[Release] Tado (Connect)
Hi
I have used this app in Smartthings for a few years, and it's worked very well.
WIth the end of Groovy, I'm moving my Tado integration to HE, and set this up successfully.
However - I see that HE is very slow to react to changes in the Tado app.
For example, if I turned on the hot water in the Tado app, I would see this change nearly instantly in ST.
But in HE, it seems to wait for the next refresh/poll - every 5 minutes.
Is there someway to improve this, so that HE recognises changes in the Tado app more quickly?
Hi @Fuzzyligic
I've been using your driver on ST for some time, and it's always worked perfectly.
Switching across to Hubitat, and it's working great to control Tado and report on temperatures.
However - all of my thermostats in Hubitat always show the thermostatOperatingState as Heating, even if they're not doing anything.
Is this a known issue? Or have I done something wrong somehow?
Or do you know if there is a way to remedy this?
Thanks in advance
Just received the following information from Tado:
We have noticed that you are using the unofficial tado° REST API with an old authentication method. That is, you are making requests similar to https://my.tado.com/api/v2/me?username=myUsername&password=myPassword where username and password are supplied as query parameters with each request.
We will discontinue the support for this type of authentication and only support OAuth 2 in the future (you can find more information at https://datatracker.ietf.org/doc/html/rfc6749).
We plan to turn off the authentication on December 4th 2023.
Important: We will stop synchronising passwords for this legacy authentication. If you reset your password, the legacy authentication might stop working even before the above date, so please try to switch to the new type of authentication as quickly as possible.
To make the transition easier for you, we have created a document explaining how to adjust the authentication flow.
Any chance for an update of the app, to handle this authentication? :slightly_smiling_face:
I've just received the same email and was thinking the same thing. I'm not sure if @Fuzzyligic is still in a position to look at this for us mere mortals. :wink:
I was actually looking for a way to integrate the radiator valves directly without the need of a bridge and cloud services. We are talking about heating, and from my point of view cloud is a no go. If you do not have internet in a chilly day it's bad news.
And now they are ditching the OAuth authentication which will leave us with non functional heating systems.
I hope someone will update this before 4th of December.
That would be a Plus 1 from me. I moved from Smartthings to Hubitat beause of all of the integrations that were being killed off.
I am considering switching to HomeKit, if i can recreate the logic. It has the advantage of working without cloud and internet so i will be solving two problems.
Problem is that i use window sensors and individual room temperature setpoints so it will be tricky.
Later update:
I just had to disable the actions involving Tado Connect. Now i use the virtual switch (that was already part of the rule ) through HomeKit Integration to trigger two automations in HomeKit, one for turning on the TRV and one for turning it off.
Basically this rule is triggered every few minutes, and it checks if the setpoint for each room has changed, if the windows are closed and then it starts the central heating and the TRV's that meet the conditions. Usually only one of them will start. This has been active for the past two years and worked flawlessly. And now i think i finally managed to make it 100% local, so Tado Connect is no longer needed.
This can be applied only if you have a smart home that is based on Hubitat and HomeKit.
But there are also other official Tado integrations like Google Home, Amazon Alexa or IFTTT and also Hubitat Integrations, so good luck adapting. :slight_smile:
Hi
Quick questions.
How are your Tado TVR's/Thermostats connected to Hubitat.
What drivers are you using and how did you pair them.
I cannot find any way to add Tado devices directly without Tado Connect
I've asked the same question and the answer is NO, you cannot add the TRV's directly because they use 6LoWPAN not ZigBee, Z-Wave or WiFi. That is low energy iPV6 and i can tell you that it actually works better than any of the other protocols in my apartment. Never had connectivity issues.
If you are looking to integrate them this is not a good time to try Tado Connect which will be useless in a couple of weeks, if nobody updates the app to use OAuth 2.
I was actually looking to replace the Tado TRV's because of the required internet connection even with Tado Connect. But now that i found a way to use the same Rule and only turn on / off the TRV's via HomeKit, i would not change them. They worked very good in the last couple of years, and the Tado App is a bonus. You have graphs and low battery notifications and other features.
Users of Node Red will still be OK.
I raised an issue with the guy who wrote the Tado node (node-red-contrib-tado-client) and he has confirmed that this already uses OAuth2.
:crossed_fingers: all will be OK for NR users in December.
That is also a good choice specially if you already have a Raspberry for other integrations, as i do.
Well, have been using Tado Connect for a while, and found it really usefull. As it integrates with Tado, it allows me to use both Tado functions and automatisation, as well as adjusting things or triggering other devices in Hubitat. So did some work to modify the app code to utilize OAuth authentication.
Have had this code running on my system the last days, and seems to be stable and working. Currently working alongside the "old" Tado Connect to compare.
Gave the app a new name (added Oauth 2) and have both installed right now. Had to import devices again, and will eventually go through the old ones and replace them with the new ones in flows etc.
Copy in the code below as a new app code, and then configure the app.
Use the following Client ID and Secret:
Client ID: public-api-preview
Client Secret: 4HJGRffVR8xb3XdEUQpjgZ1VplJi6Xgw
Further details here: How do I update my REST API authentication method to OAuth 2? | Help Center
I'm new to this, but will try if I can merge the code with the existing app on GitHub as well. For now, I will past the new app code in comment(s) below.
Code part 1:
 *  Tado Connect
 *  Copyright 2016 Stuart Buchanan
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 * 22/11/2023 v2.9 Adjusted to OAuth 2 authentication flow
 * 27/04/2018 v2.8 fixed issue with null values when trying to retrieve current setpoint when null as the try and catch arent working as expected.
 * 27/04/2018 v2.7 Modified for Hubitat
 * 07/02/2018 v2.7 Added some new try catch blocks around parse capability as there were exceptioons after v2.1 occuring for air conditioners, this now works correctly
 * 06/02/2018 v2.6 Fixed Commands for those with Heat Cool that do not support Fan Modes
 * 08/06/2017 v2.5 Amended bug where Hot water type was set to WATER, Instead or HOT_WATER, with thanks to @invisiblemountain
 * 08/06/2017 v2.4 Added Device name to DNI, trying to avaid issue with multiple devices in a single Zone
 * 26/05/2017 v2.3 removed erronous jsonbody statements in the coolCommand Function.
 * 26/05/2017 v2.2 Corrected bug with parseCapability function as this was returning the map instead of the value, this would account for lots of strange behaviour.
 * 25/05/2017 v2.1 Added support for Air Condiioners which have a mandatory swing field for all Commands, corrected prevois bugs in v2.0, thanks again to @Jnick
 * 20/05/2017 v2.0 Added support for Air Condiioners which have a mandatory swing field in the heating & cool Commands, thanks again to @Jnick
 * 17/05/2017 v1.9 Corrected issue with the wrong temp unit being used on some thermostat functions when using Farenheit, many thanks again to @Jnick for getting the logs to help diagnose this.
 * 04/05/2017 v1.8 Corrected issue with scheduling which was introduced in v1.7 with merge of pull request. Many thanks to @Jnick for getting the logs to help diagnose this.
 * 17/04/2017 v1.7 General Bugfixes around Tado user presence with thanks to @sipuncher
 * 14/04/2017 v1.6 fixed defects in user presence device polling
 * 06/04/2017 v1.5 scheduled refresh of tado user status every minute (Thanks to @sipuncher for pointing out my mistake)
 * 03/04/2017 v1.4 Added ability to have your Tado Users created as Smarthings Virtual Presence Sensors for use in routines etc..
