Well, that's partially true, as I have yet to release this enhancement to the public that is coming in Envisalink Integration
Thanks for enhancing!
I recall reading that VLC can be used as an audio device. Is there a reference on how to set it up so it can work? I have a Linux computer that stays on constantly. It would be good to use it for sound output (chimes, announcements, etc.) if I can find out how to do so.
You can try this. Works pretty well.
I have a lot of configurations as well. Even if you add config for HSM (water, fire, etc) so I can turn the volume up for emergencies I still can't do a local notification to one room anymore.
Example:
Does that make sense?
I’m testing a version where I go back to putting the device config in the child
That's amazing. Thank you, thank you!
Wrapping my head around Speaker Central...
Everything seems to be install correctly. I have the proxy virtual device set up.
Now, within the Speaker Central app, I can choose the virtual device. Then configure a child: choose the speakers I want to have my alert played on, etc.
I guess I'm trying to figure out the process for using this in another app. So, I have NOAA Weather Alerts, that can push weather alerts to google home and minis (currently doing this). Within my NOAA app, I choose the speakers (I choose the Cobra Proxy VD).
Assuming this is correct, how does SpeakerCentral know which child app to use? There seems to be only one Proxy Speaker Virtual Device choice in the SC app, so all third party apps (NOAA for example) push their output to the Cobra PSVD.
And I'm not sure what the Speaker Central TTS Device is for. I've read most of this thread, and hubitat.uk, etc.
Thanks for any pointers.
Set up rules in Speaker Central for where you want the TTS sent to etc, then point your TTS messages to the Proxy speaker.
Based on what you set up in the app, it’ll then send the messages to the correct places.
Example. I use modes for where my TTS messages should be sent. During “home alone” I want them sent to my Office speaker. So I have SC app send all message sent to the proxy speaker and SC sends them to my office speaker. And any app I use for TTS I just use the proxy speaker as where to send the message to.
SC will then forward it on to where I need it.
If my mode changes to Home, then all messages from apps will be sent to my lounge speaker.
Hope this helps?
Still seems like SC is a black box. I don't see where a SC child and the third part app (NOAA in my case) reference each other.
UI seems to allow only one Proxy Device in SC, which is basically the gateway into SC from third party apps. I still don't see how (unless my install is incorrect) how SC routes specific third party apps to the correct SC-child.
Separately, I'm not sure what Speaker Central TTS Device purpose is.
Thanks.
Think of the virtual proxy as a ‘receiver’ which takes tts from any app (where it is configured as a speaker) and ‘forwards’ the tts to one or more speakers (configured in one or more child apps)
Each child app can be configured to turn on or off one or more speakers dependant upon certain conditions..
For example.
I have a speaker in my kitchen..
my childapp for my kitchen is activated by motion..
If motion is active in the kitchen then the speaker is ‘on’ and tts from the virtual device is sent to that speaker
If there is no motion in the kitchen then the speaker is ‘off’ and no tts gets through to that speaker.
I have other speakers in my office.. if I am in my office (again, detected by motion) then if tts is sent to the virtual device by an app, then it plays in my office but not in the kitchen (as when I’m in the office, there is no motion in the kitchen)
The proxy is just a ‘forwarder’ to send tts to each child app then the individual child apps decide whether to play the tts or not.
Andy
That's the answer. Thank you.
So, it goes to every child app. So, SC just helps to, for example, not send it to SpeakerA because no one is there to hear it, or an infant is napping in that room at the moment (no motion), etc.
I was trying to make SC send to multiple speakers when the third party app wouldn't allow that.
Thanks @Cobra
Correct!
You can make it do that too..
Just create a child app with the multiple speakers configured and use the proxy in your 3rd party app
I guess you decided to ditch putting the virtual device back into the child app? Having it in the parent app removes the ability to use zones of speakers the way I'm doing.
My other option is to create multiple instances of the parent app. This sort of works except that the second parent somewhat blindly create the virtual speaker device on install. This throws an error because the DNI is already in use by the first parent. Also, I can't name the parents so they have identical names. Also, once two parent apps are installed side by side neither works. That's kind of an issue.
Can you help me out here and give me one of these two options maybe?
I don't really want to have to fork and maintain my own copy. I wouldn't update at all but you've got some weird bug in 1.2 where every time the hub reboots an exception is thrown in initialize and I haven't had time to track it down. Maybe I'll just look at your commits to see what you did there to fix it.
I’m sorry, I have been tied up with real life and coding for a different project that I’m involved in.
I’m really hoping to get to this soon.
Speaker Central is not really working for me correctly atm so it has become a priority for me too now.
The error on boot is an easy fix
Hopefully, I can get to fix all this next week
Andy
The app was originally designed to use only ONE speaker proxy..
I have LOTS of different speaker groups but only ONE proxy..
And I have so many Message Central messages that I can't even get them all in one screenshot!
The answer is in your screenshot!
put two forward slashes - // in front of the line to comment it out if you are not using the 'Cobra Apps' container
Thanks!
I'm still new to this, and trying to learn as I go.
Thanks again, for teaching me something new!
Does this app/driver get rid of the google sound chime that occurs before tts?
No I'm sorry, it does not
