This driver will add the doorbell as a pushable button and it adds the tamper detections from the device. This means you can add a warning if somebody tries to remove it.
The Silvercrest is originally supplied by Heiman. Thus, the driver will most likely also work with the Heiman HS2DB Smart Doorbell. (not tested yet)
#Installation
I'm awaiting a pull request before it is added to the Hubitat Package Manager.
In the meantime it can be installed using the following links: Import URL Install Guide
I can confirm this driver works, though not at first.
Because it didn't work immediately I tried other internal HE drivers when finally returning to this driver and found it working then, both the button and tamper detection.
I just got this doorbell but doesn't seem to work for me.
after hitting that small button on the back etc i can get it connected to hubitat.
Or at least for a min. then it's gone again.
before you ask, I do have some zigbee repeating stuff... 2 Lidl outlets, about 28 Hue lights, Ikea plug, 2 Ikea repeaters, 1 ikea bulb,... should be enough to get the doorbel working about 7m from hubitat with only 1 single wall in between.
I have some 'logs' but my english is limited so sorting out some things are hard.
maybe somebody else could help?
In the event tab of the device itself nothing much is happening...
it reports that "DEVICENAME pushed is 0" and that the battery would be 0%
but it's brand new, arrived yesterday after ordering it a few days earlier.