 * 03/01/2017 v1.3 Corrected Cooling Commands and Set Points issue with incorrect DNI statement with thanks to Richard Gregg
 * 03/12/2016 v1.2 Corrected Values for Heating and Hot Water set Points
 * 03/12/2016 v1.1 Updated to Support Multiple Hubs, and fixed bug in device discovery and creation, however all device types need updated also.
 * 26/11/2016 V1.0 initial release
import java.text.DecimalFormat
import groovy.json.JsonSlurper
import groovy.json.JsonOutput
private apiUrl() 			{ "https://my.tado.com" }
private getApiUrl()		    { "https://my.tado.com" }
private getOauthTokenUri()  { "https://auth.tado.com" }
private getOauthTokenPath() { "/oauth/token" }
private getVendorName() 	{ "Tado" }
private getVendorIcon()		{ "https://dl.dropboxusercontent.com/s/fvjrqcy5xjxsr31/tado_128.png" }
private getVendorAuthPath()	{ "/oauth2/authorize" }
private getVendorTokenPath(){ "https://auth.tado.com/oauth/token" }
private getClientId() 		{ settings.clientId }
private getClientSecret() 	{ settings.clientSecret }
private getRefreshToken( )  { state.refreshToken }
private getCallbackUrl()	{ getServerUrl()+ "/oauth/callback?access_token=${state.accessToken}" }
private getBuildRedirectUrl() { getServerUrl() + "/oauth/initialize?access_token=${state.accessToken}" }
private getServerUrl() 		{ return getFullApiServerUrl() }
 // Automatically generated. Make future change here.
definition(
    name: "Tado (Connect) - Oauth 2",
    namespace: "fuzzysb",
    author: "Stuart Buchanan",
    description: "Tado Integration, This SmartApp supports all Tado Products. (Heating Thermostats, Extension Kits, AC Cooling & Radiator Valves.)",
    category: "Heating",
	iconUrl:   "https://dl.dropboxusercontent.com/s/fvjrqcy5xjxsr31/tado_128.png",
	iconX2Url: "https://dl.dropboxusercontent.com/s/jyad58wb28ibx2f/tado_256.png",
	oauth: true,
    singleInstance: false
	appSetting "clientId"
	appSetting "clientSecret"
	appSetting "serverUrl"
preferences {
	page(name: "startPage", title: "Tado (Connect) Integration", content: "startPage", install: false)
	page(name: "Credentials", title: "Fetch Tado Credentials", content: "authPage", install: false)
	page(name: "mainPage", title: "Tado (Connect) Integration", content: "mainPage")
	page(name: "completePage", title: "${getVendorName()} is now connected to Hubitat!", content: "completePage")
	page(name: "listDevices", title: "Tado Devices", content: "listDevices", install: false)
    page(name: "listUsers", title: "Tado Users", content: "listUsers", install: false)
	page(name: "advancedOptions", title: "Tado Advanced Options", content: "advancedOptions", install: false)
	page(name: "badCredentials", title: "Invalid Credentials", content: "badAuthPage", install: false)
mappings {
	path("/receivedHomeId"){action: [POST: "receivedHomeId", GET: "receivedHomeId"]}
def startPage() {
    if (state.homeId) { return mainPage() }
    else { return authPage() }
def authPage() {
	log.debug "In authPage"
    log.error "In authPage"
    if(enableDebug == true){log.debug "In authPage"}
	def description
	def uninstallAllowed = false
	def oauthTokenProvided = false
	if (!state.accessToken) {
		if(enableDebug == true){log.debug "About to create access token."}
		state.accessToken = createAccessToken()
		if(enableDebug == true){log.debug "Access token is : ${state.accessToken}"}
	def redirectUrl = getBuildRedirectUrl()
	if(enableDebug == true){log.debug "Redirect url = ${redirectUrl}"}
	if (state.authToken) {
		description = "Tap 'Next' to proceed"
		uninstallAllowed = true
		oauthTokenProvided = true
	} else {
		description = "Click to enter Credentials."
	if (!oauthTokenProvided) {
		if(enableDebug == true){log.debug "Showing the login page"}
		return dynamicPage(name: "Credentials", title: "Authorize Connection", nextPage:mainPage, uninstall: false , install:false) {
			section("Enter Application Details...") {
				paragraph "you can get these details from Tado"
				input(name: 'clientId', title: 'Client ID', type: 'text', required: true)
				input(name: 'clientSecret', title: 'Client secret (save this box before pressing the button below)', type: 'text', required: true, submitOnChange: true )
			section("Generate Username and Password") {
				input "username", "text", title: "Your Tado Username", required: true, defaultValue: ""
				input "password", "password", title: "Your Tado Password", required: true
def mainPage() {
 	if (!state.accessToken){
  		createAccessToken()
  		getToken()
    if (!state.authToken){
        oauthAccessTokenGrant() }
  	getidCommand()
    getTempUnitCommand()
  	log.debug "Logging debug: ${state.homeId}"
	   if (state.homeId) {
       return completePage()
       } else {
         return badAuthPage()
def completePage(){
	def description = "Tap 'Next' to proceed"
			return dynamicPage(name: "completePage", title: "Credentials Accepted!", uninstall:true, install:false,nextPage: listDevices) {
				section { href url: buildRedirectUrl("receivedHomeId"), style:"embedded", required:false, title:"${getVendorName()} is now connected to Hubitat!", description:description }
def badAuthPage(){
	log.debug "In badAuthPage"
    log.error "login result false"
       		return dynamicPage(name: "badCredentials", title: "Bad Tado Credentials", install:false, uninstall:true, nextPage: Credentials) {
				section("") {
					paragraph "Please check your username and password"
def advancedOptions() {
	log.debug "In Advanced Options"
	def options = getDeviceList()
	dynamicPage(name: "advancedOptions", title: "Select Advanced Options", install:true) {
    	section("Default temperatures for thermostat actions. Please enter desired temperatures") {
      	input("defHeatingTemp", "number", title: "Default Heating Temperature?", required: true)
      	input("defCoolingTemp", "number", title: "Default Cooling Temperature?", required: true)
		section("Tado Override Method") {
      	input("manualmode", "enum", title: "Default Tado Manual Overide Method", options: ["TADO_MODE","MANUAL"], required: true)
        section(){
    		if (getHubID() == null){
        		input(
            		,type		: "hub"
            		,title		: "Select your hub"
            		,multiple		: false
            		,required		: true
            		,submitOnChange	: true
     		} else {
        		paragraph("Tap done to finish the initial installation.")
