[RELEASE] Synology SRM Router Integration
Synology SRM Router Integration — presence tracking, router health & parental controls
Hi all, I'd like to share a new integration for Synology routers (SRM). It tracks devices on your WiFi/network as presence + switch devices, surfaces router and mesh-node health, reports internet (WAN) status, and exposes Safe Access parental controls right inside Hubitat.
Built and tested against an RT6600ax + RT2600ac mesh (SRM 1.3.2). It talks to the router's local API over HTTPS — no cloud, no extra hardware.
Features
  • Device presence tracking — pick any device on your network; each becomes a child device with PresenceSensor + Switch (on/present = connected, off/not-present = disconnected) for maximum automation compatibility.
    • Discovery picker split into Currently online / Offline, offline sorted by last-seen.
    • Randomised (private) MACs flagged :warning: so you select the stable one.
    • Configurable grace period to debounce phones whose WiFi sleeps.
  • Router & mesh health — optional Router device plus one child per mesh node:
    • Per-node CPU, memory, uptime, model, firmware, connection type (wired/wireless), connected-device count, node status, ethernet ports up.
    • Internet/WAN up/down + public IP.
    • Firmware update available indicator.
    • Reboot (whole router or single node) — opt-in.
  • Parental controls (Safe Access) — mark a tracked device as a Child, link it to a Safe Access profile, and:
    • Pause/resume that person's internet from the device.
    • See screen time today (minutes online).
Requirements
  • A Synology router running SRM (developed on 1.3.2; other versions likely work, may vary).
  • An admin account (SRM has no read-only API role).
  • If you use 2FA, set it to external access only so local logins from Hubitat aren't challenged.
  • Tip: for reliable phone/tablet tracking, set Private Wi-Fi Address to Off/Fixed for your home network on those devices so their MAC stays stable.
Automation ideas
  • Internet down alert: trigger on Router internet = down → flash a light.
  • Bedtime: at 9pm on school nights, pauseInternet on a child's device; resume at 7am.
  • Screen-time cap: if screenTimeMinutes > 120, pauseInternet.
  • Presence automations: use the device presence/switch like any other presence sensor.
  • Firmware reminder: notify when Router updateAvailable = yes.
Installation (HPM )
Search for “Synology”, click on the “Synology SRM Router Integration” to begin the install.
Installation (manual )
Install the drivers first, then the app. The links are raw URLs — in Hubitat, hit Import, paste the URL, and Save.
1. Drivers Code → New Driver → Import → paste each URL → Save:
- Synology SRM Device — `https://raw.githubusercontent.com/dJOS1475/Synology-SRM-Integration/refs/heads/main/drivers/SynologySRMDevice.groovy\`
- Synology SRM Router — `https://raw.githubusercontent.com/dJOS1475/Synology-SRM-Integration/refs/heads/main/drivers/SynologySRMRouter.groovy\`
- Synology SRM Node — `https://raw.githubusercontent.com/dJOS1475/Synology-SRM-Integration/refs/heads/main/drivers/SynologySRMNode.groovy\`
2. Apps Code → New App → Import → paste URL → Save:
- Synology SRM Integration — `https://raw.githubusercontent.com/dJOS1475/Synology-SRM-Integration/refs/heads/main/app/SynologySRMIntegration.groovy\`
3. Apps → Add User App → Synology SRM Integration.
4. Enter your router host, port (default 8001), and admin credentials.
5. Open Select devices to track and pick your devices.
6. (Optional) Enable the Router health device and Safe Access controls; on a Child's device, turn on *This is a Child* and choose their Safe Access profile.
That's it — devices update on the poll interval (default 5 minutes).
Notes & limitations
  • Polling-based (the router can't push), so presence latency ≈ poll interval.
  • Safe Access pause is per profile (per person) — it covers all of that person's devices at once.
  • Cumulative per-device bandwidth isn't exposed by SRM, so it's not included.
  • Reboot commands are opt-in; test them deliberately.
General
- GitHub repo: `https://github.com/dJOS1475/Synology-SRM-Integration\`
Feedback, bug reports, and tested-on-your-model reports very welcome. Enjoy!
Changelog
v1.3.1 - Main router reboot works from its node child device, plus Refresh on node devices.
v1.3.0 - Stable release. All features verified on real hardware (RT6600ax + RT2600ac, SRM 1.3.2) including whole-router and per-node reboot. Added the Actuator capability to the Router and Node drivers so their reboot commands are available to Rule Machine and other automation apps.
v1.1.0 — Added HTML dashboard tiles (htmlTile) to every device; added importUrl to all components for one-click import/updates in Hubitat.
v1.0.0 — Initial release. Device presence tracking (presence + switch), router & mesh-node health, internet/WAN status, firmware-update indicator, whole-router & per-node reboot, Safe Access internet pause, and screen-time reporting.
2026-06-25 - v1.1.1 - Fixed the NameSpace errors
A handy use case for those of us with servers, is you can use your router to tell you when they are offline and all the hard work is done by SRM, not by Hubitat needing to poll multiple devices directly.
EDIT: Installation via HPM is now available.
Hey Derek a couple things, First Great idea, I just downloaded it and I am super excited to use this, I’ve been looking for a way to reboot my router from hubitat or anything other than a smart switch, (for some reason when the internet goes down and comes back up I have to reboot the router before the internet will work again)
The links you have above aren’t working for me (HPM worked perfectly).
I did come across an issue
I had to go into the app code and change @Field static final String CHILD_NS = "derekosborn" to @Field static final String CHILD_NS = "dJOS" (or I could have changed the namespace in the drivers from dJOS to derekosborn
But for the Node driver I needed to change the namespace (of the driver) from dJOS to derekosborn for evertyhing to work
Keep up the Great work
Cheers, I’ve fixed those now.
Ah right - I did change the namespace before release and missed that gotcha - I’ll try to fix that in the next day or so.
Cheers, I was jealous that the UniFi crowd had nice integrations and we Synology owners didn’t. :smiley:
Couldn’t help myself - it’s fixed in v1.1.1
Awesome I'll run the update when I get home
v1.3.0 is out today - I finally got Mesh Node reboots working, and Reboots are now available as an actuator.
One of the annoying things with SRM is you can only schedule reboots for the main router, but not the mesh nodes. Now you can use Hubitat to Schedule the reboots of your entire Mesh network. eg I can reboot my Mesh Node at 04:45 and the Router at 04:50 fortnightly to keep them in top health.
Minor release today:
