No problem!!
From Tasmota -
16:24:03.809 RSL: RESULT = {"POWER1":"OFF"}
16:24:03.811 RSL: POWER1 = OFF
16:24:03.858 RUL: POWER1#STATE performs "backlog0 Var13 0 ; RuleTimer1 1"
16:24:03.877 RSL: RESULT = {"Var13":"0"}
16:24:03.900 RSL: RESULT = {"T1":1,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
16:24:05.425 RUL: RULES#TIMER=1 performs "var15 '0','1'"
16:24:05.431 RSL: RESULT = {"Var15":"'0','1'"}
16:24:05.483 RUL: VAR15#STATE$!%VAR16% performs "backlog ; var16 '0','1' ; webquery http://192.168.1.185:39501/ POST {'TSync':'True','SWITCH1':'0','SWITCH2':'1'}"
16:24:05.515 RSL: RESULT = {"Var16":"'0','1'"}
16:24:05.615 RSL: RESULT = {"WebQuery":"Done"}
From Habitat (wow!):
dev:1682022-07-10 04:24:01.048 pm infoKitchen Light Sync - *️⃣1️⃣🐶 🛑 ..watchdog: Finished.
dev:1682022-07-10 04:24:01.045 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣🐶 ....watchdog: All normal. Not in a transaction.
dev:1682022-07-10 04:23:56.247 pm infoKitchen Light Sync - *️⃣1️⃣💨 ..hubitatResponse: Exiting
dev:1682022-07-10 04:23:56.243 pm infoKitchen Light Sync - *️⃣1️⃣..hubitatResponse: Closing Transaction
dev:1682022-07-10 04:23:56.239 pm infoKitchen Light Sync - *️⃣1️⃣..updateStatus: Complete:Success
dev:1682022-07-10 04:23:56.235 pm infoKitchen Light Sync - 0️⃣hubitatResponse: Setting device handler values to match device.
dev:1682022-07-10 04:23:56.231 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....hubitatResponse: RSSI: 100
dev:1682022-07-10 04:23:56.226 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....hubitatResponse: Flags are Action:STATE ActionValue:None
dev:1682022-07-10 04:23:56.221 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....hubitatResponse: Raw data is: {"TIME":"2022-07-10T16:23:53","UPTIME":"0T02:53:58","UPTIMESEC":10438,"HEAP":23,"SLEEPMODE":"DYNAMIC","SLEEP":50,"LOADAVG":19,"MQTTCOUNT":0,"POWER1":"ON","POWER2":"ON","WIFI":{"AP":1,"SSID":"CANDY CASTLE","BSSID":"3E:94:ED:BC:05:73","CHANNEL":8,"MODE":"11N","RSSI":100,"SIGNAL":-48,"LINKCOUNT":1,"DOWNTIME":"0T00:00:05"}}.
dev:1682022-07-10 04:23:56.218 pm infoKitchen Light Sync - *️⃣1️⃣🏁 ..hubitatResponse: Entering, data received
dev:1682022-07-10 04:23:56.215 pm infoKitchen Light Sync - *️⃣1️⃣💨 ..parse: Exit to hubitatResponse()
dev:1682022-07-10 04:23:56.212 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....parse: TSync is: false.
dev:1682022-07-10 04:23:56.209 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....parse: StatusSync is: false.