def listDevices() {
	log.debug "In listDevices"
	dynamicPage(name: "listDevices", title: "Choose devices", install:false, uninstall:true, nextPage: listUsers) {
		section("Devices") {
			input "devices", "enum", title: "Select Device(s)", required: false, multiple: true, options: options, submitOnChange: true
def listUsers() {
	log.debug "In listUsers"
	def options = getUserList()
	dynamicPage(name: "listUsers", title: "Choose users you wish to create a Virtual Smarthings Presence Sensors for", install:false, uninstall:true, nextPage: advancedOptions) {
		section("Users") {
			input "users", "enum", title: "Select User(s)", required: false, multiple: true, options: options, submitOnChange: true
def getToken(){
		try {
			getAccessToken()
			DEBUG("Creating new Access Token: $state.accessToken")
		} catch (ex) {
			DEBUG("Did you forget to enable OAuth in SmartApp IDE settings")
            DEBUG(ex)
def receivedHomeId() {
	log.debug "In receivedToken"
	def html = """
        <!DOCTYPE html>
        <html>
        <head>
        <meta name="viewport" content="width=device-width, initial-scale=1">
        <title>${getVendorName()} Connection</title>
        <style type="text/css">
            * { box-sizing: border-box; }
            @font-face {
                font-family: 'Swiss 721 W01 Thin';
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.eot');
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.eot?#iefix') format('embedded-opentype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.woff') format('woff'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.ttf') format('truetype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-thin-webfont.svg#swis721_th_btthin') format('svg');
                font-weight: normal;
                font-style: normal;
            @font-face {
                font-family: 'Swiss 721 W01 Light';
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.eot');
                src: url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.eot?#iefix') format('embedded-opentype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.woff') format('woff'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.ttf') format('truetype'),
                     url('https://s3.amazonaws.com/smartapp-icons/Partner/fonts/swiss-721-light-webfont.svg#swis721_lt_btlight') format('svg');
                font-style: normal;
            .container {
                width: 560px;
                padding: 40px;
                /*background: #eee;*/
                text-align: center;
            img {
                vertical-align: middle;
            img:nth-child(2) {
                margin: 0 30px;
            p {
                font-size: 2.2em;
                text-align: center;
                color: #666666;
                margin-bottom: 0;
            p:last-child {
                margin-top: 0px;
            span {
        </style>
        </head>
        <body>
            <div class="container">
                <img src=""" + getVendorIcon() + """ alt="Vendor icon" />
                <img src="https://s3.amazonaws.com/smartapp-icons/Partner/support/connected-device-icn%402x.png" alt="connected device icon" />
                <img src="https://cdn.shopify.com/s/files/1/2575/8806/t/20/assets/logo-image-file.png" alt="Hubitat logo" />
                <p>Tap 'Done' to continue to Devices.</p>
			</div>
        </body>
        </html>
	render contentType: 'text/html', data: html
def buildRedirectUrl(endPoint) {
	log.debug "In buildRedirectUrl"
	log.debug("returning: " + getServerUrl() + "/${hubUID}/apps/${app.id}/${endPoint}?access_token=${state.accessToken}")
	return getServerUrl() + "/${hubUID}/apps/${app.id}/${endPoint}?access_token=${state.accessToken}"
def getDeviceList() {
  def TadoDevices = getZonesCommand()
  return TadoDevices.sort()
def getUserList() {
  def TadoUsers = getMobileDevicesCommand()
  return TadoUsers.sort()
def installed() {
	log.debug "Installed with settings: ${settings}"
	initialize()
def updated() {
	log.debug "Updated with settings: ${settings}"
  	unsubscribe()
	unschedule()
	initialize()
def uninstalled() {
  log.debug "Uninstalling Tado (Connect)"
  revokeAccessToken()
  removeChildDevices(getChildDevices())
  log.debug "Tado (Connect) Uninstalled"
def initialize() {
	log.debug "Initialized with settings: ${settings}"
	// Pull the latest device info into state
	getDeviceList();
    def children = getChildDevices()
    if(settings.devices) {
    	settings.devices.each { device ->
        log.debug("Devices Inspected ${device.inspect()}")
		def item = device.tokenize('|')
        def deviceType = item[0]
        def deviceId = item[1]
        def deviceName = item[2]
        def existingDevices = children.find{ d -> d.deviceNetworkId.contains(deviceId + "|" + deviceType) }
        log.debug("existingDevices Inspected ${existingDevices.inspect()}")
    	if(!existingDevices) {
          log.debug("Some Devices were not found....creating Child Device ${deviceName}")
          try {
            if (deviceType == "HOT_WATER")
              log.debug("Creating Hot Water Device ${deviceName}")
              createChildDevice("Tado Hot Water Control", deviceId + "|" + deviceType + "|" + state.accessToken + "|" + devicename, "${deviceName}", deviceName)
            if (deviceType == "HEATING")
              log.debug("Creating Heating Device ${deviceName}")
              createChildDevice("Tado Heating Thermostat", deviceId + "|" + deviceType + "|" + state.accessToken + "|" + devicename, "${deviceName}", deviceName)
            if (deviceType == "AIR_CONDITIONING")
              log.debug("Creating Air Conditioning Device ${deviceName}")
              createChildDevice("Tado Cooling Thermostat", deviceId + "|" + deviceType + "|" + state.accessToken + "|" + devicename, "${deviceName}", deviceName)
 			} catch (Exception e)
					log.error "Error creating device: ${e}"
    getUserList();
       if(settings.users) {
    	settings.users.each { user ->
        log.debug("Devices Inspected ${user.inspect()}")
		def item = user.tokenize('|')
        def userId = item[0]
        def userName = item[1]
        def existingUsers = children.find{ d -> d.deviceNetworkId.contains(userId + "|" + userName) }
        log.debug("existingUsers Inspected ${existingUsers.inspect()}")
    	if(!existingUsers) {
          log.debug("Some Users were not found....creating Child presence Device ${userName}")
          try
              createChildDevice("Tado User Presence", userId + "|" + userName + "|" + state.accessToken, "${userName}", userName)
	// Do the initial poll
    getInititialDeviceInfo()
	// Schedule it to run every 5 minutes
	runEvery5Minutes("poll")
    runEvery5Minutes("userPoll")
def getInititialDeviceInfo(){
	log.debug "getInititialDeviceInfo"
	getDeviceList();
      if(existingDevices) {
        existingDevices.getInitialDeviceinfo()
def getHubID(){
	def hubID
    if (myHub){
        hubID = myHub.id
    } else {
        log.debug("hub type is ${location.hubs[0].type}")
        def hubs = location.hubs.findAll{ it.type == "PHYSICAL" }
        if (hubs.size() == 1){
            hubID = hubs[0].id
    log.debug("Returning Hub ID: ${hubID}")
    return hubID
def poll() {
	log.debug "In Poll"
	getDeviceList();
        existingDevices.poll()
def userPoll() {
	log.debug "In UserPoll"
    def children = getChildDevices();
    		if(existingUsers) {
          		existingUsers.poll()
def createChildDevice(deviceFile, dni, name, label) {
	log.debug "In createChildDevice"
    try{
		def childDevice = addChildDevice("fuzzysb", deviceFile, dni, getHubID(), [name: name, label: label, completedSetup: true])
	} catch (e) {
private sendCommand(method,childDevice,args = []) {
  def methods = [
		'getid': [
        			uri: apiUrl(),
                    path: "/api/v2/me",
