I have the same issue. I added the app, put in my Schlage credentials, and waited. After 48 hours, only the wifi repeater shows up but none of the locks. 2 are WiFi (BE499WB) and 1 is bluetooth (BE479AA). Does the code need to be updated for some security key?
Same here only 1 of 4 show up, only the encode plus, the other ecode’s do not.
There is a bug fix to the apps code that was posted recently at the link below. With this new code, the app is seeing all 3 of my Schlage Encode Plus locks (used to only see 2 of them).
Would I be correct in assuming if you had Apple's HomeKit running that the interface there would allow you to lock and unlock the lock via the Hubitat's HomeKit app? If not directly to the device via a Virtual Lock that you would keep in sync with the lock?
Thank you for creating this app! I wanted to add an old (10+ yo) Connect lock to my foyer-garage door, but haven't been able to find them in stock anywhere. Finding this App gave me the gut feeling to go ahead and replace the old Connect and manual deadbolt with two Encode locks. They're physically installed now and this app is installed in my Hub. Is there a way to force a scan for the door locks or does it just ... happen at some point? Thanks!
Got my 499 lock and have it working. Installed the app and it asks about home keys. I set one up but it wants:
The log is full of strings but I don’t see anything about HomeKit-000… or the Key Code of User. What am I missing?
Think I found the HomeKit Code Name of User in the Schlage app but still can't find the Apple Key Code as a dashed string? I have tried using Auto, Put and Post but nothing ever appears in the log that looks right.
I've applied the latest code then added a new Schlage WiFi Door locks app and entered my Schlage credentials. Now what...? Will the locks just show up as Devices in the Hubitat? Do I need to do something else? Does it take awhile for the locks to be found?
@user6099,
Okay, I found the log and did a refresh this AM to get current messages. Below are the entire list from today's test. Note I replaced the actual password with asterisks. I see two apparent error messages, first "InvalidParameterException" and last a "Cannot get property 'AccessToken' on null object on line 448" (which my gut suspects may be related to the InvalidParameterException error.
Thank you for any guidance,
pat----
app:3482024-12-28 09:00:41.716 AMerrorjava.lang.NullPointerException: Cannot get property 'AccessToken' on null object on line 448 (method updated)
app:3482024-12-28 09:00:41.635 AMdebug[Schlage Locks] DEBUG: : null
app:3482024-12-28 09:00:41.633 AMdebug[Schlage Locks] DEBUG: : {"__type":"InvalidParameterException","message":"2 validation errors detected: Value at 'userAlias' failed to satisfy constraint: Member must satisfy regular expression pattern: [\p{L}\p{M}\p{S}\p{N}\p{P}]+; Value at 'userName' failed to satisfy constraint: Member must satisfy regular expression pattern: [\p{L}\p{M}\p{S}\p{N}\p{P}]+"}
app:3482024-12-28 09:00:41.144 AMdebug[Schlage Locks] DEBUG: : aws cognito uri: https://cognito-idp.us-west-2.amazonaws.com/ --- data: [AuthFlow:USER_SRP_AUTH, AuthParameters:[USERNAME:Pat Sklenar, SRP_A: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, SECRET_HASH:cZM4WGkjfwlZrvLONMrLo3vgPqxPyqK9TwBgxEBDyXw=], ClientId:t5836cptp2s1il0u9lki03j5]
app:3482024-12-28 09:00:41.129 AMdebug[Schlage Locks] DEBUG: : [AuthFlow:USER_SRP_AUTH, AuthParameters:[USERNAME:Pat Sklenar, SRP_A: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, SECRET_HASH:cZM4WGkjfwlZrvLONMrLo3vgPqxPyqK9TwBgxEBDyXw=], ClientId:t5836cptp2s1il0u9lki03j5]
app:3482024-12-28 09:00:41.098 AMdebug[Schlage Locks] DEBUG: : now : 1735394441098
app:3482024-12-28 09:00:41.097 AMdebug[Schlage Locks] DEBUG: : token_updated : null
app:3482024-12-28 09:00:41.084 AMdebug[Schlage Locks] DEBUG: : Pat Sklenar
2zhrVs9d4
1kfmt18bgaig51in4j4v1j3jbe7ioqtjhle5o6knqc5dat0tpuvo
cognito-idp
us-west-2
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
2
538282c4354742d7cbbde2359fcf67f9f5b3a6b08791e5011b43b8a5b66d9ee6
12265cb914035d5317cabd944dc1a08597111877acb1a43f6be02afb09c26293c9d33320d4dc0c4edbb2367b9d060b61688ea57124b2f8e5c92efed194ccd074c5f4f3aedd3fd5880779917952df56204fcf491ee5720fd38aad98b7c0effc926ea405ed10715d5a5c6658582f42fc8c8f9a5a3da0d3ccc8d73d036675d606c8
app:3482024-12-28 09:00:41.043 AMdebug[Schlage Locks] DEBUG: : large_a_value is 852712447526951670462604150179551084670154071646402076391339992249738562192443418710362829095641054546623846723684467367039807832646708292477435377742150854334349760284140317936670527475328646839859287929268866735057984679092107829230024998163082752568332879441745182891420637833195415394664746737657370303889539570590611207033527714916303799587940560918123220450417992825433936179198580650868603887037796971978100002148116716865065853186843838952493055634745642180020962800524815753112069403920167821419753636444032560056159534948976908115782284107002796099786465869543401370232651141599134817528705648456437741898495229322913402591745946864783284133314963305681458308380795245803905808318965489137186687818072957997987736385048695700671117180338841029730209674775408933594118400542631827192740588968010159703851652395598639202098254981965204767438758426579877060907499785505052354533362061186048192848311093448909171946853
