Type: The Group Bulb Dimmer-2.1 is the correct dimmer type. The only other one is dated.
Refresh Devices. The Group driver does not include the capability Refresh. The HE folk probably thought there was no need. I would contact support to add this function.
Work-around. Within the rule, send the refresh only to the tv set (not needed for the MS-650).
Looking at bravia driver code:
Refresh does a Poll and that is all. So both are not necessary.
On command looks at latest poll and if still polling (TV Asleep), then will send the WOL command.
Off command assumes that the TV is not asleep. May not be a great assumption.
Suggestion:
Poll
Delay 1 sec
Poll
This will poll for status. On first try, if LAN is asleep, the value will be "polling", otherwise on/off state. The second will set the TV to Off and not execute the Poll.
I consider this a minor flaw in the driver (never anticipating the rule machine operation).
I've been using this app and driver ever since you released it Still use it every single day at some point or another, so a massive thank you firstly.
Secondly, is there any way to just play a URL directly? My favourite radio station has moved from Tunein, and I've found their new URL, but this never shows up in the Playing section of the speaker, and if I attempt to use it through the play track, it plays for a little and then stops.
The URL is https://streams.radio.co/se1a320b47/listen. I can get it playing if I use a direct command to the speaker but I'd rather have a more user friendly way of doing it.
The one I use is http://192.168.1.171:55001/UIC?cmd=%3Cname%3ESetUrlPlayback%3C/name%3E%3Cp%20type=%22cdata%22%20name=%22url%22%20val=%22empty%22%3E%3C!%5bCDATA%5bhttps://streams.radio.co/se1a320b47/listen%5d%5d%3E%3C/p%3E%3Cp%20type=%22dec%22%20name=%22buffersize%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22seektime%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22resume%22%20val=%221%22/%3E
I will look into it next week. (Will need to take speakers out or storage.) My thinking is a URL version of the current channel preset implementation (i.e., creatURLStation, playURLStation). Does that sound reasonable?
I went with a Amazon Echo Studio. Excellent audio, can play my selected stations and playlists, and connects to my TV. It also has bluetooth input (never used on the R1's nor here). With Echo Speaks is a also a great TTS Speaker. Fits my home automation schema where the primary control is via voice through Alexa with Hubitat the core (integrating the devices) and a backup in-case the internet or Amazon's AWS are down.
I still have the soundbar and two R1 speakers (with stands) in storage. Wanted to be able to do any changes necessary and I like the idea of url Presets where a person can set up a URL manually then create the presets for rapid call via dashboard or rule machine.
Hi, Multiroom users. I have a totally OT question unrelated to the driver @djgutheinz has given us. In addition to TTS through HE, I also use five of the R1's for surround sound with my Samsung "H" 2014 television.
About once every week, the TV loses connection to the speakers and reverts to its internal speakers. I don't get any notice or realize it has happened until I hear the sound is inferior.
Does anyone know if there is some secret to force the TV to keep the Multiroom configuration? Or, perhaps, what causes it to forget? Sorry for the interruption.
The NEW function urlPresetCreate and urlPresetPlay are what you need to do. The presetCreate is only for conventional channels. This is because the urlPlayback capability in the speakers was an add-on (to support the notification functions) and they never integrated the playback into the devices internal data.
To create the preset:
Make sure you have run Save Preferences after you installed the updates.
Start with playTrack and get the preset playing.
Go to urlPresetCreate and enter an number and short name
To play afterwards, just select urlPresetPlay.
An interesting sidelight. While playing a url, if I change the speaker input to speaker, the url continues to play. It is intended to always play over whatever mode the speaker is in.
I also noticed this when using the command URL to play it.
I couldn't use the tap on the top to stop it playing either, I've been having to unplug it lol.
I tried to delete my preset, and followed your instruction above, but its still showing preset2 as the description, even though the log looks fine.
