.049 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DC2B0100001801002048E2FF2038E4FF2000, dni:DC2B, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:10432022-11-09 04:39:03.924 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 11 01 016040, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[01, 60, 40]]
dev:10432022-11-09 04:39:03.814 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10432022-11-09 04:39:03.812 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10432022-11-09 04:39:03.807 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02160C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 16, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10432022-11-09 04:39:03.693 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock DELAYING 8 seconds event : [name:temperature, unit:°C, value:24.8, type:delayed, isStateChange:true, descriptionText:temperature is 24.9 °C]
dev:10432022-11-09 04:39:03.690 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=249
dev:10432022-11-09 04:39:03.684 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 021501020004000000F9020200040000003904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 15, 01, 02, 00, 04, 00, 00, 00, F9, 02, 02, 00, 04, 00, 00, 00, 39, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10432022-11-09 04:39:03.200 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Humidity Alarm (0x0F=2) is inactive
dev:10432022-11-09 04:39:03.199 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=2
dev:10432022-11-09 04:39:03.195 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02140F04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 14, 0F, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:03.081 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10432022-11-09 04:39:03.079 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10432022-11-09 04:39:03.075 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02130E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 13, 0E, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:02.960 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock reported temperature alarm lower limit 0.0 C
dev:10432022-11-09 04:39:02.958 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=11 fncmd=0
dev:10432022-11-09 04:39:02.954 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02120B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 12, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10432022-11-09 04:39:02.836 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Humidity Alarm (0x0F=2) is inactive
dev:10432022-11-09 04:39:02.835 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=2
dev:10432022-11-09 04:39:02.831 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02110F04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 11, 0F, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:02.717 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10432022-11-09 04:39:02.715 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10432022-11-09 04:39:02.711 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02100E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 10, 0E, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:02.597 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock reported temperature alarm upper limit 39.0 C
dev:10432022-11-09 04:39:02.594 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=10 fncmd=390
dev:10432022-11-09 04:39:02.590 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020F0A02000400000186, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0F, 0A, 02, 00, 04, 00, 00, 01, 86]]
dev:10432022-11-09 04:39:02.469 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Humidity Alarm (0x0F=2) is inactive
dev:10432022-11-09 04:39:02.468 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=2
dev:10432022-11-09 04:39:02.464 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020E0F04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0E, 0F, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:02.346 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10432022-11-09 04:39:02.344 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10432022-11-09 04:39:02.340 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020D0E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0D, 0E, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:02.223 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Temperature scale reported by device is: Celsius
dev:10432022-11-09 04:39:02.222 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=9 fncmd=0
dev:10432022-11-09 04:39:02.218 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0C, 09, 04, 00, 01, 00]]
dev:10432022-11-09 04:39:02.101 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Humidity Alarm (0x0F=2) is inactive
dev:10432022-11-09 04:39:02.099 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=2
dev:10432022-11-09 04:39:02.095 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020B0F04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0B, 0F, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:01.989 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10432022-11-09 04:39:01.986 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10432022-11-09 04:39:01.977 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10432022-11-09 04:39:01.975 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10432022-11-09 04:39:01.971 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020A0E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 0A, 0E, 04, 00, 01, 02]]
dev:10432022-11-09 04:39:01.881 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10432022-11-09 04:39:01.879 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10432022-11-09 04:39:01.851 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 02090C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 09, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10432022-11-09 04:39:01.841 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10432022-11-09 04:39:01.837 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10432022-11-09 04:39:01.827 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10432022-11-09 04:39:01.823 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10432022-11-09 04:39:01.812 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10432022-11-09 04:39:01.808 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10432022-11-09 04:39:01.695 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock temperature is 24.9 °C
dev:10432022-11-09 04:39:01.692 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=249