app:3482024-12-28 09:00:41.036 AMdebug[Schlage Locks] DEBUG: : hex_big_a : 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
app:3482024-12-28 09:00:40.878 AMdebug[Schlage Locks] DEBUG: : hex_big_n : 00ffffffffffffffffc90fdaa22168c234c4c6628b80dc1cd129024e088a67cc74020bbea63b139b22514a08798e3404ddef9519b3cd3a431b302b0a6df25f14374fe1356d6d51c245e485b576625e7ec6f44c42e9a637ed6b0bff5cb6f406b7edee386bfb5a899fa5ae9f24117c4b1fe649286651ece45b3dc2007cb8a163bf0598da48361c55d39a69163fa8fd24cf5f83655d23dca3ad961c62f356208552bb9ed529077096966d670c354e4abc9804f1746c08ca18217c32905e462e36ce3be39e772c180e86039b2783a2ec07a28fb5c55df06f4c52c9de2bcbf6955817183995497cea956ae515d2261898fa051015728e5a8aaac42dad33170d04507a33a85521abdf1cba64ecfb850458dbef0a8aea71575d060c7db3970f85a6e1e4c7abf5ae8cdb0933d71e8c94e04a25619dcee3d2261ad2ee6bf12ffa06d98a0864d87602733ec86a64521f2b18177b200cbbe117577a615d6c770988c0bad946e208e24fa074e5ab3143db5bfce0fd108e4b82d120a93ad2caffffffffffffffff
app:3482024-12-28 09:00:40.874 AMdebug[Schlage Locks] DEBUG: : hex_small_a : 12265cb914035d5317cabd944dc1a08597111877acb1a43f6be02afb09c26293c9d33320d4dc0c4edbb2367b9d060b61688ea57124b2f8e5c92efed194ccd074c5f4f3aedd3fd5880779917952df56204fcf491ee5720fd38aad98b7c0effc926ea405ed10715d5a5c6658582f42fc8c8f9a5a3da0d3ccc8d73d036675d606c8
app:3482024-12-28 09:00:40.839 AMdebug[Schlage Locks] DEBUG: : refreshing Schlage Locks...
Still trying to figure out where to get this:
I don't see it in the logs. At least nothing by that name. Anyone that has this working that can help it would really be appreciated.
Is there any known way to make this App less chatty? I get frequent log entries like those shown below in the span of less than 2 seconds (even though the INFO dates and times are from prior periods). The log output seems to be a momentary dump of recent-history lock states (I'm not sure how that is useful).
Since I have 3 BE499WB locks, the amount of log "noise" is a LOT.
app:8332025-01-07 01:21:11.991 PMinfo
[Schlage Locks] INFO: Sun Jan 05 20:01:41 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:11.990 PMinfo
[Schlage Locks] INFO: Mon Jan 06 01:32:00 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.989 PMinfo
[Schlage Locks] INFO: Mon Jan 06 01:32:30 PST 2025 : Locked by thumbturn
[Schlage Locks] INFO: Mon Jan 06 09:32:35 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.988 PMinfo
[Schlage Locks] INFO: Mon Jan 06 09:32:45 PST 2025 : Locked by Schlage button
app:8332025-01-07 01:21:11.987 PMinfo
[Schlage Locks] INFO: Mon Jan 06 10:39:42 PST 2025 : Unlocked by keypad
app:8332025-01-07 01:21:11.986 PMinfo
[Schlage Locks] INFO: Mon Jan 06 22:20:05 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:11.985 PMinfo
[Schlage Locks] INFO: Mon Jan 06 23:11:27 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.984 PMinfo
[Schlage Locks] INFO: Mon Jan 06 23:15:17 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:11.983 PMinfo
[Schlage Locks] INFO: Tue Jan 07 09:25:17 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.418 PMinfo
[Schlage Locks] INFO: Mon Jan 06 10:41:26 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.417 PMinfo
[Schlage Locks] INFO: Mon Jan 06 10:41:49 PST 2025 : Locked by Schlage button
app:8332025-01-07 01:21:11.416 PMinfo
[Schlage Locks] INFO: Mon Jan 06 10:51:47 PST 2025 : Unlocked by thumbturn
[Schlage Locks] INFO: Mon Jan 06 10:51:53 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:11.415 PMinfo
[Schlage Locks] INFO: Mon Jan 06 14:45:58 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.414 PMinfo
[Schlage Locks] INFO: Mon Jan 06 14:46:10 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:11.413 PMinfo
[Schlage Locks] INFO: Mon Jan 06 15:03:21 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.412 PMinfo
[Schlage Locks] INFO: Mon Jan 06 15:03:30 PST 2025 : Locked by thumbturn
[Schlage Locks] INFO: Tue Jan 07 12:24:01 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:11.411 PMinfo
[Schlage Locks] INFO: Tue Jan 07 12:24:14 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:10.870 PMinfo
[Schlage Locks] INFO: Mon Jan 06 13:01:21 PST 2025 : Unlocked by thumbturn
[Schlage Locks] INFO: Mon Jan 06 13:04:19 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:10.869 PMinfo
[Schlage Locks] INFO: Mon Jan 06 14:03:35 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:10.868 PMinfo
[Schlage Locks] INFO: Mon Jan 06 14:04:02 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:10.867 PMinfo
[Schlage Locks] INFO: Mon Jan 06 15:02:10 PST 2025 : Unlocked by keypad
app:8332025-01-07 01:21:10.866 PMinfo
[Schlage Locks] INFO: Mon Jan 06 15:02:20 PST 2025 : Locked by thumbturn
app:8332025-01-07 01:21:10.865 PMinfo
[Schlage Locks] INFO: Mon Jan 06 22:16:43 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:10.864 PMinfo
[Schlage Locks] INFO: Mon Jan 06 22:19:00 PST 2025 : Locked by thumbturn
[Schlage Locks] INFO: Tue Jan 07 09:38:30 PST 2025 : Unlocked by thumbturn
app:8332025-01-07 01:21:10.862 PMinfo
[Schlage Locks] INFO: Tue Jan 07 09:38:40 PST 2025 : Locked by Schlage button
I guess no one using this currently with HomeKit can answer my question? I have it working with a virtual lock mirroring it so I don't even know that it's worth using the driver at all at this point.
How did it work?
