TCP connected bulbs stopped working since TCP Servers went down
If you have a gateway with firmware ver 2 , you can use this app to control your lights.
I will made some test with other hub version.
You must to block the internet service of your gateway to avoid updates
You must to enter the ip gateway and I suggest you to assign a static ip to gateway, to avoid update the ip each time your router change it
The bulbs are stable and works fine, the gateway does not has a subscription method, then a schedule refresh its needed to update the status if an external action occurs
Your TCP lights must not include custom images, due load limits, if your lamps have custom images is not possible to get the lamp info.
Try and comment
If you like this app, please consider supporting its development by making a
donation via PayPal.
Source files
