A local driver for the Tholz SmartHeat 2nd generation solar water-heater controller (e.g. TSZ1505N). It talks to the controller over TCP on your LAN (port 4000), no cloud needed.
Features:
- Temperatures: collector, reservoir, consumption and recirculation
- Heat mode (Off / On / Automatic / Eco), heat setpoint and ±1 °C buttons
- On/off for each channel: solar pump, gas, electric backup and recirculation
- Estimated power (W) and energy (kWh) per channel, from on-time × the nominal power you set, with one child device per channel
- Low event traffic (Maker API friendly) and auto-reconnect
Install: Hubitat Package Manager → search "Tholz", or Install → From a URL with https://raw.githubusercontent.com/rngarcia/hubitat/main/drivers/tholz-smartheat/packageManifest.json
Code and docs: hubitat/drivers/tholz-smartheat at main · rngarcia/hubitat · GitHub
Setup: controller IP and port (default 4000), plus the nominal power of each channel you want to measure (from the equipment labels).
Credits: based on the Tholz SmartConnect (TCP) driver for the SmartPool controller by VH / TRATO (@hhorigian), hubitat_tholz (Apache 2.0), adapted to the SmartHeat and extended. Developed with AI assistance.