Working great doing the mirroring route. Never could get an answer to my question above so I just dumped the driver and manage the lock codes on the Apple side.
Looks like I have the same issue, was wondering if you found a fix? Thanks
Here's my hack to stop the deluge of Log messages from these locks: just comment out line 511:
511 //log.info("[Schlage Locks] INFO: ${message}")
Is this the latest code? Because if it is, nothing is happening for me. I'm currently using a C8 hub. TIA.
I had to reinstall the Schlage WiFi app because I messed up linking my 3 "BE499WB Encode Plus WiFi" units with Apple Homekit. However, the locks no longer connect via this App -- I get this error (reported by others): java.lang.NullPointerException: Cannot get property 'AccessToken' on null object on line 448 (method updated)
I'd like to monitor lock state in HE (and battery level if possible).
You indicated that "I have it working [through HomeKit??] with a virtual lock mirroring it so I don't even know that it's worth using the driver at all at this point."
Would you please explain how you did this?
Never mind! I figured it out:
- Link the Schlage locks to Apple Home
- In HE, create a virtual lock for each Schlage lock
- Use the HomeKit integration app to link the virtual locks to Apple Home
- In Apple Home, for each Schlage lock, create one automation that sets an associated virtual lock to LOCKED when the actual lock is locked, and another automation that sets the associated virtual lock to UNLOCKED when the actual lock is unlocked
- The virtual locks will reflect the lock state MUCH faster than the Schlage Wifi driver.
Thanks for the hint about virtual locks!
Is there a more up to date version? I have multiple locks configured in my Schlage app, but the hubitat app only pulls 2 of my locks.
Any suggestion on where to check out.
Logs below, I sanitized my password
Schlage WiFi Locks
app:2112025-06-21 01:42:42.400 AM
error
groovy.lang.MissingPropertyException: No such property: name for class: java.util.LinkedHashMap$Entry
Possible solutions: value on line 614 (method updated)
app:2112025-06-21 01:42:42.387 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:22:40 EDT 2025 : Firmware updated
app:2112025-06-21 01:42:42.386 AM
debug
[Schlage Locks] DEBUG: : 1750468960000 : Firmware updated : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
info
[Schlage Locks] INFO: Fri Jun 20 21:22:44 EDT 2025 : WiFi AP connect
app:2112025-06-21 01:42:42.385 AM
debug
[Schlage Locks] DEBUG: : 1750468964000 : WiFi AP connect : 00000000-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.384 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:22:46 EDT 2025 : null by 00040000-2000-0000-ffff-ffffffffffff
app:2112025-06-21 01:42:42.383 AM
debug
[Schlage Locks] DEBUG: : 1750468966000 : null : 00040000-2000-0000-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.382 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:22:49 EDT 2025 : WiFi host connect
app:2112025-06-21 01:42:42.381 AM
debug
[Schlage Locks] DEBUG: : 1750468969000 : WiFi host connect : ffffff00-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.380 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:28:31 EDT 2025 : Unlocked by thumbturn
app:2112025-06-21 01:42:42.379 AM
debug
[Schlage Locks] DEBUG: : 1750469311000 : Unlocked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.378 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:29:39 EDT 2025 : Locked by thumbturn
app:2112025-06-21 01:42:42.377 AM
debug
[Schlage Locks] DEBUG: : 1750469379000 : Locked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
info
[Schlage Locks] INFO: Fri Jun 20 22:23:27 EDT 2025 : WiFi host disconnect
app:2112025-06-21 01:42:42.376 AM
debug
[Schlage Locks] DEBUG: : 1750472607000 : WiFi host disconnect : 00000000-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.375 AM
info
[Schlage Locks] INFO: Fri Jun 20 22:23:29 EDT 2025 : WiFi host connect
app:2112025-06-21 01:42:42.374 AM
debug
[Schlage Locks] DEBUG: : 1750472609000 : WiFi host connect : ffffff00-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:42.373 AM
info
[Schlage Locks] INFO: Fri Jun 20 22:36:05 EDT 2025 : Access code user added
app:2112025-06-21 01:42:42.372 AM
debug
[Schlage Locks] DEBUG: : 1750473365000 : Access code user added : ffffffff-ffff-ffff-ffff-ffffffffffff : 956b4f73-0000-0000-0000-000000000000
app:2112025-06-21 01:42:42.261 AM
debug