                    requestContentType: "application/json",
                    headers: ["Authorization": "Bearer " + state.authToken ]
    'gettempunit': [
        			uri: apiUrl(),
                    path: "/api/v2/homes/${state.homeId}",
    'getzones': [
             uri: apiUrl(),
                    path: "/api/v2/homes/" + state.homeId + "/zones",
	'getMobileDevices': [
             uri: apiUrl(),
                    path: "/api/v2/homes/" + state.homeId + "/mobileDevices",
    'getcapabilities': [
        			uri: apiUrl(),
                    path: "/api/v2/homes/" + state.homeId + "/zones/" + args[0] + "/capabilities",
    'status': [
        			uri: apiUrl(),
                    path: "/api/v2/homes/" + state.homeId + "/zones/" + args[0] + "/state",
	'userStatus': [
             		uri: apiUrl(),
	'temperature': [
        			uri: apiUrl(),
        			path: "/api/v2/homes/" + state.homeId + "/zones/" + args[0] + "/overlay",
                    headers: ["Authorization": "Bearer " + state.authToken ],
                  	body: args[1]
	'weatherStatus': [
        			uri: apiUrl(),
        			path: "/api/v2/homes/" + state.homeId + "/weather",
    'deleteEntry': [
        			uri: apiUrl(),
	def request = methods.getAt(method)
        if(now() >= state.authTokenExpires) {
		    refreshToken();
      log.debug "Http Params ("+request+")"
      try{
        log.debug "Executing 'sendCommand' for method" + " " + method
          if (method == "getid"){
            httpGet(request) { resp ->
                parseMeResponse(resp)
          }else if (method == "gettempunit"){
                parseTempResponse(resp)
          }else if (method == "getzones"){
                parseZonesResponse(resp)
          }else if (method == "getMobileDevices"){
                parseMobileDevicesResponse(resp)
       	  }else if (method == "getcapabilities"){
                parseCapabilitiesResponse(resp,childDevice)
          }else if (method == "status"){
                parseResponse(resp,childDevice)
          }else if (method == "userStatus"){
                parseUserResponse(resp,childDevice)
		  }else if (method == "temperature"){
            httpPut(request) { resp ->
                parseputResponse(resp,childDevice)
          }else if (method == "weatherStatus"){
            log.debug "calling weatherStatus Method"
                parseweatherResponse(resp,childDevice)
          }else if (method == "deleteEntry"){
            httpDelete(request) { resp ->
                parsedeleteResponse(resp,childDevice)
        }else{
            httpGet(request)
    } catch(Exception e){
        log.debug("Exception: " + e)
// Parse incoming device messages to generate events
private parseMeResponse(resp) {
    log.debug("Executing parseMeResponse: "+resp.data)
    log.debug("Output status: "+resp.status)
    if(resp.status == 200) {
    	log.debug("Executing parseMeResponse.successTrue")
        state.homeId = resp.data.homes[0].id
        log.debug("Got HomeID Value: " + state.homeId)
    }else if(resp.status == 201){
        log.debug("Something was created/updated")
private parseputResponse(resp,childDevice) {
	log.debug("Executing parseputResponse: "+resp.data)
private parsedeleteResponse(resp,childDevice) {
	log.debug("Executing parsedeleteResponse: "+resp.data)
private parseUserResponse(resp,childDevice) {
  	def item = (childDevice.device.deviceNetworkId).tokenize('|')
    log.debug("Executing parseUserResponse: "+resp.data)
      def restUsers = resp.data
      log.debug("Executing parseUserResponse.successTrue")
      log.debug("UserId is ${userId} and userName is ${userName}")
      for (TadoUser in restUsers) {
      	log.debug("TadoUserId is ${TadoUser.id}")
      	if ((TadoUser.id).toString() == (userId).toString())
         log.debug("Entering presence Assesment for User Id: ${userId}")
         if (TadoUser.settings.geoTrackingEnabled == true)
         	log.debug("GeoTracking is Enabled for User Id: ${userId}")
        	if (TadoUser.location.atHome == true)
            	log.debug("Send presence Home Event Fired")
               	childDevice?.sendEvent(name:"presence",value: "present")
            } else if (TadoUser.location.atHome == false)
            	log.debug("Send presence Away Event Fired")
            	childDevice?.sendEvent(name:"presence",value: "not present")
    } else if(resp.status == 201){
private parseResponse(resp,childDevice) {
  def deviceId = item[0]
  def deviceType = item[1]
  def deviceToken = item[2]
    log.debug("Executing parseResponse: "+resp.data)
    def temperatureUnit = state.tempunit
    log.debug("Temperature Unit is ${temperatureUnit}")
    def humidityUnit = "%"
    def ACMode
    def ACFanSpeed
    def ACFanMode = "off"
    def thermostatSetpoint
    def tOperatingState
        log.debug("Executing parseResponse.successTrue")
        def temperature
        if (temperatureUnit == "C") {
        	temperature = (Math.round(resp.data.sensorDataPoints.insideTemperature.celsius *10 ) / 10)
        else if(temperatureUnit == "F"){
        	temperature = (Math.round(resp.data.sensorDataPoints.insideTemperature.fahrenheit * 10) / 10)
        log.debug("Read temperature: " + temperature)
        childDevice?.sendEvent(name:"temperature",value:temperature,unit:temperatureUnit)
        log.debug("Send Temperature Event Fired")
        def autoOperation = "OFF"
        if(resp.data.overlayType == null){
        	autoOperation = resp.data.tadoMode
        else if(resp.data.overlayType == "NO_FREEZE"){
        }else if(resp.data.overlayType == "MANUAL"){
        	autoOperation = "MANUAL"
        log.debug("Read tadoMode: " + autoOperation)
        childDevice?.sendEvent(name:"tadoMode",value:autoOperation)
        log.debug("Send thermostatMode Event Fired")
        def humidity
        if (resp.data.sensorDataPoints.humidity.percentage != null){
        	humidity = resp.data.sensorDataPoints.humidity.percentage
        }else{
        	humidity = "--"
        log.debug("Read humidity: " + humidity)
        childDevice?.sendEvent(name:"humidity",value:humidity,unit:humidityUnit)
    	if (resp.data.setting.power == "OFF"){
            tOperatingState = "idle"
            ACMode = "off"
            ACFanMode = "off"
            log.debug("Read thermostatMode: " + ACMode)
            ACFanSpeed = "OFF"
            log.debug("Read tadoFanSpeed: " + ACFanSpeed)
            thermostatSetpoint = "--"
            log.debug("Read thermostatSetpoint: " + thermostatSetpoint)
      else if (resp.data.setting.power == "ON"){
        ACMode = (resp.data.setting.mode).toLowerCase()
        log.debug("thermostatMode: " + ACMode)
        ACFanSpeed = resp.data.setting.fanSpeed
        if (ACFanSpeed == null) {
          ACFanSpeed = "--"
        if (resp.data.overlay != null){
          if (resp.data.overlay.termination.type == "TIMER"){
            if (resp.data.overlay.termination.durationInSeconds == "3600"){
              ACMode = "emergency heat"
              log.debug("thermostatMode is heat, however duration shows the state is: " + ACMode)
            switch (ACMode) {
				case "off":
        		break
    			case "heat":
        			tOperatingState = "heating"
        		break
    			case "emergency heat":
        		break
        		case "cool":
        			tOperatingState = "cooling"
        		break
                case "dry":
        			tOperatingState = "drying"
        		break
                case "fan":
        			tOperatingState = "fan only"
        		break
                case "auto":
        			tOperatingState = "heating|cooling"
        		break
            log.debug("Read thermostatOperatingState: " + tOperatingState)
        if (ACMode == "dry" || ACMode == "auto" || ACMode == "fan"){
        }else if(ACMode == "fan") {
        	ACFanMode = "auto"
        }else{