dev:10432022-11-09 04:39:01.686 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DC2B 01 00 0000 02 01 020801020004000000F9020200040000003904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DC2B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[02, 08, 01, 02, 00, 04, 00, 00, 00, F9, 02, 02, 00, 04, 00, 00, 00, 39, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10432022-11-09 04:39:01.246 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he cmd 0xDC2B 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200, he cmd 0xDC2B 0x01 0xEF00 0x00 {00020904000100} {}, delay 200, he cmd 0xDC2B 0x01 0xEF00 0x00 {00030A02000400000186} {}, delay 200, he cmd 0xDC2B 0x01 0xEF00 0x00 {00040B02000400000000} {}, delay 200])
dev:10432022-11-09 04:39:01.244 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Update finished
dev:10432022-11-09 04:39:01.242 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0xDC2B 0x01 0xEF00 0x00 {00040B02000400000000} {}, delay 200]
dev:10432022-11-09 04:39:01.239 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting minTempAlarm to 0.0 C
dev:10432022-11-09 04:39:01.237 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0xDC2B 0x01 0xEF00 0x00 {00030A02000400000186} {}, delay 200]
dev:10432022-11-09 04:39:01.234 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting maxTempAlarm to 39.0 C
dev:10432022-11-09 04:39:01.232 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting temperature scale to Celsius: [he cmd 0xDC2B 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200, he cmd 0xDC2B 0x01 0xEF00 0x00 {00020904000100} {}, delay 200]
dev:10432022-11-09 04:39:01.230 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0xDC2B 0x01 0xEF00 0x00 {00020904000100} {}, delay 200]
dev:10432022-11-09 04:39:01.225 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0xDC2B 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200]
dev:10432022-11-09 04:39:01.221 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting temperatureSensitivity to 0.5 C
dev:10432022-11-09 04:39:01.219 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is will be turned off after 24 hours
dev:10432022-11-09 04:39:01.193 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is true; Description text logging is true
dev:10432022-11-09 04:39:01.191 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Updating null (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE200_whkgqxse modelGroupPreference = Auto detect (TS0601_Tuya)
dev:10432022-11-09 04:39:00.295 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DC2B01000068040042105F545A453230305F77686B67717873650000002003010000204805000042065453303630310700003003FEFF003000, dni:DC2B, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_whkgqxse, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:10432022-11-09 04:39:00.287 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DC2B01000068040042105F545A453230305F77686B67717873650000002003010000204805000042065453303630310700003003FEFF003000, dni:DC2B, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_whkgqxse, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:10432022-11-09 04:39:00.159 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he raw 0xDC2B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200])
dev:10432022-11-09 04:39:00.155 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock configure()..
dev:10432022-11-09 04:39:00.065 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock InitializeVars()... fullInit = true
dev:10432022-11-09 04:39:00.057 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock installed()...
EDITED: I have been looking at the wrong logs, actually there are no humidity log records.
If you click on the Events button, do you see humidity events there?
That's wierd.. Please enable the 'Advanced Options' switch in the Preferences section and make a screenshot of what is shown there after you click on the Save button.
You can try changing the 'Humidity sensitivity' parameter from 5% to 1% ...
When testing, did you change the humidity to say 60% ... 70% ( by breathing very close to the sensor) ?
Mmm Yes tried that and I stuck it in the fridge for a couple of minutes got it down to 38% but still nothing..
OK, will continue tomorrow, now have to go to my work... Should be able to find a solution.
Thankyou very much for trying..
All the best have a great day..
CHris
Definitely there is nothing in the logs that may be a humidity reporting… you can try to reset the device, remove the batteries for 2-3 minutes and install them again. Will the device join the HE hub automatically again? Anything in the logs related to humidity?
dev:10472022-11-10 03:38:32.745 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:32.744 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:32.739 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00710C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 71, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:32.651 PMdebugBedroom Sensor DELAYING 8 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:32.621 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:32.616 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00700102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 70, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:30.748 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:30.746 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:30.742 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006F0C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6F, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:30.669 PMdebugBedroom Sensor DELAYING 10 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:30.666 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:30.661 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006E0102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6E, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:30.310 PMinfoBedroom Sensor temperature is 26.1 °C (delayed)
dev:10472022-11-10 03:38:29.406 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:29.405 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:29.401 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006D0C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6D, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:29.287 PMdebugBedroom Sensor DELAYING 1 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:29.284 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:29.279 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006C0102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6C, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:29.161 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:29.160 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:29.155 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006B0C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6B, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:29.037 PMdebugBedroom Sensor DELAYING 1 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:29.034 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:29.029 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 006A0102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6A, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:28.911 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:28.910 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:28.906 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00690C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 69, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:28.790 PMdebugBedroom Sensor DELAYING 2 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:28.788 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:28.783 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00680102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 68, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:28.662 PMinfoBedroom Sensor humidity alarm upper limit is 70