[Schlage Locks] DEBUG: : [[createdAt:2025-06-21T02:36:08.211Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:f2fd3621-107f-491a-b774-d7cabd6339f6, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:14, keypadUuid:956b4f73-0000-0000-0000-000000000000, secondsSinceEpoch:1750473365], timestamp:2025-06-21T02:36:05.001Z, ttl:2025-07-21T02:36:08.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T02:36:08.211Z], [createdAt:2025-06-21T02:23:31.242Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:ba047964-c371-45f1-bb78-95ed552d2f83, message:[accessorUuid:ffffff00-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:39, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750472609], timestamp:2025-06-21T02:23:29.001Z, ttl:2025-07-21T02:23:31.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T02:23:31.242Z], [createdAt:2025-06-21T02:23:31.039Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:e7e14bf7-4c03-4c32-9bca-f3727fbe5f2b, message:[accessorUuid:00000000-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:37, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750472607], timestamp:2025-06-21T02:23:27.001Z, ttl:2025-07-21T02:23:31.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T02:23:31.039Z], [createdAt:2025-06-21T01:29:40.466Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:689740c5-b208-4778-b59a-aac07be01e1f, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:3, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750469379], timestamp:2025-06-21T01:29:39.001Z, ttl:2025-07-21T01:29:40.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:29:40.466Z], [createdAt:2025-06-21T01:28:32.477Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:8574af9f-633c-4a7c-9fec-7acf1ba8fb02, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:4, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750469311], timestamp:2025-06-21T01:28:31.001Z, ttl:2025-07-21T01:28:32.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:28:32.477Z], [createdAt:2025-06-21T01:22:50.623Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:bc0a79a4-530b-4d47-bed6-770df39be8fb, message:[accessorUuid:ffffff00-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:39, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750468969], timestamp:2025-06-21T01:22:49.001Z, ttl:2025-07-21T01:22:50.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:22:50.623Z], [createdAt:2025-06-21T01:22:50.343Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:ad3084cb-f091-4f74-aebb-122b24b391d5, message:[accessorUuid:00040000-2000-0000-ffff-ffffffffffff, action:2, clientId:null, eventCode:41, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750468966], timestamp:2025-06-21T01:22:46.001Z, ttl:2025-07-21T01:22:50.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:22:50.343Z], [createdAt:2025-06-21T01:22:50.065Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:abe51f27-3b7b-4cf3-9c94-6498ff26e2e3, message:[accessorUuid:00000000-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:38, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750468964], timestamp:2025-06-21T01:22:44.001Z, ttl:2025-07-21T01:22:50.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:22:50.065Z], [createdAt:2025-06-21T01:22:49.870Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:9a6ac556-189d-44c6-952f-7031ee4861e4, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:20, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750468960], timestamp:2025-06-21T01:22:40.001Z, ttl:2025-07-21T01:22:49.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:22:49.870Z], [createdAt:2025-06-21T01:17:13.751Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, deviceTimezoneOffset:-16, logId:0feab9d5-4a91-4b21-bb84-500390e6b081, message:[accessorUuid:a341f6c8-26dd-4930-b045-9faaf448b92e, action:2, clientId:t5836cptp2s1il0u9lki03j5, eventCode:6, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750468633], timestamp:2025-06-21T01:17:13.001Z, ttl:2025-07-21T01:17:13.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:17:13.751Z]]
app:2112025-06-21 01:42:41.906 AM
debug
[Schlage Locks] DEBUG: : uri: https://api.allegion.yonomi.cloud/v1/devices/fd03f15b-6f29-57a9-ba8d-6258af650fc1/logs?sort=desc&limit=10, data: null, method: GET
app:2112025-06-21 01:42:41.904 AM
debug
[Schlage Locks] DEBUG: : [:]
app:2112025-06-21 01:42:41.902 AM
debug
[Schlage Locks] DEBUG: .createChildDevice(): Child device id: fd03f15b-6f29-57a9-ba8d-6258af650fc1 already exists
app:2112025-06-21 01:42:41.877 AM
info
[Schlage Locks] INFO: Fri Jun 20 15:41:35 EDT 2025 : Access code user deleted by 95dc8e12-fb73-1c2c-e93e-4b2114561a0d
debug
[Schlage Locks] DEBUG: : 1750448495000 : Access code user deleted : ffffffff-ffff-ffff-ffff-ffffffffffff : 95dc8e12-fb73-1c2c-e93e-4b2114561a0d
app:2112025-06-21 01:42:41.875 AM
info
[Schlage Locks] INFO: Fri Jun 20 16:28:14 EDT 2025 : Unlocked by thumbturn
app:2112025-06-21 01:42:41.874 AM
debug
[Schlage Locks] DEBUG: : 1750451294000 : Unlocked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
info
[Schlage Locks] INFO: Fri Jun 20 16:35:53 EDT 2025 : WiFi host disconnect
app:2112025-06-21 01:42:41.873 AM
debug
[Schlage Locks] DEBUG: : 1750451753000 : WiFi host disconnect : 00000000-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.871 AM
info
[Schlage Locks] INFO: Fri Jun 20 16:35:55 EDT 2025 : WiFi host connect
app:2112025-06-21 01:42:41.870 AM
debug
[Schlage Locks] DEBUG: : 1750451755000 : WiFi host connect : ffffff00-0000-0000-0000-000000000000 : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.869 AM
info
[Schlage Locks] INFO: Fri Jun 20 19:22:29 EDT 2025 : Locked by thumbturn
