This brings to mind yet another addition (no one really needs it). A function to stop the queue playing until you get home. Then kickStartQueue to play all messages queue while you were gone. Could add the time to the queue messages while in this mode.
Driver Update. The driver has been updated to version 3.3.3. Location is same. Make sure the version is 3.3.3.
Issue: hanging queue.
Cause: attribute trackData used in queue recovery was being written with incorrect data for URL playback. (Url playback information can not be extracted from device. It is set when URL is started
Corrective Actions:
Updated setTrackDescription to NOT run when URL is playing
Updated Refresh to not run getSource nor setTrackDescription whe URL is playing
Simplified recovery data to recoveryVolume only. All other data will be captured from attributes at time of recovery.
Fixed kickQueue to set the state notificationPlaying to false if queue is empty.
Good morning. I was very intrigued when I saw your post about presets. I use this same app with my Samsung R1 and love it, however I only use it for simple TTS notifications. I like to listen to Fox News and saw that link in your post, it works well when I run it in my browser but for the life of me I can't wrap my head around how to insert it into the app. Any help (instructions) will be greatly appreciated.
Select Refresh and wait one minute for the data to update.
go down to Preset Create
Enter a number (1 - 6) and execute the function.
From then on, selecting Play Preset and the number will play fox news.
As far as playing direct, it does not like the www format the browser uses at all (immediate failure). For radio.com, the format is "https://streams.radio.co/STATION ID/listen. If you can get the fox news station id, the you are set to go.
Does someone (@Evilborg) know how to get the station URL?
Yes. But be aware, this integration is for the Samsung Multiroom series of speaker and soundbars. The device MUST be controlled via the Samsung Multiroom Application. It will not work on newer or older Samsung speakers.
I have tested on Tune-In, Pandora, iHeartRadio, and 8tracks. I have not tested (due to required subscription cost) on other services - but they may work.
The button feature is my favorite. Using a button device and knowing the button number for a preset, you can cause preset music to play using Rule Machine.
I was not able to add a preset for Pandora though in Hubitat.
Was thinking it would be cool to add a preset to start pandora when I turn on my gym light.
***** NVMND***** Apparently I also had to refresh the device page All good now