dev:10472022-11-10 03:38:28.661 PMtraceBedroom Sensor dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:28.657 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00670C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 67, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:28.544 PMdebugBedroom Sensor DELAYING 2 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:28.541 PMtraceBedroom Sensor dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:28.537 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00660102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 66, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:28.106 PMwarnBedroom Sensor NOT PARSED : [raw:9BDD01000026DFFF420FA643FF2A13B643FF2A65B743FF2A12, dni:9BDD, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:¦Cÿ¶Cÿe·Cÿ*, clusterInt:0, attrInt:65503]
dev:10472022-11-10 03:38:28.103 PMdebugBedroom Sensor parse() descMap = [raw:9BDD01000026DFFF420FA643FF2A13B643FF2A65B743FF2A12, dni:9BDD, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:¦Cÿ¶Cÿe·Cÿ*, clusterInt:0, attrInt:65503]
dev:10472022-11-10 03:38:28.091 PMinfoBedroom Sensor Received endpoint response: cluster: 8005 (endpoint response) endpointCount = 01 endpointList = 01
dev:10472022-11-10 03:38:28.087 PMdebugBedroom Sensor parse() descMap = [raw:catchall: 0000 8005 00 00 0040 00 9BDD 00 00 0000 00 00 5A00DD9B0101, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:9BDD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5A, 00, DD, 9B, 01, 01]]
dev:10472022-11-10 03:38:22.811 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:9BDD0100001801002048E2FF2038E4FF2000, dni:9BDD, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:10472022-11-10 03:38:22.779 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:9BDD0100001801002048E2FF2038E4FF2000, dni:9BDD, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:10472022-11-10 03:38:22.653 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 11 01 005540, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 55, 40]]
dev:10472022-11-10 03:38:22.491 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10472022-11-10 03:38:22.489 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:22.484 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00650C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 65, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:22.373 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock DELAYING 8 seconds event : [name:temperature, unit:°C, value:26.1, type:delayed, isStateChange:true, descriptionText:temperature is 26.1 °C]
dev:10472022-11-10 03:38:22.370 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:22.364 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00640102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 64, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:21.870 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Humidity Alarm (0x0F=1) is active
dev:10472022-11-10 03:38:21.868 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=1
dev:10472022-11-10 03:38:21.864 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00630F04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 63, 0F, 04, 00, 01, 01]]
dev:10472022-11-10 03:38:21.746 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10472022-11-10 03:38:21.744 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10472022-11-10 03:38:21.740 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00620E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 62, 0E, 04, 00, 01, 02]]
dev:10472022-11-10 03:38:21.622 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock reported temperature alarm lower limit 0.0 C
dev:10472022-11-10 03:38:21.620 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=11 fncmd=0
dev:10472022-11-10 03:38:21.615 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00610B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 61, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:21.500 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Humidity Alarm (0x0F=1) is active
dev:10472022-11-10 03:38:21.498 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=1
dev:10472022-11-10 03:38:21.494 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00600F04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 60, 0F, 04, 00, 01, 01]]
dev:10472022-11-10 03:38:21.376 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10472022-11-10 03:38:21.374 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10472022-11-10 03:38:21.370 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005F0E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5F, 0E, 04, 00, 01, 02]]
dev:10472022-11-10 03:38:21.253 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock reported temperature alarm upper limit 39.0 C
dev:10472022-11-10 03:38:21.251 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=10 fncmd=390
dev:10472022-11-10 03:38:21.247 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005E0A02000400000186, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5E, 0A, 02, 00, 04, 00, 00, 01, 86]]
dev:10472022-11-10 03:38:21.130 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Humidity Alarm (0x0F=1) is active
dev:10472022-11-10 03:38:21.129 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=1
dev:10472022-11-10 03:38:21.125 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005D0F04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5D, 0F, 04, 00, 01, 01]]
dev:10472022-11-10 03:38:21.019 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10472022-11-10 03:38:21.017 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10472022-11-10 03:38:21.013 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005C0E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5C, 0E, 04, 00, 01, 02]]