app:2112025-06-21 01:42:41.868 AM
debug
[Schlage Locks] DEBUG: : 1750461749000 : Locked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.867 AM
info
[Schlage Locks] INFO: Fri Jun 20 19:40:56 EDT 2025 : Unlocked by thumbturn
app:2112025-06-21 01:42:41.866 AM
debug
[Schlage Locks] DEBUG: : 1750462856000 : Unlocked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.865 AM
info
[Schlage Locks] INFO: Fri Jun 20 20:00:49 EDT 2025 : Locked by thumbturn
app:2112025-06-21 01:42:41.864 AM
debug
[Schlage Locks] DEBUG: : 1750464049000 : Locked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.863 AM
info
[Schlage Locks] INFO: Fri Jun 20 21:56:22 EDT 2025 : Access code user added by d8cb2727-fc76-e88e-904f-e3c935a0bb05
app:2112025-06-21 01:42:41.862 AM
debug
[Schlage Locks] DEBUG: : 1750470982000 : Access code user added : ffffffff-ffff-ffff-ffff-ffffffffffff : d8cb2727-fc76-e88e-904f-e3c935a0bb05
app:2112025-06-21 01:42:41.861 AM
info
[Schlage Locks] INFO: Fri Jun 20 23:08:52 EDT 2025 : Unlocked by thumbturn
app:2112025-06-21 01:42:41.860 AM
debug
[Schlage Locks] DEBUG: : 1750475332000 : Unlocked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.859 AM
info
[Schlage Locks] INFO: Sat Jun 21 01:12:12 EDT 2025 : Locked by thumbturn
app:2112025-06-21 01:42:41.858 AM
debug
[Schlage Locks] DEBUG: : 1750482732000 : Locked by thumbturn : ffffffff-ffff-ffff-ffff-ffffffffffff : ffffffff-ffff-ffff-ffff-ffffffffffff
app:2112025-06-21 01:42:41.736 AM
debug
[Schlage Locks] DEBUG: : [[createdAt:2025-06-21T05:12:11.089Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:1525714b-e2f4-4867-bcf4-1aa89e1d1b75, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:3, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750482732], timestamp:2025-06-21T05:12:12.001Z, ttl:2025-07-21T05:12:11.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T05:12:11.089Z], [createdAt:2025-06-21T03:08:50.935Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:54bdeddf-f1fd-4bfa-8940-2cc40e59c9c7, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:4, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750475332], timestamp:2025-06-21T03:08:52.001Z, ttl:2025-07-21T03:08:50.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T03:08:50.935Z], [createdAt:2025-06-21T01:56:22.791Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:f21ad039-701c-46ee-a248-7b603e595b1a, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:14, keypadUuid:d8cb2727-fc76-e88e-904f-e3c935a0bb05, secondsSinceEpoch:1750470982], timestamp:2025-06-21T01:56:22.001Z, ttl:2025-07-21T01:56:22.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T01:56:22.791Z], [createdAt:2025-06-21T00:00:49.148Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:1cbbb6c6-8534-4c2a-9738-d88a3fc29fa0, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:3, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750464049], timestamp:2025-06-21T00:00:49.001Z, ttl:2025-07-21T00:00:49.000Z, type:DEVICE_LOG, updatedAt:2025-06-21T00:00:49.148Z], [createdAt:2025-06-20T23:40:57.016Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:eb3e0015-4880-444c-a231-a4ea460c9c71, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:4, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750462856], timestamp:2025-06-20T23:40:56.001Z, ttl:2025-07-20T23:40:57.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T23:40:57.016Z], [createdAt:2025-06-20T23:22:29.407Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:3d48e2c7-e8bb-4dff-a1ec-481ad6190748, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:3, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750461749], timestamp:2025-06-20T23:22:29.001Z, ttl:2025-07-20T23:22:29.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T23:22:29.407Z], [createdAt:2025-06-20T20:35:56.417Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:9698ad30-acb4-4e9e-a122-e5bb5869483f, message:[accessorUuid:ffffff00-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:39, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750451755], timestamp:2025-06-20T20:35:55.001Z, ttl:2025-07-20T20:35:56.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T20:35:56.417Z], [createdAt:2025-06-20T20:35:56.190Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:c8877edc-d51c-49cc-94b8-1d182380165f, message:[accessorUuid:00000000-0000-0000-0000-000000000000, action:2, clientId:null, eventCode:37, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750451753], timestamp:2025-06-20T20:35:53.001Z, ttl:2025-07-20T20:35:56.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T20:35:56.190Z], [createdAt:2025-06-20T20:28:15.503Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:95982b89-f02a-4187-9f73-7f00462ebd0a, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:4, keypadUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, secondsSinceEpoch:1750451294], timestamp:2025-06-20T20:28:14.001Z, ttl:2025-07-20T20:28:15.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T20:28:15.503Z], [createdAt:2025-06-20T19:41:37.709Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, deviceTimezoneOffset:-16, logId:ba340ced-618f-422d-9d7a-0bf99fac4f24, message:[accessorUuid:ffffffff-ffff-ffff-ffff-ffffffffffff, action:2, clientId:null, eventCode:15, keypadUuid:95dc8e12-fb73-1c2c-e93e-4b2114561a0d, secondsSinceEpoch:1750448495], timestamp:2025-06-20T19:41:35.001Z, ttl:2025-07-20T19:41:37.000Z, type:DEVICE_LOG, updatedAt:2025-06-20T19:41:37.709Z]]