        		thermostatSetpoint = Math.round(resp.data.setting.temperature.celsius)
        		thermostatSetpoint = Math.round(resp.data.setting.temperature.fahrenheit)
    }else{
        log.debug("Executing parseResponse.successFalse")
    childDevice?.sendEvent(name:"thermostatOperatingState",value:tOperatingState)
    log.debug("Send thermostatOperatingState Event Fired")
    childDevice?.sendEvent(name:"tadoFanSpeed",value:ACFanSpeed)
    log.debug("Send tadoFanSpeed Event Fired")
    childDevice?.sendEvent(name:"thermostatFanMode",value:ACFanMode)
    log.debug("Send thermostatFanMode Event Fired")
    childDevice?.sendEvent(name:"thermostatMode",value:ACMode)
    childDevice?.sendEvent(name:"thermostatSetpoint",value:thermostatSetpoint,unit:temperatureUnit)
    log.debug("Send thermostatSetpoint Event Fired")
    childDevice?.sendEvent(name:"heatingSetpoint",value:thermostatSetpoint,unit:temperatureUnit)
    log.debug("Send heatingSetpoint Event Fired")
    childDevice?.sendEvent(name:"coolingSetpoint",value:thermostatSetpoint,unit:temperatureUnit)
    log.debug("Send coolingSetpoint Event Fired")
    def ACMode
    def ACFanSpeed
    def tOperatingState
        def temperature
        	temperature = (Math.round(resp.data.sensorDataPoints.insideTemperature.celsius * 10 ) / 10)
        childDevice?.sendEvent(name: 'temperature', value: temperature, unit: temperatureUnit)
        childDevice?.sendEvent(name: 'tadoMode', value: autoOperation)
			childDevice?.sendEvent(name: 'thermostatMode', value: "heat")
			childDevice?.sendEvent(name: 'thermostatOperatingState', value: "heating")
				thermostatSetpoint = resp.data.setting.temperature.celsius
				thermostatSetpoint = resp.data.setting.temperature.fahrenheit
		} else if(resp.data.setting.power == "OFF"){
			childDevice?.sendEvent(name: 'thermostatMode', value: "off")
			childDevice?.sendEvent(name: 'thermostatOperatingState', value: "idle")
        def humidity
        }else{
        	humidity = "--"
        childDevice?.sendEvent(name: 'humidity', value: humidity,unit: humidityUnit)
	else{
    childDevice?.sendEvent(name: 'thermostatSetpoint', value: thermostatSetpoint, unit: temperatureUnit)
    childDevice?.sendEvent(name: 'heatingSetpoint', value: thermostatSetpoint, unit: temperatureUnit)
    def ACMode
    def ACFanSpeed
    def tOperatingState
    def temperature
    if (state.supportsWaterTempControl == "true" && resp.data.tadoMode != null && resp.data.setting.power != "OFF"){
      temperature = (Math.round(resp.data.setting.temperature.celsius * 10 ) / 10)
      temperature = (Math.round(resp.data.setting.temperature.fahrenheit * 10) / 10)
    } else {
      childDevice?.sendEvent(name: 'temperature', value: "--", unit: temperatureUnit)
        } else {
      else{
private parseTempResponse(resp) {
    log.debug("Executing parseTempResponse: "+resp.data)
    	log.debug("Executing parseTempResponse.successTrue")
        def tempunitname = resp.data.temperatureUnit
        if (tempunitname == "CELSIUS") {
        	log.debug("Setting Temp Unit to C")
        	state.tempunit = "C"
        else if(tempunitname == "FAHRENHEIT"){
        	log.debug("Setting Temp Unit to F")
        	state.tempunit = "F"
private parseZonesResponse(resp) {
    log.debug("Executing parseZonesResponse: "+resp.data)
      def restDevices = resp.data
      def TadoDevices = []
      log.debug("Executing parseZoneResponse.successTrue")
      restDevices.each { Tado -> TadoDevices << ["${Tado.type}|${Tado.id}|${Tado.name}":"${Tado.name}"] }
      log.debug(TadoDevices)
      return TadoDevices
private parseMobileDevicesResponse(resp) {
    log.debug("Executing parseMobileDevicesResponse: "+resp.data)
      def TadoUsers = []
      log.debug("Executing parseMobileDevicesResponse.successTrue")
      restUsers.each { TadoUser ->
        	TadoUsers << ["${TadoUser.id}|${TadoUser.name}":"${TadoUser.name}"]
      log.debug(TadoUsers)
      return TadoUsers
private parseCapabilitiesResponse(resp,childDevice) {
    log.debug("Executing parseCapabilitiesResponse: "+resp.data)
    log.debug("Output status: " + resp.status)
    	try
       	childDevice?.setCapabilitytadoType(resp.data.type)
        log.debug("Tado Type is ${resp.data.type}")
        if(resp.data.type == "AIR_CONDITIONING")
          try
            if(resp.data.AUTO || (resp.data.AUTO).toString() == "[:]"){
              log.debug("settingautocapability state true")
              childDevice?.setCapabilitySupportsAuto("true")
            } else {
              log.debug("settingautocapability state false")
              childDevice?.setCapabilitySupportsAuto("false")
            if(resp.data.AUTO.swings || (resp.data.AUTO.swings).toString() == "[:]")
              log.debug("settingautoswingcapability state true")
            childDevice?.setCapabilitySupportsAutoSwing("true")
            else
              log.debug("settingautoswingcapability state false")
              childDevice?.setCapabilitySupportsAutoSwing("false")
          catch(Exception e)
            log.debug("___exception parsing Auto Capabiity: " + e)
          try
              if(resp.data.COOL || (resp.data.COOL).toString() == "[:]"){
              log.debug("setting COOL capability state true")
              childDevice?.setCapabilitySupportsCool("true")
                def coolfanmodelist = resp.data.COOL.fanSpeeds
                if(resp.data.COOL.swings || (resp.data.COOL.swings).toString() == "[:]")
                  log.debug("settingcoolswingcapability state true")
                  childDevice?.setCapabilitySupportsCoolSwing("true")
                else
                  log.debug("settingcoolswingcapability state false")
                  childDevice?.setCapabilitySupportsCoolSwing("false")
                if(resp.data.COOL.fanSpeeds || (resp.data.COOL.fanSpeeds).toString() == "[:]")
                  childDevice?.setCapabilitySupportsCoolFanSpeed("true")
                else
                  childDevice?.setCapabilitySupportsCoolFanSpeed("false")
                if(coolfanmodelist.find { it == 'AUTO' }){
                  log.debug("setting COOL Auto Fan Speed capability state true")
                  childDevice?.setCapabilitySupportsCoolAutoFanSpeed("true")
                } else {
                  log.debug("setting COOL Auto Fan Speed capability state false")
                  childDevice?.setCapabilitySupportsCoolAutoFanSpeed("false")
                if (state.tempunit == "C"){
                  childDevice?.setCapabilityMaxCoolTemp(resp.data.COOL.temperatures.celsius.max)
                  childDevice?.setCapabilityMinCoolTemp(resp.data.COOL.temperatures.celsius.min)
                } else if (state.tempunit == "F") {
                  childDevice?.setCapabilityMaxCoolTemp(resp.data.COOL.temperatures.fahrenheit.max)
                  childDevice?.setCapabilityMinCoolTemp(resp.data.COOL.temperatures.fahrenheit.min)
            } else {
              log.debug("setting COOL capability state false")
              childDevice?.setCapabilitySupportsCool("false")
          catch(Exception e)
            log.debug("___exception parsing Cool Capabiity: " + e)
          try
            if(resp.data.DRY || (resp.data.DRY).toString() == "[:]"){
              log.debug("setting DRY capability state true")
              childDevice?.setCapabilitySupportsDry("true")
            } else {
              log.debug("setting DRY capability state false")
              childDevice?.setCapabilitySupportsDry("false")
            if(resp.data.DRY.swings || (resp.data.DRY.swings).toString() == "[:]")
              log.debug("settingdryswingcapability state true")
            childDevice?.setCapabilitySupportsDrySwing("true")
            else
              log.debug("settingdryswingcapability state false")
              childDevice?.setCapabilitySupportsDrySwing("false")
          catch(Exception e)
