I will look into problem. However, there is another way to control the device:
capability "AudioNotification"
command: playText(Text, Volume). Can also use other commands: See below.
It (the HW-N850) is very unlikely to operate at all. The integration is for Samsung Multiroom Audio devices (use a special port and protocol).
I will update title and put a note in top of thread.
It was indeed fixed, but I had to go through and re-save the audio notifications in RM. I deleted and reinstalled the Notification app. They both work now.
You have a soundbar. Prior to doing a play text of any type, you need to enter the API key from "Voice RSS - Registration". (the hubitat-generated TTS mp3 will not play on the Samsung Soundbar. Probably a sample rate limitation within the soundbar.)
I've had this working for a while but decided to update to your latest driver/app. I did a fresh install and haven't been able to find my speakers. I tried everything and it just will not find it. Had to restore to get it to work.. not sure whats up.
Oh sorry so I thought the restore worked but it didn’t. It never could connect to my speaker. I’ve set this up a handful of times in the past but now since I updated the speaker it just hasn’t worked.