app:2112025-06-21 01:42:41.538 AM
debug
[Schlage Locks] DEBUG: : uri: https://api.allegion.yonomi.cloud/v1/devices/c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3/logs?sort=desc&limit=10, data: null, method: GET
app:2112025-06-21 01:42:41.537 AM
debug
app:2112025-06-21 01:42:41.534 AM
debug
[Schlage Locks] DEBUG: .createChildDevice(): Child device id: c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3 already exists
app:2112025-06-21 01:42:40.486 AM
debug
[Schlage Locks] DEBUG: : [[CAT:582c864319200146081a2fe87244420c0042010246081a2fe902d141065092c77d9a62f65e549d6f6d28f79c7192, SAT:582182431930014a0048e175512beb1ab65f50573d6d88beab641e84b1209b50c6a5a4, attributes:[CAT:582c864319200146081a2fe87244420c0042010246081a2fe902d141065092c77d9a62f65e549d6f6d28f79c7192, SAT:582182431930014a0048e175512beb1ab65f50573d6d88beab641e84b1209b50c6a5a4, accessCodeLength:0, actAlarmBuzzerEnabled:0, actAlarmState:0, actuationCurrentMax:0, alarmSelection:0, alarmSensitivity:0, alarmState:0, autoLockTime:0, batteryChangeDate:0, batteryLevel:100, batteryLowState:0, batterySaverConfig:[activePeriod:[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], enabled:0], batterySaverState:0, beeperEnabled:1, bleFirmwareVersion:0118.080303.017, deviceUid:ea785df740f1, diagnostics:[adParamsSet:1750451711, bsm:0, currentVoltage:7027, dmd:1, filterVoltage:7030, hostSelect:1, houseKeepingStatus:stat_fwSch=3,dlSch=0,24hrHK=1750498509,rtc=1750484097,stat_rtc=2,stat_ntp=0,stat_netConnect=0, isrCounters:[0, 0, 0, 4, 0, 0, 0, 0, 0], lsiInfo:[1, 100, 618, 1545, 1, 9, 0, 0, 1750484097], macAwakeTime:1, noLoadVoltage:7027, nwpStdbyTime:0, pubCnt:3, pubErrCnt:0, rtosTicks:3997, rxStats:[beaconStateMachine:[0, 9, 1, 1, 6, 2563, 0, 0, 6, 17, 649, 1859, 64, 29, 68, 625, 5897, 0, 0, 2318435364], legacyRxStats:[3727, 201, 528, -74, -74, 0, 0, 2, 16, 3668, 41, 2318426420], macSleepStats:[0, 330, 120950, 148143771, 0, 2167830691, 7, 2469841, 0, 3590517364, 0, 25738313, 0, 0, 0, 2318444304]], taskTicks:[0, 2, 19, 445, 22, 1, 2, 1, 0, 1, 1, 0, 2, 1, 0, 0, 0, 15, 9, 3435, 41], tcpkeepAlive:5, wifiCalibrationTime:1750451711], firmwareUpdate:[status:[additionalInfo:null, updateStatus:success]], homePosCurrentMax:0, keypadFirmwareVersion:104.02.00999277, keypadLockout:0, lockAndLeaveEnabled:1, lockState:1, lockStateMetadata:[UUID:null, actionType:periodicDeepQuery, clientId:null, name:null], macAddress:EA:78:5D:F7:40:F1, mainFirmwareVersion:05.00.01008970, maxSchedule:2, mode:2, modelName:BE489WB2, name:Laundry, periodicDeepQueryTimeSetting:60, psPollEnabled:1, scheduleParams:, serialNumber:34000000000b6e24, supportedFeatures:[activityAlarm:1, scheduledLocking:1, vlac:1], timezone:-16, wifiFirmwareVersion:03.22.00.01, wifiRssi:-74], connected:true, connectivityUpdated:2025-06-21T05:34:55.000Z, created:2025-06-20T19:27:08.000Z, deviceId:c9ab41e0-f0b5-5ff3-93a5-b90d7a83c2a3, devicetypeId:be489wifi2, lastUpdated:2025-06-21T05:34:55.000Z, macAddress:EA:78:5D:F7:40:F1, modelName:BE489WB2, name:Laundry Door Lock, physicalId:34000000000b6e24, relatedDevices:, role:owner, serialNumber:34000000000b6e24, timezone:-16, users:[[email:johnpturner@hotmail.com, friendlyName:John Turner, identityId:a341f6c8-26dd-4930-b045-9faaf448b92e, role:owner]]], [CAT:582c864319200146081a2fe8c40b420c0042010246081a2fe902d14106503bb71f5e2e4b940960665951b239317c, SAT:582182431930014a00488cc1e36a9f74c18c50e65c3b14ed2be9c911bf6798541e2e98, attributes:[CAT:582c864319200146081a2fe8c40b420c0042010246081a2fe902d14106503bb71f5e2e4b940960665951b239317c, SAT:582182431930014a00488cc1e36a9f74c18c50e65c3b14ed2be9c911bf6798541e2e98, accessCodeLength:0, actAlarmBuzzerEnabled:0, actAlarmState:0, actuationCurrentMax:0, alarmSelection:0, alarmSensitivity:0, alarmState:0, autoLockTime:0, batteryChangeDate:0, batteryLevel:100, batteryLowState:0, batterySaverConfig:[activePeriod:[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], enabled:0], batterySaverState:0, beeperEnabled:1, bleFirmwareVersion:01.03.00751535, deviceUid:c3041b999143, diagnostics:[adParamsSet:1750472565, bsm:0, currentVoltage:6920, dmd:1, filterVoltage:6894, hostSelect:1, houseKeepingStatus:stat_fwSch=3,dlSch=0,24hrHK=1750501363,rtc=1750483362,stat_rtc=2,stat_ntp=0,stat_netConnect=0, isrCounters:[0, 54, 0, 0, 0, 0, 0, 0, 0], keypadIsr:[0, 0], lsiInfo:[1, 100, 618, 927, 1, 3, 0, 0, 1750483362], macAwakeTime:1, noLoadVoltage:6920, nwpStdbyTime:0, pubCnt:1, pubErrCnt:0, rtosTicks:4621, rxStats:[beaconStateMachine:[2, 1, 13, 46, 1, 4379, 0, 0, 25, 17, 2144, 3226, 61, 22, 46, 1091, 11074, 0, 0, 