            log.debug("___exception parsing Dry Capabiity: " + e)
          try
            if(resp.data.FAN || (resp.data.FAN).toString() == "[:]"){
              log.debug("setting FAN capability state true")
              childDevice?.setCapabilitySupportsFan("true")
            } else {
              log.debug("setting FAN capability state false")
              childDevice?.setCapabilitySupportsFan("false")
            if(resp.data.FAN.swings || (resp.data.FAN.swings).toString() == "[:]")
              log.debug("settingfanswingcapability state true")
            childDevice?.setCapabilitySupportsFanSwing("true")
            else
              log.debug("settingfanswingcapability state false")
              childDevice?.setCapabilitySupportsFanSwing("false")
          catch(Exception e)
            log.debug("___exception parsing Fan Capabiity: " + e)
          try
            if(resp.data.HEAT || (resp.data.HEAT).toString() == "[:]"){
              log.debug("setting HEAT capability state true")
              childDevice?.setCapabilitySupportsHeat("true")
                def heatfanmodelist = resp.data.HEAT.fanSpeeds
                if(resp.data.HEAT.swings || (resp.data.HEAT.swings).toString() == "[:]")
                  log.debug("settingheatswingcapability state true")
                  childDevice?.setCapabilitySupportsHeatSwing("true")
                else
                  log.debug("settingheatswingcapability state false")
                  childDevice?.setCapabilitySupportsHeatSwing("false")
                if(resp.data.HEAT.fanSpeeds || (resp.data.HEAT.fanSpeeds).toString() == "[:]")
                  childDevice?.setCapabilitySupportsHeatFanSpeed("true")
                else
                  childDevice?.setCapabilitySupportsHeatFanSpeed("false")
                if(heatfanmodelist.find { it == 'AUTO' }){
                  log.debug("setting HEAT Auto Fan Speed capability state true")
                  childDevice?.setCapabilitySupportsHeatAutoFanSpeed("true")
                } else {
                  log.debug("setting HEAT Auto Fan Speed capability state false")
                  childDevice?.setCapabilitySupportsHeatAutoFanSpeed("false")
                  childDevice?.setCapabilityMaxHeatTemp(resp.data.HEAT.temperatures.celsius.max)
                  childDevice?.setCapabilityMinHeatTemp(resp.data.HEAT.temperatures.celsius.min)
                  childDevice?.setCapabilityMaxHeatTemp(resp.data.HEAT.temperatures.fahrenheit.max)
                  childDevice?.setCapabilityMinHeatTemp(resp.data.HEAT.temperatures.fahrenheit.min)
            } else {
              log.debug("setting HEAT capability state false")
              childDevice?.setCapabilitySupportsHeat("false")
          }catch(Exception e)
            log.debug("___exception parsing Heat Capabiity: " + e)
        if(resp.data.type == "HEATING")
              childDevice?.setCapabilityMaxHeatTemp(resp.data.temperatures.celsius.max)
              childDevice?.setCapabilityMinHeatTemp(resp.data.temperatures.celsius.min)
              childDevice?.setCapabilityMaxHeatTemp(resp.data.temperatures.fahrenheit.max)
              childDevice?.setCapabilityMinHeatTemp(resp.data.temperatures.fahrenheit.min)
          else
        if(resp.data.type == "HOT_WATER")
            if(resp.data.type == "HOT_WATER"){
              log.debug("setting WATER capability state true")
              dchildDevice?.setCapabilitySupportsWater("true")
              if (resp.data.canSetTemperature == true){
                childDevice?.setCapabilitySupportsWaterTempControl("true")
              else
                childDevice?.setCapabilitySupportsWaterTempControl("false")
            else
            log.debug("setting Water capability state false")
            childDevice?.setCapabilitySupportsWater("false")
      catch(Exception e)
        log.debug("___exception: " + e)
Code part 2:
Copy in below code part 1
private parseweatherResponse(resp,childDevice) {
    log.debug("Executing parseweatherResponse: "+resp.data)
        def outsidetemperature
        	outsidetemperature = resp.data.outsideTemperature.celsius
        	outsidetemperature = resp.data.outsideTemperature.fahrenheit
        log.debug("Read outside temperature: " + outsidetemperature)
        childDevice?.sendEvent(name: 'outsidetemperature', value: outsidetemperature, unit: temperatureUnit)
        log.debug("Send Outside Temperature Event Fired")
        return result
def getidCommand(){
	log.debug "Executing 'sendCommand.getidCommand'"
	sendCommand("getid",null,[])
def getTempUnitCommand(){
	sendCommand("gettempunit",null,[])
def getZonesCommand(){
	log.debug "Executing 'sendCommand.getzones'"
	sendCommand("getzones",null,[])
def getMobileDevicesCommand(){
	log.debug "Executing 'sendCommand.getMobileDevices'"
	sendCommand("getMobileDevices",null,[])
def weatherStatusCommand(childDevice){
	log.debug "Executing 'sendCommand.weatherStatusCommand'"
	def result = sendCommand("weatherStatus",childDevice,[deviceId])
def getCapabilitiesCommand(childDevice, deviceDNI){
	log.debug("childDevice is: " + childDevice.inspect())
	log.debug("deviceDNI is: " + deviceDNI.inspect())
	def item = deviceDNI.tokenize('|')
	log.debug "Executing 'sendCommand.getcapabilities'"
	sendCommand("getcapabilities",childDevice,[deviceId])
private removeChildDevices(delete) {
	try {
    	delete.each {
        	deleteChildDevice(it.deviceNetworkId)
            log.info "Successfully Removed Child Device: ${it.displayName} (${it.deviceNetworkId})"
    catch (e) { log.error "There was an error (${e}) when trying to delete the child device" }
def parseCapabilityData(Map results){
  log.debug "in parseCapabilityData"
  def result
  results.each { name, value ->
    if (name == "value")
    log.debug "Map Name Returned, ${name} and Value is ${value}"
    result = value.toString()
    log.debug "Result is ${result}"
    //return result
  return result
//Device Commands Below Here
def autoCommand(childDevice){
  log.debug "Executing 'sendCommand.autoCommand' on device ${childDevice.device.name}"
  def terminationmode = settings.manualmode
  def traperror
    def capabilitySupportsAuto = parseCapabilityData(childDevice.getCapabilitySupportsAuto())
    def capabilitySupportsAutoSwing = parseCapabilityData(childDevice.getCapabilitySupportsAutoSwing())
    def capabilitysupported = capabilitySupportsAuto
    if (capabilitysupported == "true"){
    def jsonbody
   	if (capabilitySupportsAutoSwing == "true")
        jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"AUTO", power:"ON", swing:"OFF", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else
      	jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"AUTO", power:"ON", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    sendCommand("temperature",dchildDevice,[deviceId,jsonbody])
    statusCommand(device)
    } else {
      log.debug("Sorry Auto Capability not supported on device ${childDevice.device.name}")
  if(deviceType == "HEATING")
    def initialsetpointtemp
    if(childDevice.device.currentValue("thermostatSetpoint"))
        traperror = ((childDevice.device.currentValue("thermostatSetpoint")).intValue())
    else
       log.debug "Existing Setpoint is not set"
       traperror = 0
    if(traperror == 0){
      initialsetpointtemp = settings.defHeatingTemp
    } else {
    	initialsetpointtemp = childDevice.device.currentValue("thermostatSetpoint")
  	def jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:initialsetpointtemp], type:"HEATING"], termination:[type:terminationmode]])
    sendCommand("temperature",childDevice,[deviceId,jsonbody])
    statusCommand(childDevice)
    log.debug "Executing 'sendCommand.autoCommand'"
    def jsonbody
    def capabilitySupportsWaterTempControl = parseCapabilityData(childDevice.getCapabilitySupportsWaterTempControl())
