So, not gonna fix the problem? I take it it works fine on the Android versions, but not iPhone?
Edit: @bptworld, I did further debugging on the issue. The issue appears to be with using the dashboard via the cloud. If I go to the local "http://192.168.1.xx" URL and access the dashboard that way, it works fine. However, if I login through the cloud to the dashboard, it simply does not work. That may be more the issue than iPhone vs Android.
Unfortunately, I would have no idea on how to fix this, I'm not a professional programmer and everything I do takes a lot of time. Time is something I take pretty seriously lately.
If someone wants to take a crack at it, please (as always) feel free to play around with the code. If you can get it to work, I'll gladly add it in.
My use case involves being able to start a timer when I am away from home; so, the dashboard not working via the cloud is a deal killer for me. Let me ask this of anyone monitoring this thread - has anyone used the Android app (away from home) and does it work for them. I think I know the answer already (it would not work), but would like confirmation if possible.
Hi @bptworld - Thank you for this great app that I'm using in my kitchen dashboard.
I'm not getting a message played to my Google Mini at the 10 second warning and at the end of the timer. Both apps are at latest version. I've also hit 'done' wherever possible to ensure everything is updated properly. I have Follow-Me installed and set up.
I'm seeing this message in the error logs (device 34 is my Google Mini):