dev:1682022-07-10 04:23:56.203 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣....parse: body is {"Time":"2022-07-10T16:23:53","Uptime":"0T02:53:58","UptimeSec":10438,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"Candy Castle","BSSId":"3E:94:ED:BC:05:73","Channel":8,"Mode":"11n","RSSI":100,"Signal":-48,"LinkCount":1,"Downtime":"0T00:00:05"}}
dev:1682022-07-10 04:23:56.167 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣......parse: data is mac:8CAAB5E49F85, ip:c0a801ba, port:50, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LVR5cGU6IGFwcGxpY2F0aW9uL2pzb24NClNlcnZlcjogVGFzbW90YS8xMi4wLjIgKEVTUDgyNjZFWCkNCkNhY2hlLUNvbnRyb2w6IG5vLWNhY2hlLCBuby1zdG9yZSwgbXVzdC1yZXZhbGlkYXRlDQpQcmFnbWE6IG5vLWNhY2hlDQpFeHBpcmVzOiAtMQ0KQWNjZXB0LVJhbmdlczogbm9uZQ0KVHJhbnNmZXItRW5jb2Rpbmc6IGNodW5rZWQNCkNvbm5lY3Rpb246IGNsb3NlDQo=, body:eyJUaW1lIjoiMjAyMi0wNy0xMFQxNjoyMzo1MyIsIlVwdGltZSI6IjBUMDI6NTM6NTgiLCJVcHRpbWVTZWMiOjEwNDM4LCJIZWFwIjoyMywiU2xlZXBNb2RlIjoiRHluYW1pYyIsIlNsZWVwIjo1MCwiTG9hZEF2ZyI6MTksIk1xdHRDb3VudCI6MCwiUE9XRVIxIjoiT04iLCJQT1dFUjIiOiJPTiIsIldpZmkiOnsiQVAiOjEsIlNTSWQiOiJDYW5keSBDYXN0bGUiLCJCU1NJZCI6IjNFOjk0OkVEOkJDOjA1OjczIiwiQ2hhbm5lbCI6OCwiTW9kZSI6IjExbiIsIlJTU0kiOjEwMCwiU2lnbmFsIjotNDgsIkxpbmtDb3VudCI6MSwiRG93bnRpbWUiOiIwVDAwOjAwOjA1In19
dev:1682022-07-10 04:23:56.163 pm infoKitchen Light Sync - *️⃣1️⃣🏁 ..parse: Entering, data received.
dev:1682022-07-10 04:23:56.070 pm infoKitchen Light Sync - *️⃣1️⃣💨 ..callTasmota: Exiting
dev:1682022-07-10 04:23:56.065 pm infoKitchen Light Sync - *️⃣1️⃣..updateStatus: Sent:STATE
dev:1682022-07-10 04:23:56.060 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: hubaction: GET /cm?user=null&password=null&cmnd=STATE%20None HTTP/1.1
Accept: */*
User-Agent: Linux UPnP/1.0 Hubitat
HOST: 192.168.1.186:80
dev:1682022-07-10 04:23:56.055 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Path: /cm?user=null&password=null&cmnd=STATE%20None
dev:1682022-07-10 04:23:56.052 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣......cleanURL: Returning fixed path: /cm?user=null&password=null&cmnd=STATE%20None
dev:1682022-07-10 04:23:56.048 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣......cleanURL: Fixing path: /cm?user=null&password=null&cmnd=STATE None
dev:1682022-07-10 04:23:56.019 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣📞 ......callTasmota: Starting Watchdog
dev:1682022-07-10 04:23:56.016 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣📞 ....callTasmota: Opening Transaction
dev:1682022-07-10 04:23:56.012 pm infoKitchen Light Sync - 0️⃣📞 callTasmota: Sending command: STATE
dev:1682022-07-10 04:23:55.488 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣......remainingTime: Remaining time 0
dev:1682022-07-10 04:23:55.485 pm infoKitchen Light Sync - 0️⃣⚡ Action: Refresh started....
dev:1682022-07-10 04:23:55.460 pm infoKitchen Light Sync - 0️⃣Initialize: Configured as simple switch. No power monitoring information.
dev:1682022-07-10 04:23:55.449 pm infoKitchen Light Sync - 0️⃣Initialize: pollFrequency value: 0 seconds.
dev:1682022-07-10 04:23:55.446 pm debugKitchen Light Sync - *️⃣*️⃣2️⃣⚡ ....Action: DNI: C0A801BA is correct. Not updated.
dev:1682022-07-10 04:23:55.441 pm debugKitchen Light Sync - *️⃣*️⃣*️⃣3️⃣......updateDeviceNetworkID: Settings are:192.168.1.186
dev:1682022-07-10 04:23:55.432 pm infoKitchen Light Sync - 0️⃣Initialize: Device initialized
dev:1682022-07-10 04:23:55.428 pm infoKitchen Light Sync - 0️⃣Update: Settings: [destIP:192.168.1.186, HubIP:192.168.1.185, relayType:0, timeout:5000, debounce:7000, switchBehaviour:2, logging_level:3, loggingEnhancements:3, pollFrequency:0, destPort:80]
Thanks again!