    if(capabilitySupportsWaterTempControl == "true"){
    else
       traperror = 0
      if(traperror == 0){
      } else {
      jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:initialsetpointtemp], type:"HOT_WATER"], termination:[type:terminationmode]])
    } else {
      jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", type:"HOT_WATER"], termination:[type:terminationmode]])
def dryCommand(childDevice){
  def capabilitySupportsDry = parseCapabilityData(childDevice.getCapabilitySupportsDry())
  def capabilitySupportsDrySwing = parseCapabilityData(childDevice.getCapabilitySupportsDrySwing())
  def capabilitysupported = capabilitySupportsDry
  	log.debug "Executing 'sendCommand.dryCommand' on device ${childDevice.device.name}"
  	def jsonbody
      	if (capabilitySupportsDrySwing == "true")
			jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"DRY", power:"ON", swing:"OFF", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
        else
        	jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"DRY", power:"ON", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
  } else {
    log.debug("Sorry Dry Capability not supported on device ${childDevice.device.name}")
def fanAuto(childDevice){
  def capabilitySupportsFan = parseCapabilityData(childDevice.getCapabilitySupportsFan())
  def capabilitySupportsFanSwing = parseCapabilityData(childDevice.getCapabilitySupportsFanSwing())
  def capabilitysupported = capabilitySupportsFan
		log.debug "Executing 'sendCommand.fanAutoCommand' on device ${childDevice.device.name}"
      def jsonbody
      	if (capabilitySupportsFanSwing == "true")
			jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"FAN", power:"ON", swing:"OFF", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
        else
        	jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"FAN", power:"ON", type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
  } else {
    log.debug("Sorry Fan Capability not supported by your HVAC Device")
def endManualControl(childDevice){
	log.debug "Executing 'sendCommand.endManualControl' on device ${childDevice.device.name}"
	sendCommand("deleteEntry",childDevice,[deviceId])
def cmdFanSpeedAuto(childDevice){
  def supportedfanspeed
  def jsonbody
  def capabilitySupportsCool = parseCapabilityData(childDevice.getCapabilitySupportsCool())
  def capabilitysupported = capabilitySupportsCool
  def capabilitySupportsCoolAutoFanSpeed = parseCapabilityData(childDevice.getCapabilitySupportsCoolAutoFanSpeed())
  def fancapabilitysupported = capabilitySupportsCoolAutoFanSpeed
  if (fancapabilitysupported == "true"){
    supportedfanspeed = "AUTO"
    } else {
      supportedfanspeed = "HIGH"
	def curSetTemp = (childDevice.device.currentValue("thermostatSetpoint"))
	def curMode = ((childDevice.device.currentValue("thermostatMode")).toUpperCase())
	if (curMode == "COOL" || curMode == "HEAT"){
    	if (capabilitySupportsCoolSwing == "true" || capabilitySupportsHeatSwing == "true")
    		if (state.tempunit == "C") {
      			jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:curMode, power:"ON", swing:"OFF", temperature:[celsius:curSetTemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		else if(state.tempunit == "F"){
      			jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:curMode, power:"ON", swing:"OFF", temperature:[fahrenheit:curSetTemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
        else
      			jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:curMode, power:"ON", temperature:[celsius:curSetTemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
      			jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:curMode, power:"ON", temperature:[fahrenheit:curSetTemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
		log.debug "Executing 'sendCommand.fanSpeedAuto' to ${supportedfanspeed}"
def cmdFanSpeedHigh(childDevice){
  def jsonbody
  def supportedfanspeed = "HIGH"
        else
def cmdFanSpeedMid(childDevice){
  def supportedfanspeed = "MIDDLE"
  def jsonbody
        else
		log.debug "Executing 'sendCommand.fanSpeedMid' to ${supportedfanspeed}"
def cmdFanSpeedLow(childDevice){
  def capabilitySupportsCoolSwing = parseCapabilityData(childDevice.getCapabilitySupportsCoolSwing())
  def capabilitySupportsHeatSwing = parseCapabilityData(childDevice.getCapabilitySupportsHeatSwing())
  def supportedfanspeed = "LOW"
  def jsonbody
        else
		log.debug "Executing 'sendCommand.fanSpeedLow' to ${supportedfanspeed}"
def setCoolingTempCommand(childDevice,targetTemperature){
  def capabilitySupportsCoolFanSpeed = parseCapabilityData(childDevice.getCapabilitySupportsCoolFanSpeed())
  def jsonbody
    } else {
    if (capabilitySupportsCoolSwing == "true" && capabilitySupportsCoolFanSpeed == "true")
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", swing:"OFF", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", swing:"OFF", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else if(capabilitySupportsCoolSwing == "true" && capabilitySupportsCoolFanSpeed == "false"){
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", swing:"OFF", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", swing:"OFF", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else if(capabilitySupportsCoolSwing == "false" && capabilitySupportsCoolFanSpeed == "false"){
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
	log.debug "Executing 'sendCommand.setCoolingTempCommand' to ${targetTemperature} on device ${childDevice.device.name}"
def setHeatingTempCommand(childDevice,targetTemperature){
  if(deviceType == "AIR_CONDITIONING")
    def capabilitySupportsHeat = parseCapabilityData(childDevice.getCapabilitySupportsHeat())
    def capabilitysupported = capabilitySupportsHeat
    def capabilitySupportsHeatAutoFanSpeed = parseCapabilityData(childDevice.getCapabilitySupportsHeatAutoFanSpeed())
    def capabilitySupportsHeatFanSpeed = parseCapabilityData(childDevice.getCapabilitySupportsHeatFanSpeed())
    def fancapabilitysupported = capabilitySupportsHeatAutoFanSpeed
    def jsonbody
    else
    if (capabilitySupportsHeatSwing == "true" && capabilitySupportsHeatFanSpeed == "true")
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else if(capabilitySupportsHeatSwing == "true" && capabilitySupportsHeatFanSpeed == "false"){
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", swing:"OFF", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", swing:"OFF", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else if(capabilitySupportsHeatSwing == "false" && capabilitySupportsHeatFanSpeed == "false"){
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[celsius:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[fahrenheit:targetTemperature], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
  	log.debug "Executing 'sendCommand.setHeatingTempCommand' to ${targetTemperature} on device ${childDevice.device.name}"
    def jsonbody
      jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:targetTemperature], type:"HEATING"], termination:[type:terminationmode]])
      jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:targetTemperature], type:"HEATING"], termination:[type:terminationmode]])
  if(deviceType == "HOT_WATER")
    def jsonbody
        jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:targetTemperature], type:"HOT_WATER"], termination:[type:terminationmode]])
				jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:targetTemperature], type:"HOT_WATER"], termination:[type:terminationmode]])
		sendCommand("temperature",[jsonbody])
	  } else {
		    log.debug "Hot Water Temperature Capability Not Supported on device ${childDevice.device.name}"
def offCommand(childDevice){
	log.debug "Executing 'sendCommand.offCommand' on device ${childDevice.device.name}"