2207341780], legacyRxStats:[2923, 146, 70, -72, -72, 0, 0, 0, 110, 2812, 1, 2207331980], macSleepStats:[0, 334, 110696, 63763456, 0, 2142245521, 2, 1343116, 0, 3591671936, 0, 11863329, 0, 0, 0, 2207352094]], taskTicks:[0, 26, 524, 39, 3, 1, 2, 0, 0, 2, 0, 0, 2, 0, 2, 0, 0, 0, 17, 1, 0, 88, 3863, 51], tcpkeepAlive:5, wifiCalibrationTime:1750472565], firmwareUpdate:[status:[additionalInfo:null, updateStatus:success]], homePosCurrentMax:0, keypadFirmwareVersion:02.00.00757179, keypadLockout:0, lockAndLeaveEnabled:1, lockState:1, lockStateMetadata:[UUID:null, actionType:periodicDeepQuery, clientId:null, name:null], macAddress:D3:1E:73:D2:50:AF, mainFirmwareVersion:03.02.00871595, maxSchedule:2, mode:2, modelName:be499WB, name:Living Back Door Main, opMode:1, periodicDeepQueryTimeSetting:60, psPollEnabled:1, scheduleParams:, serialNumber:320000000014bc5b, supportedFeatures:[activityAlarm:1, scheduledLocking:1, vlac:1], timezone:-16, wifiFirmwareVersion:03.22.00.01, wifiRssi:-72], connected:true, connectivityUpdated:2025-06-21T05:22:43.000Z, created:2025-06-21T01:15:37.000Z, deviceId:fd03f15b-6f29-57a9-ba8d-6258af650fc1, devicetypeId:be499wifi, lastUpdated:2025-06-21T05:22:43.000Z, macAddress:D3:1E:73:D2:50:AF, modelName:be499WB, name:Living Backdoor Main Lock, physicalId:320000000014bc5b, relatedDevices:, role:owner, serialNumber:320000000014bc5b, timezone:-16, users:[[email:johnpturner@hotmail.com, friendlyName:John Turner, identityId:a341f6c8-26dd-4930-b045-9faaf448b92e, role:owner]]], [CAT:582c864319200146081a2fe8c7bd420c0042010246081a2fe902d14106507af56a7cfc8f57aa91028869359e4071, SAT:582182431930014a00481eaf65b459658e9e5024d6d57c7308bd6ae39415ff9d10bb49, attributes:[CAT:582c864319200146081a2fe8c7bd420c0042010246081a2fe902d14106507af56a7cfc8f57aa91028869359e4071, SAT:582182431930014a00481eaf65b459658e9e5024d6d57c7308bd6ae39415ff9d10bb49, accessCodeLength:0, actAlarmBuzzerEnabled:0, actAlarmState:0, actuationCurrentMax:259, alarmSelection:0, alarmSensitivity:0, alarmState:0, autoLockTime:0, batteryChangeDate:0, batteryLevel:100, batteryLowState:0, batterySaverConfig:[activePeriod:[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], enabled:0], batterySaverState:0, beeperEnabled:1, bleFirmwareVersion:01.03.00751536, deviceUid:9c2851fa7c82, diagnostics:[adParamsSet:1750473520, bsm:0, currentVoltage:6976, dmd:1, filterVoltage:6957, hostSelect:1, houseKeepingStatus:stat_fwSch=3,dlSch=0,24hrHK=1750495120,rtc=1750484314,stat_rtc=2,stat_ntp=0,stat_netConnect=0, isrCounters:[0, 0, 0, 0, 0, 0, 0, 0, 0], keypadIsr:[0, 0], lsiInfo:[1, 100, 618, 927, 1, 3, 0, 0, 1750484314], macAwakeTime:1, noLoadVoltage:6976, nwpStdbyTime:0, pubCnt:1, pubErrCnt:0, rtosTicks:4002, rxStats:[beaconStateMachine:[1, 3, 3, 30, 2, 4383, 0, 0, 0, 0, 2246, 3190, 32, 1, 31, 1164, 11086, 0, 0, 2203630706], legacyRxStats:[2726, 138, 32, -53, -53, 3, 2666, 57, 0, 0, 0, 2203621822], macSleepStats:[0, 222, 23954, 52507061, 0, 2150046794, 2, 1085852, 0, 3591059326, 0, 7915455, 0, 0, 0, 2203639708]], taskTicks:[2, 17, 248, 31, 2, 1, 1, 1, 0, 2, 2, 1, 4, 0, 2, 1, 1, 0, 26, 0, 0, 5, 3619, 36], tcpkeepAlive:5, wifiCalibrationTime:1750473520], firmwareUpdate:[status:[additionalInfo:null, updateStatus:success]], homePosCurrentMax:164, keypadFirmwareVersion:02.00.00757179, keypadLockout:0, lockAndLeaveEnabled:1, lockState:1, lockStateMetadata:[UUID:null, actionType:periodicDeepQuery, clientId:null, name:null], macAddress:C0:0E:E3:C3:FA:4D, mainFirmwareVersion:03.02.00871596, maxSchedule:2, mode:2, modelName:be499WB2, name:Master Back Door, opMode:1, periodicDeepQueryTimeSetting:60, psPollEnabled:1, scheduleParams:, serialNumber:350000000015ed38, supportedFeatures:[activityAlarm:1, scheduledLocking:1, vlac:1], timezone:-16, wifiFirmwareVersion:03.22.00.01, wifiRssi:-53], connected:true, connectivityUpdated:2025-06-21T05:38:35.000Z, created:2025-06-21T01:34:55.000Z, deviceId:cfec2399-89e5-55fd-aa94-84cf090bd0c8, devicetypeId:be499wifi2, lastUpdated:2025-06-21T05:38:35.000Z, macAddress:C0:0E:E3:C3:FA:4D, modelName:be499WB2, name:Master Backdoor Lock, physicalId:350000000015ed38, relatedDevices:, role:owner, serialNumber:350000000015ed38, timezone:-16, users:[[email:johnpturner@hotmail.com, friendlyName:John Turner, identityId:a341f6c8-26dd-4930-b045-9faaf448b92e, role:owner]]], [CAT:582c864319200146081a2fce4606420c0042010246081a2fe902d1410650d08ef30221da4c99448bb63254d9a59d, SAT:582182431930014a0048c508164ff0205f71506ad8ba3f7ddb2999805c5faadb090ae4, attributes:[CAT:582c864319200146081a2fce4606420c0042010246081a2fe902d1410650d08ef30221da4c99448bb63254d9a59d, SAT:582182431930014a0048c508164ff0205f71506ad8ba3f7ddb2999805c5faadb090ae4, accessCodeLength:0, actAlarmBuzzerEnabled:0, actAlarmState:0, actuationCurrentMax:246, alarmSelection:0, alarmSensitivity:0, alarmState:0, autoLockTime:0, batteryChangeDate:0, batteryLevel:100, batteryLowState:0, batterySaverConfig:[activePeriod:[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], enabled:0], batterySaverState:0, beeperEnabled:1, bleFirmwareVersion:01.03.00751535, deviceUid:4b9ef84fd709, diagnostics:[adParamsSet:1750449529, bsm:0, currentVoltage:6981, dmd:1, filterVoltage:6982, hostSelect:1, houseKeepingStatus:stat_fwSch=3,dlSch=0,24hrHK=1750503526,rtc=1750481925,stat_rtc=2,stat_ntp=0,stat_netConnect=0, isrCounters:[4, 