dev:10472022-11-10 03:38:21.003 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10472022-11-10 03:38:20.999 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10472022-11-10 03:38:20.883 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Temperature scale reported by device is: Celsius
dev:10472022-11-10 03:38:20.881 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=9 fncmd=0
dev:10472022-11-10 03:38:20.877 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005B0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5B, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:20.771 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Humidity Alarm (0x0F=1) is active
dev:10472022-11-10 03:38:20.770 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=15 fncmd=1
dev:10472022-11-10 03:38:20.765 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 005A0F04000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5A, 0F, 04, 00, 01, 01]]
dev:10472022-11-10 03:38:20.755 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10472022-11-10 03:38:20.751 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10472022-11-10 03:38:20.635 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Minimal Temperature Alarm (0x0E=2) is inactive
dev:10472022-11-10 03:38:20.634 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=14 fncmd=2
dev:10472022-11-10 03:38:20.629 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00590E04000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 59, 0E, 04, 00, 01, 02]]
dev:10472022-11-10 03:38:20.616 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10472022-11-10 03:38:20.613 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10472022-11-10 03:38:20.508 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock humidity alarm upper limit is 70
dev:10472022-11-10 03:38:20.507 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=12 fncmd=70
dev:10472022-11-10 03:38:20.501 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00580C020004000000460D02000400000014110200040000003C0904000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 58, 0C, 02, 00, 04, 00, 00, 00, 46, 0D, 02, 00, 04, 00, 00, 00, 14, 11, 02, 00, 04, 00, 00, 00, 3C, 09, 04, 00, 01, 00]]
dev:10472022-11-10 03:38:20.482 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:10472022-11-10 03:38:20.479 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:10472022-11-10 03:38:20.374 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock temperature is 26.1 °C
dev:10472022-11-10 03:38:20.371 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=1 fncmd=261
dev:10472022-11-10 03:38:20.365 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 9BDD 01 00 0000 02 01 00570102000400000105020200040000004904020004000000640A020004000001860B02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:9BDD, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 57, 01, 02, 00, 04, 00, 00, 01, 05, 02, 02, 00, 04, 00, 00, 00, 49, 04, 02, 00, 04, 00, 00, 00, 64, 0A, 02, 00, 04, 00, 00, 01, 86, 0B, 02, 00, 04, 00, 00, 00, 00]]
dev:10472022-11-10 03:38:20.277 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he cmd 0x9BDD 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200, he cmd 0x9BDD 0x01 0xEF00 0x00 {00020904000100} {}, delay 200, he cmd 0x9BDD 0x01 0xEF00 0x00 {00030A02000400000186} {}, delay 200, he cmd 0x9BDD 0x01 0xEF00 0x00 {00040B02000400000000} {}, delay 200])
dev:10472022-11-10 03:38:20.275 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Update finished
dev:10472022-11-10 03:38:20.273 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0x9BDD 0x01 0xEF00 0x00 {00040B02000400000000} {}, delay 200]
dev:10472022-11-10 03:38:20.268 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting minTempAlarm to 0.0 C
dev:10472022-11-10 03:38:20.266 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0x9BDD 0x01 0xEF00 0x00 {00030A02000400000186} {}, delay 200]
dev:10472022-11-10 03:38:20.263 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting maxTempAlarm to 39.0 C
dev:10472022-11-10 03:38:20.260 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting temperature scale to Celsius: [he cmd 0x9BDD 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200, he cmd 0x9BDD 0x01 0xEF00 0x00 {00020904000100} {}, delay 200]
dev:10472022-11-10 03:38:20.258 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0x9BDD 0x01 0xEF00 0x00 {00020904000100} {}, delay 200]
dev:10472022-11-10 03:38:20.254 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendTuyaCommand = [he cmd 0x9BDD 0x01 0xEF00 0x00 {0001130200040000000A} {}, delay 200]
dev:10472022-11-10 03:38:20.251 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock setting temperatureSensitivity to 0.5 C
dev:10472022-11-10 03:38:20.249 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is will be turned off after 24 hours
dev:10472022-11-10 03:38:20.214 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is true; Description text logging is true
dev:10472022-11-10 03:38:20.212 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock Updating null (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE200_whkgqxse modelGroupPreference = Auto detect (TS0601_Tuya)
dev:10472022-11-10 03:38:19.327 PMwarnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:9BDD01000068040042105F545A453230305F77686B67717873650000002003010000204805000042065453303630310700003003FEFF003000, dni:9BDD, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_whkgqxse, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:10472022-11-10 03:38:19.295 PMdebugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:9BDD01000068040042105F545A453230305F77686B67717873650000002003010000204805000042065453303630310700003003FEFF003000, dni:9BDD, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_whkgqxse, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:48, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:10472022-11-10 03:38:19.177 PMtraceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he raw 0x9BDD 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200])
dev:10472022-11-10 03:38:19.172 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock configure()..
dev:10472022-11-10 03:38:19.065 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock InitializeVars()... fullInit = true
dev:10472022-11-10 03:38:19.056 PMinfoTuya Temperature Humidity Illuminance LCD Display with a Clock installed()...
Not sure.. no luck still just the temp.. displayed
Based on the logs, I think that your device humidity sensor is defective and does not work.
This is an event that is used in SmartLife app to trigger some Tuya automations, not used in HE as there is a much better and flexible way to send alarm notifications, but it means something is wrong with the humidity sensor. Contrary, the events for the temperature alarm are OK (not active).