  def jsonbody = new groovy.json.JsonOutput().toJson([setting:[type:deviceType, power:"OFF"], termination:[type:terminationmode]])
def onCommand(childDevice){
  log.debug "Executing 'sendCommand.onCommand'"
    coolCommand(childDevice)
  if(deviceType == "HEATING" || deviceType == "HOT_WATER")
    heatCommand(childDevice)
def coolCommand(childDevice){
	log.debug "Executing 'sendCommand.coolCommand'"
    def traperror
    else
       traperror = 0
        } else {
    if(traperror == 0){
    	initialsetpointtemp = settings.defCoolingTemp
    } else {
    def jsonbody
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", swing:"OFF", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    	else if (state.tempunit == "F"){
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", swing:"OFF", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", swing:"OFF", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", swing:"OFF", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
            jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"COOL", power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    else
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"COOL", power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
def heatCommand(childDevice){
  log.debug "Executing 'sendCommand.heatCommand' on device ${childDevice.device.name}"
      def traperror
    	else
       		traperror = 0
      else
      if(traperror == 0)
      else
      def jsonbody
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
          jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", swing:"OFF", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
              jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", swing:"OFF", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
          jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
              jsonbody = new groovy.json.JsonOutput().toJson([setting:[mode:"HEAT", power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
      else
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
    		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[type:terminationmode]])
      def traperror
    	else
       		traperror = 0
        if(traperror == 0)
        else
        def jsonbody
        	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"HEATING"], termination:[type:terminationmode]])
      def jsonbody
      def traperror
    	else
       		traperror = 0
        if(traperror == 0){
        } else {
        	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"HOT_WATER"], termination:[type:terminationmode]])
      } else {
def emergencyHeat(childDevice){
  def traperror
    else
       traperror = 0
      else
      if(traperror == 0)
      else
      def jsonbody
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", swing:"OFF", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
      else
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[celsius:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
      		jsonbody = new groovy.json.JsonOutput().toJson([setting:[fanSpeed:supportedfanspeed, mode:"HEAT", power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"AIR_CONDITIONING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
    else
      log.debug("Sorry Heat Capability not supported on device ${childDevice.device.name}")
    	else
       		traperror = 0
      if(traperror == 0)
      else
      def jsonbody
      	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:initialsetpointtemp], type:"HEATING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
      	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"HEATING"], termination:[durationInSeconds:"3600", type:"TIMER"]])
    def jsonbody
    	else
       		traperror = 0
      if(traperror == 0)
      else
      	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[celsius:initialsetpointtemp], type:"HOT_WATER"], termination:[durationInSeconds:"3600", type:"TIMER"]])
      	jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", temperature:[fahrenheit:initialsetpointtemp], type:"HOT_WATER"], termination:[durationInSeconds:"3600", type:"TIMER"]])
    else
      jsonbody = new groovy.json.JsonOutput().toJson([setting:[power:"ON", type:"HOT_WATER"], termination:[durationInSeconds:"3600", type:"TIMER"]])
def statusCommand(childDevice){
	log.debug "Executing 'sendCommand.statusCommand'"
	sendCommand("status",childDevice,[deviceId])
def userStatusCommand(childDevice){
	try{
		log.debug "Executing 'sendCommand.userStatusCommand'"
		sendCommand("userStatus",childDevice,[])
    	} catch(Exception e) { log.debug("Failed in setting userStatusCommand: " + e)
// OAuth methods
def oauthAccessTokenGrant() {
    log.debug "Executing OAuth 2 Autorization Flow: Request Access Token"
        	def params = [
                uri: getOauthTokenUri(),
                path: getOauthTokenPath(),
				body: [
                    client_id: getClientId(),
                    client_secret: getClientSecret(),
                    username: settings.username,
                    password: settings.password,
                    grant_type: "password"
            try {
                log.debug "Parameters for token request:" + " " + params
                httpPost(params)
                { resp ->
                log.debug "Response data:" + " " + resp.data
                log.debug "Respones succes:" + " " + resp.success//
    			if (resp && resp.data && resp.success) {
                    log.debug "Access token granted"
                    state.refreshToken = resp.data.refresh_token
                    state.authToken = resp.data.access_token
                    state.authTokenExpires = (now() + (resp.data.expires_in * 1000)) - 60000
                    log.debug "Token expires:" + " " + state.authTokenExpires
                } else { log.error "Failed to retreive access token" }
		catch (e) {
            log.error "OAuth error: ${e}"
def refreshToken() {
	def result = false
    log.debug "Refreshing OAuth token"
	try {
        def params = [
				body: [
                    refresh_token: getRefreshToken(),
                    grant_type: "refresh_token"
        log.debug "Parameters for token refresh:" + " " + params
		httpPost(params) { resp ->
				log.debug "Token refreshed successfully"
                state.authTokenExpires = now() + (resp.data.expires_in * 1000) - 60000
				result = true
			else {
                log.error "Failed to refresh token"
				state.authToken = null
				result = false
	catch (e) {
		log.error "Failed to refresh token: ${e}"
		result = false
	return result
Thanks for doing this. Brilliant job.
To make it easy for people to copy the code, when you copy the code into a post, could you highlight/select the code and then click on the </> symbol at the top of the 'post' box.
This will put the code into it's own 'box' and will allow people to copy it.
It will also truncate the code making the post easier to view.
Thanks again. :+1:
Thanks for the information - just edited to make posts more readable.
Still in two posts however, as number of chars is not allowed in one post :slight_smile:
Hi guys. Do these TRV's display the current room temperature? So you can understand whether you're making the set point higher or lower when manually adjusting
Yes you have the current set point as well as actual temperature available. They will update every 5-15 mins. (not sure of the interval actually) by polling Tado, but you can also manually trigger refresh (or implement a rule to do so).
Screenshot_20231124_213914_Hubitat
Forgive me, my question was a bit ambiguous. Does the actual TRV display the room temperature when prompted.
Yes there is a digital display of the current set temperature. I think on the basic trv there are printed on markings to indicate the temperature. Just have a look at the pictures on the Tado website.