84, 0, 0, 0, 2, 0, 0, 0], keypadIsr:[0, 0], lsiInfo:[1, 100, 618, 1545, 1, 9, 0, 0, 1750481925], macAwakeTime:1, noLoadVoltage:6981, nwpStdbyTime:0, pubCnt:5, pubErrCnt:0, rtosTicks:5554, rxStats:[beaconStateMachine:[5, 14, 9, 9, 5, 2622, 0, 0, 0, 0, 1276, 1897, 145, 8, 69, 661, 6720, 0, 0, 2331771356], legacyRxStats:[1870, 125, 90, -70, -69, 0, 0, 0, 1782, 30, 58, 2331761556], macSleepStats:[0, 344, 21439, 145217728, 0, 2182930771, 7, 3633170, 0, 3592584320, 0, 28453345, 0, 0, 0, 2331781670]], taskTicks:[2, 29, 1603, 37, 4, 1, 1, 1, 0, 2, 0, 1, 5, 2, 0, 0, 1, 0, 15, 4, 3, 159, 3611, 73], tcpkeepAlive:5, wifiCalibrationTime:1750449529], firmwareUpdate:[status:[additionalInfo:null, updateStatus:null]], homePosCurrentMax:180, keypadFirmwareVersion:02.00.00757179, keypadLockout:0, lockAndLeaveEnabled:1, lockState:1, lockStateMetadata:[UUID:null, actionType:periodicDeepQuery, clientId:null, name:null], macAddress:D6:B1:53:46:29:AF, mainFirmwareVersion:03.02.00871595, maxSchedule:2, mode:2, modelName:be499WB, name:Front Door, opMode:1, periodicDeepQueryTimeSetting:60, psPollEnabled:1, scheduleParams:, serialNumber:320000000014bc4a, supportedFeatures:[activityAlarm:1, scheduledLocking:1, vlac:1], timezone:-16, wifiFirmwareVersion:03.22.00.01, wifiRssi:-70], connected:true, connectivityUpdated:2025-06-21T04:58:46.000Z, created:2025-05-31T23:07:19.000Z, deviceId:2c73f2e8-3ba1-57ac-841b-356c3d21c656, devicetypeId:be499wifi, lastUpdated:2025-06-21T04:58:46.000Z, macAddress:D6:B1:53:46:29:AF, modelName:be499WB, name:Front Door Lock, physicalId:320000000014bc4a, relatedDevices:, role:owner, serialNumber:320000000014bc4a, timezone:-16, users:[[email:jomoturner@outlook.com, friendlyName:Molly Turner, identityId:d160e3a7-1af8-432a-8099-fd6a0fd02fac, role:admin], [email:johnpturner@hotmail.com, friendlyName:John Turner, identityId:a341f6c8-26dd-4930-b045-9faaf448b92e, role:owner]]], [CAT:582c864319200146081a2fe8b1cd420c0042010246081a2fe902d1410650775f140901d3853ed933495d46466c8a, SAT:582182431930014a0048c309915b36a6aa1150ed52b7284cffdc358212c9bad7e477a2, attributes:[CAT:582c864319200146081a2fe8b1cd420c0042010246081a2fe902d1410650775f140901d3853ed933495d46466c8a, SAT:582182431930014a0048c309915b36a6aa1150ed52b7284cffdc358212c9bad7e477a2, accessCodeLength:0, actAlarmBuzzerEnabled:0, actAlarmState:0, actuationCurrentMax:0, alarmSelection:0, alarmSensitivity:0, alarmState:0, autoLockTime:0, batteryChangeDate:0, batteryLevel:100, batteryLowState:0, batterySaverConfig:[activePeriod:[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], enabled:0], batterySaverState:0, beeperEnabled:1, bleFirmwareVersion:01.03.00751536, deviceUid:991a5929b143, diagnostics:[adParamsSet:1750471363, bsm:0, currentVoltage:6941, dmd:1, filterVoltage:6929, hostSelect:1, houseKeepingStatus:stat_fwSch=3,dlSch=0,24hrHK=1750557760,rtc=1750482155,stat_rtc=2,stat_ntp=0,stat_netConnect=0, isrCounters:[0, 0, 0, 0, 0, 0, 0, 0, 0], keypadIsr:[0, 0], lsiInfo:[1, 100, 618, 927, 1, 3, 0, 0, 1750482155], macAwakeTime:1, noLoadVoltage:6941, nwpStdbyTime:0, pubCnt:1, pubErrCnt:0, rtosTicks:3999, rxStats:[beaconStateMachine:[2, 6, 3, 10, 2, 4414, 0, 0, 45, 32, 2166, 3206, 34, 7, 90, 1088, 11105, 0, 0, 2201697647], legacyRxStats:[2911, 247, 738, -73, -73, 0, 0, 4, 520, 2374, 13, 2201688641], macSleepStats:[0, 275, 103168, 60331623, 0, 2140279866, 2, 1095159, 0, 3591448120, 0, 9218831, 0, 0, 0, 2201706649]], taskTicks:[3, 17, 257, 29, 1, 0, 2, 2, 2, 0, 2, 1, 0, 0, 0, 4, 3, 0, 24, 2, 0, 5, 3604, 41], tcpkeepAlive:5, wifiCalibrationTime:1750467765], firmwareUpdate:[status:[additionalInfo:null, updateStatus:success]], homePosCurrentMax:0, keypadFirmwareVersion:02.00.00757179, keypadLockout:0, lockAndLeaveEnabled:1, lockState:1, lockStateMetadata:[UUID:null, actionType:periodicDeepQuery, clientId:null, name:null], macAddress:FA:16:DB:1A:7D:39, mainFirmwareVersion:03.02.00871596, maxSchedule:2, mode:2, modelName:be499WB2, name:Garage Backdoor, opMode:1, periodicDeepQueryTimeSetting:60, psPollEnabled:1, scheduleParams:, serialNumber:350000000015ed36, supportedFeatures:[activityAlarm:1, scheduledLocking:1, vlac:1], timezone:-16, wifiFirmwareVersion:03.22.00.01, wifiRssi:-73], connected:true, connectivityUpdated:2025-06-21T05:02:35.000Z, created:2025-06-20T23:59:15.000Z, deviceId:56a8b62f-7f46-53dd-84b4-f1068b9dad12, devicetypeId:be499wifi2, lastUpdated:2025-06-21T05:02:35.000Z, macAddress:FA:16:DB:1A:7D:39, modelName:be499WB2, name:Garage Backdoor Lock, physicalId:350000000015ed36, relatedDevices:, role:owner, serialNumber:350000000015ed36, timezone:-16, users:[[email:johnpturner@hotmail.com, friendlyName:John Turner, identityId:a341f6c8-26dd-4930-b045-9faaf448b92e, role:owner]]]]
app:2112025-06-21 01:42:40.231 AM
